Question about Ricoh Aficio 2018D All-In-One Laser Printer
Printer side problem
Ricoh Aficio 2018D Machine having problem with printing,
showing display SC: 824 CODE: 1401 DETAIL: BA400000
    New Friend:
I have change it but it's in the same problem. .how can I fix it? ?
Posted on Oct 04, 2013
    An expert whose answer gotĀ voted for 100 times.
  • 86 Answers
Try by switching off and on the machine.
If every time you switch on the machine, SC824 re-appears, please replace the NVRAM on the controller board or the controller board itself.
Posted on Jan 10, 2009
Err 553 Ricoh aficio 2018D
SC 553 is a fuser error code, could be thermistor or thermal fuse or fuser lamp
Sep 27, 2013 | Ricoh Digital Copier Toner for Aficio...
Show my printer on display C8 on Ricoh SP 100Su
Fusing Reload Temperature Error (Fatal Error)
Fusing thermistor deformed or out of position ? Fusing lamp harness loose, broken, defective ? Fusing unit defective ? After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.- Carl
Aug 02, 2013 | Ricoh Aficio SP 100SU e Laser...
Please help our ricoh aficio 2018D is printing rubbish - attached by USB to XP machine
Install the pcl 5 driver. Not the one that comes with Windows. Driver is available at
Feb 11, 2011 | Ricoh Aficio 2018D All-In-One Laser...
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Code error
Push Buttons in this order:
Yellow/clear key
and Hold Red/Stop key, for 5 secconds.
If this works, turn machine off/on, the code should be reset. Alltho the code may come back, when the Copier attempts to print a page. If this is the case, you need your Fusing unit Repaired.
Oct 26, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Code 541
may be the was damaged
try to clean use dry tissue
or replaced the drum
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Err0r sc 541
fuser code your thermistor is bad
good luck
Error code 541
may be the drum is damaged
try to clean it use dry tissue
repkaced the drum!!!
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
What SC code is the machine giving? Watch the LCD display and the machine will give an SC Code. Let us know this and we may be help to further.
Mar 10, 2008 | Ricoh Aficio 1018 Printer
Ricoh Aficio 2018D All-In-One Laser Printer Logo
527 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
