Question about Dell E151FPp 15" TFT LCD Flat Panel Monitor
Stuck in sleep mode
When i turned my computer on this morning, it got to the initial login to the computer and then goes on to show the windows screen. Then a message pops up telling me the computer is entering sleep mode. I cannot get it out of sleep mode. I moved the mouse, pressed keys on the keyboard and nothing happens! Any suggestions??
  • 903 Answers
Make sure all of the fans on your computer are free from dust and dirt. Unplug the computer from the mains and open the casing, hoover away any dust and dirt, then take out clean and resit your RAM and your Graphics card.
This could be caused by dirty RAM, dirty Graphics or just a build up of dust causing it to overheat.
I hope this helps
Posted on Nov 17, 2008
  • Debs
    Debs Nov 17, 2008
    Sorry I should have mentioned too, that if this does not remedy your problem, then it could be that your power supply box is faulty.
Will not run in PC mode
Turn off the mains power for 15mins, then turn on the mains power and boot up your computer.
Mar 30, 2013 | Vizio All-In-One CA24-A1 - Core i5 3210M...
Compaq Presario stuck in sleep mode
Connect the monitor to some other computer, e.g., a notebook, and see if it does the same thing. If it does, then the monitor is the problem.
If it does not, then your computer is not putting-out any "video" signal, and so the monitor goes to "sleep".
If you have MORE than one VGA-output port on your computer, connect your monitor to the "other" VGA port.
Or, press-and-hold the ON/OFF button on your computer, to force it to completely shutdown.
Jan 13, 2010 | HP Pavilion a1710n (RK573AA#ABA) PC...
My Computer boots and montitor says Going to sleep and flashes VGA : NO signal and goes off
Check under "Power Options" of the control panel of Windows that "Turn off Monitor" is set to "Never" Also check under the advanced tab of "Power options" that "When I press the sleep button on my computer" its set to "Do Nothing"
This will most likely solve your problem. the sleep button may be stuck on the keyboard causing the pc to quickly go into sleep mode
Nov 22, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Monitor in sleep mode
This problem could be caused by windows or the monitor .You need to hook up your monitor to another computer and see if you get the same response. If you do check and see in the owners manual if there is a control for power management.Find the control and try to adjust it, or turn it off. If all this does not work than you need to take the monitor in for servicing. If the monitor works,you may have a problem with the computer bios or windows itself. Check all power management controls in the bios and window settings and see if you can find the problem.Check the Microsoft website for this problem with your operating system and a solution. Hope this helps.
Apr 08, 2009 | HP w1907 LCD Monitor
Curious - What is the moon shaped key all about
this button puts the computer into sleep mode.
FROM WIKIPEDIA-
Sleep mode can go by many different names, including Stand By (Microsoft Windows 95-Server 2003), Sleep (Mac OS 8)-(Mac OS X) / (Windows Vista,Windows Server 2008), and Suspend (Linux). When placed in this Sleep mode, aside from the RAM which is required to restore the machine's state, the computer attempts to cut power to all unneeded parts of the machine. Because of the large power savings, most laptops automatically enter this mode when the computer is running on batteries and the lid is closed.
Though Sleep and Hibernate are generally thought as two separate functions, modern Macintoshes, Windows Vista (termed Hybrid Sleep), and some specially configured Linux machines also feature a variation of Sleep mode that incorporates the strengths of Hibernate. The RAM is copied to the hard drive before sleep mode is initiated, preserving the RAM contents in the event of a power loss.
ACPI is the current standard for power management, superseding APM and providing the backbone for sleep and hibernation on modern computers. Sleep mode corresponds to ACPI mode S3. When a non-ACPI device is plugged in, Windows will sometimes disable stand-by functionality for the whole operating system. Without ACPI functionality, as seen on older hardware, sleep mode is usually restricted to turning off the monitor and spinning down the hard drive.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 04, 2009 | HP Computers & Internet
Monitor goes into Sleep Mode immediatly upon turning on computer
I have a LCD panel it is connect to to the LCD. I need to change a setting on the computer to make it stop going into sleep mode, however, now that it's in sleep mode, how do I get out of that so I can make the change?
Jan 09, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Turn off sleep mode, It causes prob. turning on programs to use computer
I have a hp desktop, each time I push the sleep button, the computer goes to sleep, however about 10 seconds ofter entering sleep mode it starts up again.How can I make the computer stay in sleep mode. thanks
Oct 13, 2008 | E-Machines eMachines Desktop PC
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Stuck in sleep mode
Press the power button on the Computer it should come out of sleep mode then if it doesn't hold the power button of the computer down until the system turns completely off.
Then turn back on the computer should now boot fine. Once in windows goto control panel and select power option then adjust the setting.
Hope this helps you
Cheers J
Jan 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell E151FPp 15" TFT LCD Flat Panel Monitor Logo
194 people viewed this question
Alun Cox
