Question about HP Computers & Internet
Lack of Power
I have a laptop. I have a newer Targus power adaptor (had at least six months) - I pushed the power button and got no power. The light would light up for the battery each time I pushed the power button. The light was on the adaptor, although the adaptor never showed signs of being warm. The battery has never been replaced. Is it the battery or power adaptor?
  • 64 Answers
1) Battery can be derect.
2) Power adapter can be defect.
3) Power jack can be defedt.
In about 50% of such cases it is the power jack.
Bring it to a repair shop. They can check very easily the battery and the adapter to find out the problem.
Posted on Nov 26, 2008
HI there! I am using a targus universal wall power adaptor for laptops, it has an output of 19.5 V and 90 W. I was wondering if I could use this to charge my UK laptop from ADVENT. The charger for this has...
The wattage is to different, the wattage for the adapter is 90watts, and the charge for the advent is only 65w.
You can always try it, but you risk damaging your battery, or motherboard.
Jul 16, 2011 | Targus APA30US AC Laptop Charger AC...
When i push the power butten, the indicator light flickers, then nothinghappens
Firstly remove the battery and disconnect the A.C adaptor. Press and hold the power button for 30sec and then reconnect them back and check.
Check the port where u connect the A.C adaptor pin if the light is glowing then need to reseat the RAM and the Hard drive of the laptop (Compartments located at the bottom of the laptop)
If still not comming on then Hardware issue take it to local store.
But if the port where u connect the A.C adaptor doesnt have light then
1. check with different wall outlet
2. check if the adaptor is getting warm or not if not then replace it.
3. If yes then better check with different ac adaptor
Mar 31, 2010 | Acer Aspire 5100 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Need an adaptor for a toshiba satellite
Jan 23, 2009 | Toshiba Satellite 15" Flat Panel LCD...
Laptop will not turn on.
plug it into the wall , most newer laptops will have a power boost while plugged into AC.
check your power cable receptical on the back of the laptop, these are notorious for getting loose.
check the cable on the ac adaptor, these are bad for getting breaks that you cant see in them (run your hand down the cable physically and fell for any breaks while unplugged, then do it again plugged in and watch for lights to flicker on the computer.
look for the power light on the laptop to come on when you plug the adaptor in. if you get a light on the adaptor and on the computer, then the adaptor isnt the issue.
the next step is checking the power button and power supply.. post what your results are here and we'll move to the next step if not resolved.
Oct 29, 2008 | Gateway Computers & Internet
Your laptop problom, i have the same thing
I would check the power adapter with a voltage meter. It sounds like the adapter might be defective. The wire at the end of my adapter broke after a month or so of use. I picked up a targus replacement. The only problem since then is the targus plug is a bit loose.
Best wishes
Jul 19, 2008 | Gateway MX8711 Notebook
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Laptop not showing light, power button not turning on, AC adaptor light constantly beeping faintly
Unplug the power cable... Hold the power button down for 15-20 seconds... Plug cable back in and check for light... If this still didnt work, then unplug cable again, take battery out, wait 10 seconds.... Put battery back in, plug cable back in and this should allow you to boot...
Feb 05, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
78 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
