Question about Whirlpool RBS275PD Electric Single Oven
Our oven's heating elements will not come on althought the display seems to work correctly.
We used the self-cleaning feature of our oven last week, and now find that the broiler and lower heating elements won't activate. The oven goes through the pre-heat stage and all that just fine, according to the display. But it never gets hot. Any ideas?
  • 6 more comments
  • Paul Hardy Dec 21, 2006
    Found the bad part, replaced it....oven works great! Many thanks! Now I'll be getting homemade pumpkin pie for Christmas dinner...yum.
  • pintail Mar 03, 2008
    I have a whirlpool RBS245PRBOO built in oven. Used the self cleaning feature for the first time and it worked fine. After that however, neither the broiler nor the bottom element work. Display works and fan but not the elements. Checked circuit breaker and connections and are all ok.
  • Anonymous Jun 05, 2008
    I have a Whirlpool single oven that would not heat up even though the display seemed to work properly after I had cleaned the oven for the first time. The repairman said the thermal fuse had burned out. At a cost of $245 I had to oven pulled out and the small fuse replaced. He said that he has seen this problem in many Whirlpool ovens he has worked on, some were older models than mine (which is only about 1 1/2 years old),. He recommended that I not use the oven cleaning feature because the fuse would overheat and blow again. It seems clear to me that this is not a new problem and is being ignored by management. I think I should be reimbursed for my repair bill since I can no longer automatically clean my oven and this is clearly an ongoing problem.
    Susan McKinnon
    Indianapolis, IN
    susanmckinnon@att.net
  • redder7 Jun 25, 2008
    Same problem upper and lower burners don't work after cleaning cycle.
  • hsachdev Nov 26, 2008
    I have a Whirlpool oven, sparingly used. Ran the Self-clean for the first time and now it won't operate on Bake/Broil etc. It seems like from previous posts that the thermal fuse has shorted. Can I replace it myself? Is there a repair manual someone can direct me to, or walk me through instructions?Thx!
  • nelm Dec 31, 2008
    If it is a known problem, does Whirpool fix it or do I need to get a repairman at my expense. It is a built-in. I don't want to even try getting to the back panel and I don't know what a TCO (Thermal Cut Out) looks like.
  • Anonymous Mar 24, 2014
    Oven elements do not heat - both broiler and oven
  • Anonymous Apr 01, 2014
    oven not heating but the light comes on and the displays the number 7
    President:
  • 878 Answers
Wekiwa, your TCO, (thermal cutout) probably opened during the high temps in self clean. You will have to remove the back panel and replace it. It should be just under the vent back there. Part number 4450934. You can ohm it out first to make sure, it will show open (no continuity) if bad. This is an easy job, won't take you that long. Kill power to the range before going back there. In doing a little more research on your model, I see there was a service flash where they recomend moving the TCO over to one side so the cleaning cycle doesn't affect the TCO. This may be covered by Whirlpool. You might want to call them and inquire. Catriver..post back.
Posted on Dec 18, 2006
SOURCE:
How to turn on the self cleaning feature
Don't do it. We see problems all the time from the self cleaning feature being used. Normally, door locks that won't release and burned out elements. All it does is super heats the cavity to about 650'F. This burns any grease on the coating to ash.Use Easy Off, it is a lot cheaper.
Apr 07, 2018 | Ovens
The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
Nov 03, 2007 | Whirlpool GBS307PR Electric Single Oven
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Whirlpool Oven will not heat
Hello there:Usually,
when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. bullet.jpg If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. bullet.jpg Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. bullet.jpg Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. bullet.jpg If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Jul 22, 2010 | Whirlpool RBS275PD Electric Single Oven
I have a triple task Kenmore stove with the self cleaning feature, my oven worked fine till I cleaned it one day and now it wont heat up. I have taken the elements out and had the tested and they are fine...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 11, 2010 | Ovens
KitchenAidKEBS107: NO HEAT after power failure during self clean
Thermostat on the back needs replacement. The problem is caused by overheating the oven. Improper installation or inadequate blower. Depending on the model, the oven might need a new blower in addition to the thermostat. Try calling KitchenAid to find out if the oven needs that blower and get the part number for the thermostat, they might have replaced it with the one with higher temperature rating.
Nov 26, 2009 | KitchenAid KEBS177 Electric Single Oven
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Whirlpool RBS275PD Electric Single Oven Logo
764 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
