Question about Dimplex Compact Electric Flame Stove Heater
Heaters stopped working
Economy 7 key meter. work when connected directly to ring main circuit.but not on economy 7 why?
  • 417 Answers
It could be a faulty timeswitch on the E7 circuit.
Posted on Dec 02, 2008
Overcharge due to faulty credit meter
You could try to adjust the meter. It seems as if the calculation is off. You should be able to work with the electric company. They should be charging you the highest rate 100 percent of the time.
Elisa Jed ' http://www.feldmanfloorheat.com
Apr 22, 2014 | Heating & Cooling
Well my dishwasher won't turn on and it keeps blinking clean and I cleaned it and it won't work
1st unplug or dispower appliance for 2 min. Then, be sure door is cloesd, press heated dry key and Hitemp repeatedly until all lights on panel light up; if no....
The clean led blinks 7 times which indicates a heat circuit error.
Pull the kick plate off and behind should be a tech sheet..Look for heat cicuit... Check the heater for continuity..Some models come with kits main erc w heater....If heater test good then replace main erc and neutral line door switch located inside panel w main erc... Estimate for tech to repair $249-$329.... If you follow my directions you may soon one day become a tech..... A good tech would make $100-$150 on this job profit
Oct 29, 2012 | Dishwashers
Creda storage heater manual
I'm not a heating expert, but according to the information I could find, Economy 7 utilizes cheap electricty at night, during off-peak hours (7 hours) between midnight and 7AM. Economy 7 costs about 4p per unit compared to peak electricity, which is about 10 to 15p per unit. If you do not have Economy 7, you can request it FREE of charge from your electricity provider. You will either have one meter with two readings or two separate meters. A two tariff electric meter will record the electricity used during off peak times, so it can be billed, separately, at a lower rate. If you have two meters, one meter controls on peak daytime electricity and the other controls your night time economy 7 electricity.
I would need to know what model Creda heater you have installed in order to determine how energy efficient it may be. I also will need the model so I can determine operating instructions. If you need further assistance, please post back and let me know. I hope this helps.
Nov 15, 2011 | Heating & Cooling
The wires come off the pump so i put them back on now i got nothing working
Also,
please note that all electrical wiring and installation details given on diydata.com is for information purposes only. From 1st January 2005, the Building Regulations Part P requires, in England and Wales, that only certified persons can carryout electrical installation work, or the work must be certified upon completion - see this page for more details.
Ring circuit
(1) The ordinary wall sockets around the house are normally connected to a ring circuit (also referred to as a ring main). The ring circuits of a domestic property supply the socket outlets and fixed appliances in the premises.
(2) The 'ring' is formed by the cable going from the consumer unit to the first socket, then on to the second socket and then the next socket etc. until the cable returns to the consumer unit. This means (in simple terms) that every socket on the ring circuit has two cable routes back to the supply. The cable of the ring circuit consists of a red (live) wire, a black (neutral) wire and a bare copper earth wire, all three being enclosed by an outer PVC sheathing. The cable used in domestic ring circuits is either 2.5sq mm or 4.0sq mm twin core and earth, these are rated (in free air) at 24amps or 32amps respectively.
(3) Each ring circuit is protected by a 32 amp fuse or trip fitted in the consumer unit. Modern installations incorporate a Residual Current Device (RCD) before the consumer unit which trips the whole system off if a fault is detected.
(4) In older houses the cabling for ring circuits (and other circuits) may be fed through the wall cavity with the cables coming into the back of the wall mounted socket. This is unacceptable in new premises and extensions. It is now considered that cables within the cavity may become wet causing the insulation of the cable to break down and moisture running down the cable into the socket. When rewiring older houses, new cables should not be run through the cavity, they should be run through new ducting embedded in the inner wall surfaces or under floorboards.
(5) A ring circuit is considered to be rated at 30amps (7200 watts). A ring may serve up to 100 m sq of floor area and, in theory, may have any number of sockets outlets or fused connection units connected to it. With each socket outlet is normally rated at 13 amps, as a 'rule of thumb', they are limited to under twenty outlets, it is unlikely that the variety of domestic appliances being used at any one time will exceed 30amps. The length of cable used in a ring circuit is limited to 50 metres for circuits protected by an MCB. The sockets are normally mounted flush with the wall although surface mounted boxes are often easier to fit when sockets are added to the circuit. .
(6) High power electrical appliances (such as cookers, showers etc.) should not be connected to a ring main even if they use less current that the 30 amp rating of the ring circuit. Connection of such appliances will reduce the number of other appliances that can be use simultaneously and will lead to nuisance trips at the consumer unit.
(7) It is advisable to have at least two ring circuit in all premises, in multi floor houses, one for each floor. The kitchen may have a large number of electrical appliances so a separate ring circuit for the kitchen may also worthwhile, this has the added benefit that a freezer will not be affected if there is a fault elsewhere. A single ring circuit should serve a floor area no greater than 100sq m (or 120sq yd).
(8) In the UK, plugs used on a modern ring circuit have square pins and each plug is fitted with either 3 or 13 amp fuses. The correct fuse should always be fitted to suit the appliance, 3 amp fuses for appliances rated up to 750 watts, (lamps and clock radios etc.) - 13amp fuses for larger appliances up to 3000 watts.
(9) Spur extensions can be connected to the ring circuit. A spur is a socket connected into the ring by a single cable run so the socket does not have the full benefit of two cable routes to the consumer unit. Spurs are often used when a socket is added, it is easier to connect using a single cable rather than extending the ring circuit to include the new socket. A spur extension can be connected to the ring circuit provided that it supplies only 13 amp socket outlet (although that can be a double socket outlet) or one fixed appliance. Over the whole ring, the total number of spurs must not exceed the number of socket outlets directly on the main ring. No more than two separate spurs may be connected from each outlet on the ring.
Removal of the front of a wall socket will give an indication of the circuit connected to it:
A single cable connected to the terminals indicates that it is an existing spur.
Two cables may indicate either that it is on a main ring circuit OR that it is a spur with another spur connected to it. This is not a recognised configuration but possible if both spur sockets are single sockets.
Three or four cables normally indicate a socket on a main ring circuit with one or two spurs running from it.
If the wiring has been changed by a previous diy'er, it may be possible to identify any added cables and then deduce the original circuit.
Ring circuit fused outlet units
Where connection to a fixed appliance is required, a fused outlet unit may be fitted to the wall (rather than a plug socket) and connected into the ring main. These outlets require the correct fuse rating for the appliance and are connected to the appliance by a cable or flex. The outlet may be switched or unswitched and may be fitted with an indicator light to show when the supply is connected.
Where a flex is taken to a heater of any sort (e.g. night store heater) the flex must be of a special 'high temperature' type suitable for the elevated temperatures encountered. Use of ordinary flex will result in the insulation breaking down causing the flex to become dangerous.
A clock outlet is a similar type of unit, but with a small fuse fitted in a special plug connected to the flex. The plug may be retained in the socket by a screw or knurled thumbscrew. Though called a clock outlet, they are also suitable for other small low current appliances such as extractor fan units, door bells.
High Power circuits.
Within domestic premises, there may be a number of high wattage appliances, the most common being an electric cooker, immersion heater and electric shower. Each of these appliances should be connected to the consumer unit using a dedicated fuse/trip and cable run. The installation instructions for the appliance should detail the wattage of the appliance (which will also normally be shown somewhere on the appliance), the amperage of the fuse/trip and the size of cable required. Any switches on these circuits must also be of a suitable current rating. Source(s): http://www.diydata.com/planning/ring_mai...
May 17, 2011 | Hoover Washing Machines
My dishwasher seems to be locked up and needs to be reset. the clean led is constantly flashing. i had this trouble in the past, and the serviceman reset the dishwasher by using the touchpad on the front...
Control is programmed to
stop the current cycle and
not allow any further
cycles if it suspects a
faulty heater (no
temperature increase
detected in heated
intervals). Control blinks
the Clean LED 7 times in
repetitive fashion and
disables the Start/Resume
key until cleared.
Heater circuit problem:
■ Open in heater.
■ Open connection or
component in heater
circuit.
■ Faulty heater drive
circuit on control.
Running Diagnostics clears the control and
allows it to operate again. If heating problem
is not corrected though, the control will stop
running again on next cycle. See below.
1. Unplug dishwasher or disconnect power.
2. Check all components and connections in
the water heating circuit or heat dry circuit.
■ Check resistance of heater.
■ Check resistances of all connections and
components between the control and
heater.
■ Check operation of heater and temperature
sensor in Diagnostics cycle.
Aug 26, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Laser 72 is overheating. Top gets too hot to
Check the fan cage on the back, it should be cleaned to allow for adequate air flow. Be sure curtains are not getting pulled up to the fan cage.
This could also be due to a crack in the pot, or if you put too much fuel treatment in your fuel. Regardless of what is causing the overheat situation, an L 72 is a very old unit. You may not want to invest a great deal of money into repairing this unit. The manufacturer has discontinued several parts for the L 72 such as the main circuit board and the burner rings. Without these parts, you are out a heater.
If you can clean the fan cage and remedy the problem, that would be great. If it is a cracked pot, and you decide to replace, be sure that you know how long it has been since you replaced the ring. A ring in a Laser lasts about 7 years. If your technician does not have rings in stock, you could be out of luck when your unit needs a ring.
Be sure to plug the unit into a dedicated outlet and use a quality surge protector with at least 450 Joules to help protect the board. Hope this was of some help. If you have any further questions, visit www.keepuswarm.com. We do have inventory of these discontinued parts for Laser heaters if you decide to repair and your technician cannot get the needed parts.
Jan 26, 2010 | Rinnai Toyostove Direct Vent Heater:...
Hi 1 of my economy 7 heaters has stopped working
Hi in side the case on the left hand side there is a reset looks like a flat pieceof metal push this it will make a loud click this should reset heat , turn heater off first
Jan 19, 2010 | Heating & Cooling
Blinking Clean light in Whirpool dishwasher
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Jun 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
ECONOMY 7 METER & SYSTEM WONT SWITCH OFF AUTOMATIALLY
Your appliances will charge up no matter what time of day/night it is if they are turned on unless they are wired so as to only come on during Econ7. Usually this through a separate supply out of the meter to that part of the fuse box [split load type] or to a 2nd box supplying only those appliances. This area is your responsibility.
Try testing the power supply tails with a volt stick. It's a non-contact neon indicator about the size of a thick pen
If during Econ 7 period you appliances are using electricity at the higher [day] rate, - & it doesn't matter how they are wired in [see above] - call the power supplier. The meter belongs to them.& is their responsibility.
Maybe wise to check the meter readings at times both day & night with appliances both on & off
Dec 25, 2008 | GE 3.2 cu. ft. Washer
Dimplex Compact Electric Flame Stove Heater Logo
196 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
