Question about Video Game Consoles & Games
System error on x box - Video Game Consoles & Games
Xclamp kit will work, i fix them 30mins
Posted on Nov 17, 2008
Tip
How to use the disk error checking utility...
As you use your hard drive, it can develop bad sectors. Bad sectors slow down hard disk performance and sometimes make data writing (such as file saving) difficult, or even impossible. The Error Checking utility scans the hard drive for bad sectors, and scans for file system errors to see whether certain files or folders are misplaced.If you use your computer daily, you should run this utility once a week to help prevent data loss.
  1. Close all open files.
  2. Click Start, and then click My Computer.
  3. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.
  4. In the Properties dialog box, click the Tools tab.
  5. Click the Check Now button.
  6. In the Check Disk dialog box (called Error-checking in Windows 7), select the Scan for and attempt recovery of bad sectors check box, and then click Start.
  • If bad sectors are found, choose to fix them.
  • Tip: Only select the "Automatically fix file system errors" check box if you think that your disk contains bad sectors.
    on Jun 10, 2010 | Computers & Internet
    Set-top box has encountered an error BE1
    If you use a cable box, then either the cable box is putting out a signal that the set cannot understand or the set has a problem with one of the boards in it.
    Nov 18, 2013 | Samsung Audio Players & Recorders
    Error message stop 0x00000024
    which operating system ?
    If you get the Windows blue screen, you can determine which stop code you have and determine what you need to do in order to get your computer back to working correctly.
    First, make sure that you have this error code - Stop 0x00000024 or NTFS_FILE_SYSTEM. This message shows that a problem occurred within Ntfs.sys, the driver file that allows the system to read and write to NTFS file system drives. One possible problem is a malfunctioning SCSI and Advanced Technology Attachment (ATA) hardware or drivers. This can also adversely affect the system's ability to read and write to disk, causing errors. If the computer is using a SCSI hard drive, check both for cabling and termination problems between the SCSI controller and the disks. You will need to periodically check the Event Viewer for error messages related to SCSI or FASTFAT in the System log. You can also use Autochk in the Application log. Try the following. First, Double-click My Computer, select the hard disk you want to check. Then, on the File menu, click Properties. Then, click the Tools tab. Next, in the Error-checking box, click Check Now.
    Finally, in Check disk options, select the scan for and attempt recovery of bad sectors check box. You can also select the Automatically fix file system errors check box.
    http://answers.microsoft.com/en-us/windows/forum/windows_xp-system/windows-xp-blue-screen-error-message-0x00000024/9d6475ed-dc42-4fa7-a2a2-506c42f6ee63
    Feb 24, 2013 | Computers & Internet
    Error 1603
    When you try to install a Microsoft Windows Installer package, you may receive the following error message:
    Error 1603: A fatal error occurred during installation.
    If you click OK in the message box, the installation rolls back.
    To resolve this problem, do any one of the following, depending on the cause of the problem:
    1. On the Windows desktop, double-click My Computer. The My Computer window appears.
    2. Right-click the drive that you want to install the Windows Installer package to, and then click Properties.
    3. Click the Security tab.
    4. On the Security tab, do the following:
      • If you are using Microsoft Windows 2000, verify that the Name box contains the SYSTEM user account.
      • If you are using Microsoft Windows XP, verify that the Group or user names box contains the SYSTEM user account.
      If the SYSTEM user account does not appear in the box, follow these steps to add the SYSTEM account to the box:
      1. Click Add. The Select Users or Groups dialog box appears.
      2. In the Name field, click SYSTEM, and then click Add.
      3. Click OK.
    5. In the Permissions section, click to select the Full Control check box underAllow, and then click Advanced.
    6. Do the following:
      • If you are using Windows XP, in the dialog box that appears, click to select the Replace permission entries on all child objects with entries shown here that apply to child objects check box for the SYSTEM account, and then click OK.
      • If you are not using Windows XP, in the dialog box that appears, click to select the Reset permissions on all child objects and enable propagation of inheritable permissions check box for the SYSTEM account, and then click OK.
      Note If you receive a security message, click Yes.
    7. Wait for the operating system to apply the permissions that you have selected to all child folders.
    8. Run the Windows Installer package.
    Oct 30, 2010 | Intuit QuickBooks Pro 2008: Windows
    PoweReadACValue error
    Probably it is cause due to power management system corruption
    Try following steps
    Perform a Clean Boot
    If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
    Method :Perform a Clean Boot
    Step 1: Start the System Configuration Utility
    1. Click Start, click Run, type msconfig, and then click OK.
    2. The System Configuration Utility dialog box is displayed.
    Step 2: Configure selective startup options
    1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
    2. Click to clear the Process SYSTEM.INI File check box.
    3. Click to clear the Process WIN.INI File check box.
    4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
    6. Click to select the Hide All Microsoft Services check box.
    7. Click Disable All, and then click OK.
    8. When you are prompted, click Restart to restart the computer.
    Step 3: Log on to Windows
    1. If you are prompted, log on to Windows.
    2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
    Note: Start Windows in Normal State
    Steps to configure Windows to use a Normal startup state
    After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
    1. Click Start, and then click Run.
    2. Type msconfig, and then click OK.
    3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
    4. When you are prompted, click Restart to restart the computer.
    Sep 04, 2010 | HP Pavilion dv7-1130us laptop
    Computer restarts on shutdown
    If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts.
    1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
    2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
    Thanks & Regards
    Nandu :)
    Mar 25, 2009 | MSI Computers & Internet
    Trouble exiting safe mode
    Do a system repair with you operating system or recovery disc. This will clear up the system glitch and you won't lose any data.
    Aug 14, 2008 | Acer Aspire 5100 Notebook
    Navigation fatal error Error 1706
    oops..sounds like maybe your drivers are unhappy...
    Mar 09, 2008 | GPS
    Video Game Consoles & Games Logo
    18 people viewed this question
    Top Video Game Consoles & Games Experts
    James Wishart
    Marvin
    Marvin
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
