My monitor looks like it needs tuning in when on
  • 189 Answers
That happen when the monito has been used for a couple of years, have it check with a repair man, or technician.
Posted on Nov 17, 2008
We have the Graco two room monitors, says Graco A5220. Our son got ahold of the parent unit, and now the unit will tune in to the room for a short time, then seems to be looking for the other room which is...
1- Set the room switch to the room you want to disable.
2- Press and hold the "stopwatch" looking button on the left side of the monitor.
3- While still pressing the stopwatch button, press the volume down button until there is only 1 LED left on the display.
4- Release all buttons.
5- Change the rooms switch back to the room you are monitoring so you can change the volume if desired.
Sep 13, 2011 | Graco Toys
My xenon monitor just stop working the power button I used to press it a few times in order to tuned on but now it complitely stop working iopen the monitor but everything seems to look ok inside do u have...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 19, 2010 | Xenon XEN 1510T 15.1" Flat Panel LCD...
Images are not clear and it looks like a tv channel not tuned.SHH
W/power off
Try moving cables to another location and ckn connections
Apr 28, 2010 | Philips Brilliance 150P Monitor
My display don't have light
Disconnect the unit from the computer.
Disconnect from power source.
Let the unit sit for a few minutes.
Plug the unit into the power outlet.
Push in the power button and if you get a message on the screen that says " No Signal " The monitor works fine.
Next, plug the unit into the computer port.
If you do not see a image or a signal, you may need to reseat the vedio card inside the computer.
Sep 25, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Dont know how to tune for the life of me
After plugging it into the tuner ... Play one string and watch the arrow ... If its not centre then gently turn the tuning key for that string on the guitar until it says its in tune ... do this for each string.
When your holding the guitar looking down at the strings ... the biggest one is E ... then from there its A,D,G,B,E.
Apr 04, 2009 | Elo Open Box D20786-000 INTELLITOUCH USB...
Auto-tune isse
you could try adjusting the screen resolution in My Computer/Control Panel/Display this may help.
Also have a look to see if the Adaptor, is set for optimal refresh rate.
Mike @ Compurepair.
Sep 16, 2008 | Computers & Internet
I need to tune a tv does not tell me enough to help you.
Do you mean tune in a channel?
The second person does not have the same problem at all, considering one is a TV and the other a monitor.
For the second person, I have no idea what you mean by "on board cpu's battery"
If the monitor says no sync, it usually means there is no video coming out of the computer. This is most likely a fault with the computer, not the monitor.
Test it by bringing it over to a friends and testing it on his computer.
Mar 23, 2008 | Computers & Internet
1701FP display problem
Try to do the factory reset. It is on the pop up main menu on the screen by pressing the screen button.
Thank you,
Jan 12, 2008 | Dell UltraSharp 1701FP 17" LCD Monitor
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
