Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Blower on colman gas furnace will not come on. (have no gas yet)
I bought an older moble home and the furnace is newer but has not been used for 3 years. I rewired it to breaker box but blower will not come on. I have not hooked gas up yet till I can find problem. Does it need the gas on before it will come on?
I'm not a furnace technician. But I have worked on several Coleman trailer furnaces. So keep in mind that my terminology might not be exactly correct. But I think I can help you.
I don't know what model you are running, but most of them run pretty much the same. You have a four basic components to check. Thermostat; Ignition Control Module; Pressure Switch; and which ever of the following that you have (Glow plug, Electronic ignition, Pilot Light).
I'm assuming that you are referring to the blower as the "Rat wheel blower" (round wheel looking thing with fins on it). If my assumption is correct and if the power from the breaker box to the furnace junction box (Probably with a on and off switch on top or side), than when you give it power (from breaker box and turn thermostat up) the fan (not blower) comes on. If it doesn't there is a probably a problem with your Thermostat or Ignition Module. If it does come on and your glow plug or you igniter tries to work. Than yes, you are correct, you have to have gas pressure to let the pressure switch know that there is adequate gas supply pressure (gas- 5 to 7 W.C, propane 11 to 13 W.C). The reason for this is if the Pressure Switch doesn't feel the correct pressure. It thinks you have a leak and won't release gas for ignition. After you turn the gas on. If the furnace doesn't ignite. Make sure the Thermostat is definitely wired properly. Now we are down to one of three problems. If the Glow Plug, Electronic Ignition, or pilot light are working properly. Than we are down one of two problems. The Ignition Module or Pressure Switch. Check pressure on the Pressure Switch. If yuou don't smell gas it is probably OK. But it is best if you use a manometer. I have rarely found Pressure Switches bad. Normally if I get to that step. It is the Ignition Module. The Ignition Module kind of like the brain of the furnace. It is located behind one of your front panels. It will have approximately 10 wires going to it. Some will be going to the Thermostat, some to the Glow plug (Igniter), some to the Pressure Switch, and some going to the blower.
I have probably said more than you need to know. If I did I apologize. But to wrap it up. You were probably correct. You definitely need gas for the blower to kick on. The furnace has to light and heat up before the blower will Start. Not to keep rattling, but to check to see if the blower motor will run. Is to switch the Thermostat from "auto" to "run".
Good Luck
Posted on Nov 23, 2008
Have Gibson furnace runs cycle but seems don't get hot enough out of vents check all 115 degrees at vents use to lot hotter old furnace you couldn't stand on vents now you can easily
Is this a gas furnace ? Newer high eff. gas furnaces do have cooler outlet temperatures. The installer should have checked the temperature rise and gas pressure. By adjusting the gas pressure and blower speed you can obtain a higher outlet temp, but you don't want the gas pressure to be higher than the manufacture specs and you don't want the furnace to run outside of the manufactures temp rise specs.
Mar 02, 2017 | Gibson Heating & Cooling
I have a 1984 Colman propane furnace that is short cycling
Why does the gas furnace short cycle - YouTube
? 11:07
https://www.youtube.com/watch?v=3LBut8fWcw8
Apr 23, 2012 - Uploaded by grayfurnaceman
When the gas furnace short cycles, and it does not bring the structure up ... have a frazier Johnson furnace with 9 blinks on diagnostic light. just ...
Mobile Home Furnace Troubleshooting - Mobile Home Repair
www.mobilehomerepair.com/articlefurnace.php
Jan 17, 2016 | Heating & Cooling
This is a propane furnace that continues to run even after being shut off and plenum cools. No chimmey just pvc pipe to exhaust outside. Does that help.
The fact that the plenum cools down suggests that the thermostat is satisfying its setpoint and correctly turning off the gas flow....but....if the blower is continuing to run after the plenum cools down, it indicates the blower relay on the control board is stuck in the closed position (if it is a newer style furnace) OR the "fan' portion of the 'fan-limit' control is stuck closed if it is an older furnace.
If it is a newer one with a circuit board, the board cannot be field serviced...it must be replaced. Some furnace nmanufacturers have a secondary board that controls the fan alone and is cheaper than the furnaces with the single 'control board' that performs all functions of the heating/blower sequence.
Unless you have a fair amount of understanding of electricity, you should at this point call a service company for service.
Sep 29, 2015 | Heating & Cooling
Furnace computer won't let furnace light
What is the model number? I have an SLP98 (installed on 11/29/2011).... and if I take the cover off the front of the furnace the panel that has the fancy "Lennox" badge on it) you will see two clear round windows about the size of a half dollar (one high on the furnace box and one lower on the blower box.) If you look downward into the window on the blower box you can see a red LED display that will sometimes flash error codes like E228 (one character at a time). If your model has something like this, let me know. I've done some DIY fixes recently out of necessity....and their easy.....and several technicians confessed they didn't know much, if anything, about the newer high effieciency Lennox gas furnaces.
Mar 01, 2013 | Lennox Heating & Cooling
Why does my Colman EB10C electric heater start & run for a few seconds,stop, then restart & run?
check your high limit switch find blower motor and unplug white wire let furnace run it should shut off when hot enough if same problem replace high limit switch
Jan 04, 2013 | Coleman Mobile Modular Home Electric...
Draft blower stays on all the time on my Colman Evcon that is in my mobile home.What could I check for, any sensors? Furnace runs fine otherwise.
there is a temperature sensor in the fire box that keeps the blower going til it cools down after the burner shuts off, could be faulty and keeping the fan on
Feb 14, 2011 | Tools & Hardware - Others
We have a Colman Direct Vent Forced Air furnace, Model 7970A856, in our mobile home. We just moved in. We cannot get the pilot to light.
thermocouple is bad, thats the little probe that sits in the pilot flame, and runs back to the gas valve
Oct 23, 2010 | Heating & Cooling
Heating & Cooling Logo
804 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
