Question about Lands Phones
Philips303 Orange broadband 12 mths old.NO out calls possible, the number required appears on the screen but when the cursor moves over it the dialling tone misses out the first 4/5 digits of the number. It is extremely frustrating as the last call out was on the 13th nov. and there were no apparent problem.I have checked all the connections. Your advice and correction of the defect will be welcomed.
  • jrgg Nov 17, 2008
    Your solution is one of the first I tried on the 114th Nov. Your help has not helped and I would like,please a return of my fee $9.9 as guaranteed in your initial offer, as I have no faith in your solutions (I did tell you that I had tried all the connections.)
    Scholar:
  • 181 Answers
Try to reset it first by removing the battery n re inserting it after 5 mins.
Posted on Nov 17, 2008
How do I enter an MMSI number into my Uniden UM415 It is useless to call Uniden, I have already wasted 3 hours on hold with them.
Hi Peter!
NICE radio Man. You're right, Uniden customer service is horrible.
Ok, here's the deal. You HAVE to get this right the first time, otherwise you pretty much have to send the unit back to Uniden.
Press and hold CALL until the setup menu appears.
Press ENT (1W/25W), that gets you to the user MMSI portion of the program.
NEW should be what you see on the screen.
Press ENT. That'll get you to where you actually get to enter your number.
Using channel up or channel down, set the first number.
ENT
The cursor moves to the next digit.
Repeat until your full MMSI number is entered and displayed on the screen.
IF YOU MAKE AN ERROR, don't panic, press clr/scan and the cursor will move back one spot to the left, erasing the wrong digit.
When the ninth digit is correct, press ENT. The screen will display your MMSI number and ask you to confirm. To save, select yes. To cancel, select no.
Before saving the number, your radio will ask one more time if you wish to confirm and warn you that this is a permanent setting.
Press ENT to confirm, or CLR to start over again.
Hope this helps.
-Steve
Oct 15, 2014 | Boating
Date and time arror
When you turn your machine on for the first time, the display
prompts you to enter the current date and time. After entering,
it will not appear anymore.
NOTE: When turning on the machine after turning it off for a
long time, you need to reset date and time.
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) to display "Date & Time"
on the bottom line and press Enter.
3 Enter the correct time and date using the number keypad.
Month = 01 ~ 12
Day = 01 ~ 31
Year = requires four digits
Hour = 01 ~ 12 (12-hour mode)
00 ~ 23 (24-hour mode)
Minute = 00 ~ 59
NOTE: The date format may differ from country to country.
You can also use the scroll button ( or ) to move the
cursor under the digit you want to correct and enter a new
number.
4 To select "AM" or "PM" for 12-hour format, press the or
button or any number button.
When the cursor is not under the AM or PM indicator,
pressing the or button immediately moves the
cursor to the indicator.
You can change the clock mode to 24-hour format (e.g.
01:00 PM as 13:00). For details, see "Changing the Clock
Mode" on page 2.10.
5 Press Enter when the time and date on the display is
correct.
6 To return to Standby mode, press Stop/Clear.
Changing the Clock Mode
You can set your machine to display the current time using
either a 12-hour or 24-hour format.
of the display.
2 Press the scroll button ( or ) until you see "Clock Mode"
The clock mode currently set for the machine displays.
3 Press the scroll button ( or ) to select the other mode
and then press Enter to save the selection.
4 To return to Standby mode, press Stop/Clear.
May 14, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Cursor at times will jump to another place on screen is this a virus?
Possibly. Run Microsoft Essentials the free antivirus programme that appears to work and is free.
Sep 03, 2012 | Toshiba Satellite A105-S1014...
HOW DO I CALLIBRATE THE SCREEN ON MY DS thanks
Directly from Nintendo:
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
  5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
  6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
Mar 15, 2011 | Nintendo DS Console
Nintendo DS Lite keyboard problem
Recalibrating the Touch Screen
Remove all games from the Nintendo DS Lite.
Turn the system on by pressing the POWER switch.
When the main menu appears, use the Control Pad to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves. (Note : You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.)
When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner.
Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Jan 18, 2010 | Nintendo DS Lite Console
What do i key in for 2 to power of 12??
Between the x`squared key and the log key there is a key with an x with a raised small figure of a solid square. That is the key you use to enter arbitrary exponents.
  1. If calculator is in MathIO ( a Math indicator appears on the upper band of the screen), enter the base of the power (here 2). A number 2 with a raised empty square appears.The cursor will blink in the raised square. Enter there the exponent (here 12) and press [=]. Result 4096 appears at the bottom of the screen.
  2. If in LineIO (no Math indicator appears on the narrow band at the top of the screen), press 2 and then the key I talked about above. On the screen a number 2 appears with a hat and a left parenthesis. Type in the exponent (here 12) , the right parenthesis and press [=]. The calculator should display 4096.000...
Hope it helps
Nov 17, 2009 | Casio fx-300ES Calculator
2 to the twelve power equals what
In the exemples above I used 2^12. But you can enter any base (2, 3, 5.5, 16/47, ) and any exponent ( 12, 13/48, 0.007654, even negative values).
Hope it helps
Nov 17, 2009 | Casio Office Equipment & Supplies
PLASMA SCREEN BLEMISH
This phenomena is called mal-discharge on plasma televisions. When this problem is encountered, it is important that all adjustments be checked and corrected. It is possible that this will resolve the condition. If however, after adjusting all adjustments correctly and according to the specific Panel’s voltage label the problem still exist, then it is necessary
to upgrade the Control’s boards ROM software. You have to ask the help of a qualified technician to do the adjustments or the ROM software upgrade.
Nov 02, 2009 | Televison & Video
The start menu and task bar appear to be off the screen on my desktop and auto die mode is not on:(
Check to see if AUTO HIDE is not enabled in taskbar settings, move your mouse cursor to the bottom of the screen if enabled the Startmenu and taskbar will re-appear, if not then it was possibly resized accidently, move your cursor to the bottom again if it turns into two arrows pointing up and down then click and hold and drag up and it should be revealed again.
Aug 01, 2009 | HP Pavilion dv6000z Notebook
Need nck number
You will need to contact Suncom to have this unlock normally if the phone is more then 12 mths old the unlocking code would be free.
May 31, 2009 | Sony Ericsson Cell Phones
Lands Phones Logo
16 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
