Question about Toshiba 65H80 65" Rear Projection Television
Toshiba 65H80 has yellow hue.
The picture looks almost black and white with yellow hue to everything. Blue and yellow objects are accurate, but greens look yellowish and there is no red color.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Posted on Nov 20, 2008
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
Why does my KD-32FS170 32" Sony Trinitron screen have blue hues
If you turn all of the color out of the TV, the picture should be black and white. If that picture is not a true black and white picture, the TV will produce a color picture that has that behind it. It takes the proper mixture of red, green and blue light to produce white. This is something that is done inside the glass picture tube.
In your case, one color (blue is stronger) and the others are weaker.
It probably had not been used for a while. SOMETIMES, the weaker colors will get stronger with use. Adjust the brightness and picture controls to get the closest you can to a black and white picture, and then add the amount of color that seems right to you. Use the TV and hope for the best. It will improve, but 2%, 10%, or 50%; I do not know. The proper repair is to replace the glass picture tube, which is not an option at this time. So, turn it on, play games, and HOPE for the best.
Dec 04, 2014 | Sony Televison & Video
What are signs of picture tube going?
Signs of a CRT going old, are bad focussing, unnatural colours and hues of a certain colour (red, green, or blue) if you watch black/white pictures. In colour pictures, black sequences also show hue.
Jun 13, 2014 | Panasonic CT-32SL14 32" TV
Problem with the Toshiba 50H13 50 in. Rear Projection Television. Green tint
The tubes have aged and the colour balance between the tubes has shifted. You will need to redo it using a black/white test image: first the black (the cutoff point), then the white (the gain) on each tube - always start with the green colour. This is done on the final video amplifier of each tube by adjusting the corresponding semiadjustable resistors.
Jun 02, 2011 | Toshiba Televison & Video
Plugging red to red, white to white, and yellow to SPDIF (black) and got no picture with sound. Plugging red to red, white to white, and yellow to green and got black and white picture with sound. How...
First you need a component cable to solve your problem.Since you have not mentioned what device you are connecting to your TV, I''ll assume its a DVD player or a settop box.There is a Red and White audio sockets + Red / Green / Blue component video socket. Just make sure you connect the corresponding two sets of jacks at both end of your TV & DVD player and everything will work. bobhifi_21.jpg
Mar 27, 2011 | Philips Televison & Video
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
Blues' appear more green
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 05, 2010 | Philips Televison & Video
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Color problems
John here, a customer advocate at Dell headquarters. You can access the main menu by pushing the MENU button. From there you should have access to brightness and contrast controls, color settings, and image settings, among others. You should be able to adjust the settings so that white looks white, and black looks black. If you can't get it where it needs to be from these controls, it may indicate a problem. Call support if that is the case.
Jun 03, 2007 | Dell W1700 17 in. HD-Ready LCD Television
Toshiba 65H80 65" Rear Projection Television Logo
215 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
