Question about Motorola Mobility V551
My phone is crazy.
My phone is really crazy. At any moment the screen will flick and go back to the main screen. I can be in the menu on settings and all of a sudden the screen will go blank for a second and then when it comes back on it will bo on the main screen. What could it be? PS I just bought this phone a few days ago. Please Help.
  • Anonymous Mar 17, 2014
    When phone booths up goes to main menu screen can't do nothing else after that
  • 43 Answers
If you phone is motorola i can we fix rite away
Posted on Aug 30, 2007
  • Dohs Lokz Aug 30, 2007
    oops damm english...i mean we can both fix ,,,
SOURCE:
How do I switch off the torch
What brand and model phone is it? On an Iphone you start at the main screen, flick the bottom of the screen to view a menu and then press the flashlight icon.
Oct 26, 2014 | Cell Phones
Phone locked up
To Restore to factory settings
1. From the application menu, Select Settings
2. select SD Card & Phone Storage
3. Select Factory data reset
4. Select Reset phone
5. Enter your password if required, then Select Yes to confirm
To do Hard reset if your phone is frozen:
1. Turn the power off. If your Samsung Moment is frozen, pull the battery out and put it back again
2. Hold the Volume Down button, Call and End until "Samsung" appears on the screen along with a menu
3. Select Master reset device
4. When the phone is done erasing, choose the option to reboot
Once the Samsung Moment reboot it returns back to factory-fresh default state settings.
Feb 21, 2014 | Samsung Galaxy Reverb SPH-M950 Virgin...
How do i change my apn settings on my eternity so i can use the straight talk network
From the main screen of your phone open you menu, then messaging, then messaging settings, then multimedia message, then MMS profiles. from there create a new profile and fill in these settings:
Set Name: Straight Talk
Access Name: att.mvno
Auth Type: Normal
User ID: *leave blank*
Password: *leave blank*
Protocol: HTTP
Home URL: http://mmsc.cingular.com
Proxy Address: proxy.mvno.tracfone.com:80
Linger Time: 300
*leave advanced settings alone*
Save your profile and select it using the square on the right of the screen. You should now beable to recive multi-media text messages. Exit out to your phone main screen.
Press menu, then Media Net, then Browser Settings, then Browser Profiles, then select the profile named straight talk by pressing the square on the right side of the screen. You should then be all setup to use all forms of data and messaging on your new Straight Talk plan. I hope this was helpful!
May 02, 2012 | Samsung Eternity Cell Phone
When i open my phone the main screen is all messed up with different colors and i can't see anything. I can still recieve calls and texts, but the screen is just messed up and crazy so i can't see what i'm...
This could be an LCD or program problem. Try the following:
1. Turn off the phone and remove the battery.
2. Leave the battery out for about 15 minutes.
3. Put the battery back and turn the phone back on.
If you get the same problem, you need to contact the manufacturer and have them check the phone. They may need to replace the LCD or they just need to re-flash the firmware of it.
Thank you!
Dec 17, 2009 | LG VX5500 Cell Phone
Screen gets distorted and turns white
The part that is bad is the Ribbon flex cable that geos from the main board to the LCD board. Over time the cable becomes chaffed and will lose continuity between the traces. It can be fixed with
Tessco Part #: GH97-07715A
It does need to be soldered on the LCD side.
Apr 25, 2009 | Samsung SPH-m520 Cell Phone
I have sony ericsson K850i cybershot, it wont charge and is flicking in and out of touch screens will send a text half way in between txt and keeps conection to the net instead of the main menu when you...
you need to have the firmware reflash on the phone and the charging port service on the phone take the phone to a mobile service center and have it fix there.
Oct 30, 2008 | Ericsson Cell Phones
PSP SCREEN FLICKERS AND GOES SLOW IN MAIN MENU
Go to psp recovery menu and set the CPU speed in XMD to default, it should work
Aug 23, 2008 | Sony PlayStation Portable (PSP) Console
Motorola V3 GSM Phone book
you need to set the settings for your phone. just go to settings and look for the phone display settings and set the time duration for the menu to be displayed
Oct 04, 2007 | Motorola Mobility RAZR V3
V3M won't load main screen
The phone's firmware needs to be reflash take the phone to a mobile service center and have them reflash the phone there for you, this should correct any issues that you may have at present.
Oct 03, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Phone acting up - screen problem
see if i can help you here on the white screen go to main menu...settings.....personalize......wallpaper you will see picture next ....is it set to none? you can set a wallpaper here. on the vibrate.....main menu...settings....ring styles... is it set on just vibrate? you can change it here to different settings....vibrate....soft...loud...vibrate and ring so if it just says vibrate u can change it there. mine is set on vibrate and ring...down below that you will see vibrate then ring details...here u can choose the ringer u want plus ringer volume and different settings. hope this gets you back what u wanted. jeff
Oct 01, 2006 | Motorola Mobility E815
Motorola Mobility V551 Logo
65 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
