Pioneer SD-P5795W 57 in. Rear Projection Television
Problem for Pioneer SD-P5795W 57 in. Rear Projection Television
Pioneer SD P5071-K has a dark picture, though, a good one.
By booskers on Dec 16, 2006
My tv has a dark picture. Everything else seems to be fine. To view the set, I must position myself, just right, in a relatively dark room. The picture is still a straqin to view under these conditions. I've called the repairman, he states " well, it's gonna' be $189 for the service call, I'll give it a good cleanin', that'll add about $100 to the bill, after that we'll see how she looks. Ifin' she's still dark we'll try a few other things. So, it'll be $289 to start, that might just getter' done. But don't worry, Mister, I'll stay at it 'til she works or I gotta' go eat supper!". WHHAAAT? Well, could you please give me some advice. All else works well. Thanks in Advance! Jim
Same Problem
Jan 14, 2009
-   dark picture-   Guest
Best Solution
posted on Dec 24, 2006
Very Helpful)
henlopen
Rank: Wiz
Rating: 84%, 650 votes
You didn't mention if this problem suddenly happened or has been getting dimmer over time. If it's the latter, it could be a heavy buildup of dust/soot/smoke (depending if there are smokers in the house or a wood stove, etc) or the picture tubes going bad. If the set is over 9 years old, I'd replace it with a HDTV set and not look back. If the problem occurred suddendly, then a resistor or some other component may have gone out and it again would not likely be a cheap or easy repair.
Was this helpful?
Yes
No
Solution #2
posted on Jan 14, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i hAve this same tv not alot of money and it looks like it wants to tun on them jut frezzes what should i do??
thanks curt
Popular Solutions for Pioneer SD-P5795W 57 in. Rear
Questions and Unsolved Problems for Pioneer SD-P5795W 57 in. Rear
Do you recommend Pioneer SD-P5795W 57 in. Rear Projection Television?
Answer
Answer
I have a Mitsubishi Medallion 1080. Someone put a code in the parental control and I do not know the... (More)
Answer
i have a 55' sd-p5795w.i have no picture only audio....any suggestions?
Answer
I have a power board with two burned out resistors and two shorted diodes for the SD-P5795W T.V.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
