I am unable to get my sound to work on PC and with me being useless in regards to computers. I went to control panel and it says no audio device. Thanks
  • 903 Answers
Find out the name of your sound card,
Try this first, go to Start>system>hard ware>device manager
while you are there look for sound devices or sound controllers. If they are there but have a yellow exclamtion mark next to them, then you will need to update the drivers for them. Write the name of the sound card down in case you need to get back to me and I will look for the drivers for you. Other to that right click on the sound device, click on properties and then click on update drivers.
I hope this helps
Posted on Nov 17, 2008
I had reformat my PC .. because it wasn't working out .. i was not able to save all the drivers .. as in ALL .. when i finished reformatting my PC .. I discovered that it had no sounds at all .. My PC is...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 13, 2011 | Computers & Internet
I have done formating my computer & the sound dose not recognize at all ....??/ i dont know why i try so many time but useless...
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control
panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 27, 2010 | Compaq Audio card Sound Card
Iam unable to get sound on my pc after windowsxp2 installation and my pc is intel core2duo
hope this helps
Nov 27, 2010 | Intel Computers & Internet
Recently installed binatone S1545 onto computer running xp home. works well but unable to stream music (mostly from Spotify) whilst it is plugged in. Get message on Soyify '' There is a problem with your...
On windows got to "START"
Control Panel/Sounds and Audio Devices.
Audio tab select sound card as Sound playback default device
Voice tab select sound playback default device
Open Skype got to tools/options/audio settings.Select USB device under Microphone and speakers section.
Save all settings. Works well.
Dec 27, 2009 | Computers & Internet
No sound
1)Check the leads connected to speaker
2)un-install and re-install
3) control panel..sound and multimedia and check the properties.
Hope that helps....keep the hope :)
May 20, 2009 | HP Compaq Business Desktop d330 Slim Tower
Built in speakers not working
Please try to check it from Control Panel > Sound, speech & audio devices > Sound and Audio Devices > Hardware tab > then select the Device Name then click Properties tab to verify its condition status or you opt to click Troubleshoot tab. regards
May 12, 2009 | Proview PX 780 Monitor
Sound Won't Work on Dell Computer
Go to Control Panel and go to sound and audio devices. It should have the name of the speakers you are using. If it doesnt then the speakers might not work on that PC. Get a new set of speakers, and try again. It should work on the new ones. If it doesnt, get it checked at PC World or a PC repair store to get it checked, as the problem will be internal in the PC. Hope it works.
Sep 15, 2008 | Dell Computers & Internet
Multimeadia audio device ? error-no sound
Try this:
Right click on your sound card.
Uninstall it.
Scan for hardware change.
Let windows find driver.
If it cant, put in cd and re-install.
Please let me know how this works for you.
Thanks
Dec 12, 2007 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
