Over-drive vertical height on monitor screen
I already adjust to either minimum or maximum front panel control on SIZE and CENTER BUTTON,but still i cannot attain perfect allignment of screen display.i tried to open the back panel cover to check for the vertical trimmer/adjustment but found out nothing controls.sir/mam may i request if theirs a code to enter on the service mode of this unit.or any remedy to solve this problem.thank you in advance
  • denson_03 Nov 20, 2008
    sir/maam,
    thank you very much for the reply and for the solution.i will give some more feedback regarding the given solution after ill apply the troubleshooting tips,as of now i have no spare time in fixing again my personal sony monitor model CPD-300SFT,im hoping that TIP 122 and the capacitor is the only culprit. till nxtime and thanks again.
  • remonda_622 Dec 24, 2008
    CRT monitor LG flatron 19" F900B
    Compressed image from the top
    New Friend:
  • 62 Answers
1. back side of LOT one TIP 122 FET replaced.
2. Near to LOT PF 424J / 1600v change.
Posted on Nov 17, 2008
How can i adjust horazantal and vertical screen monitor size so i may fill full screen?
In Windows:
1) Click the "Start" button lower left hand corner of the screen, or the Windows key on the keyboard,
2) Choose "Control Panel",
3) Choose "Display"
4) Choose "Change Resolution", and select one that gets you where you want.
FixedYa !
Feb 25, 2015 | HP Desk Top Access Center DK985A
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Crt monitor height are coming very small in size picture wat probelm
Did you set ur resolution screen setting higher than 1024 in ur computer panel resosulion setting?Yes than that is ur problems right there.CRT monitors modes are based on old technologies ,CRT monitors can't go up more than 1024 resolution setting.Setting resolution more than 1024 resolution for CRT models monitors will have thesse causes.The screen resolution on the screen will shrink and get smaller or will not have video resolution on the CRT monitors screens at all.Only LCD or LED monitors models can support and go higher than 1024 resolution setting has none of these causes.Time to upgrade for a new monitors technologies like LCD or LED monitors models.
Oct 17, 2012 | Computers & Internet
What is the toe adjustment for a 1998 ford windstar 3.8L
Hello Snsimpson
Here are all the specs for the Windstar.
FRONT ALIGNMENT (CURB HEIGHT WITH 1/2 TANK OF FUEL)
Camber
Nominal -0.25°
Minimum -0.75°
Maximum +0.25°
Split 0.0°±0.5° Caster
Right
Nominal +3.80°
Minimum +3.05°
Maximum +4.55°
Split -0.5°±0.5° Left
Nominal +3.30°
Minimum +2.55°
Maximum +4.05°
Split -0.5°±0.5° Total Toe [1]
Nominal -0.10°
Minimum -0.40°
Maximum +0.20° Clear Vision [2]
Nominal -0.2°
Minimum -2.8°
Maximum 3.2° REAR ALIGNMENT (CURB HEIGHT WITH 1/2 TANK OF FUEL)
Camber
Nominal 0.0°
Minimum -0.3°
Maximum +0.3° Total Toe [1]
Nominal -0.06°
Minimum -0.40°
Maximum +0.28° [1] Positive value specifications for toe-in, negative value specification for toe is toe-out. [2] Negative value specification for clear vision is counterclockwise.
Nov 16, 2010 | 1998 Ford Windstar
I have a Samsung NC10 notebook hooked up to an Acer x193w monitor and up until today it has been working perfectly. Now the display will not fill the monitor's space. Horizontal is fine but vertically the...
Do you have a spare computer to hook up to the monitor to see if the monitor's settings are off vertically?
Can you adjust the vertical size of the image of the monitor?
Are the letters squashed down vertically?
If the letters are squashed down vertically, did the setting for pixel size of the screen get adjusted to another size accidentally in the control panel under display settings?
Can you reset the Acer monitor from the menu?
Jul 29, 2010 | Acer X193W LCD Monitor
My westinghouse monitor won't align on the screen. i have tried auto adjust already and it is still missaligned.
Ok, with the Auto adjust, but have you actually tried the buttons that actually manually adjust the screen, size, placement, width, height etc, This will allow you complete control over all aspects of your monitor. You usually select, menu, then step through with one button, and change up, down, side to side, with the left & right buttons.
Mar 02, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
The view on my monitor is very truncated - about two inches top and bottom are not filled
Press the MENU button on the monitor and adjust the width and height of the picture to full screen.
Oct 10, 2009 | LG Computers & Internet
What is the height of britannia omaggio 90 cooker hood?
Here are the dimensions that relate to your cooker hood. The measurements are in mm.
Width 980 front 578 rear
Depth 480
Minimum height 1015
Maximum height 1170
Main canopy height 750
(excl chimney)
Chimney section width 436 main body/340 sliding section
Chimney section depth 170
Mounting height 650 - 750
Regards
Alan Hood
ami-man
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Jun 16, 2009 | Kitchen Ranges
The viewable area is bigger than the screen. I
You probably need to go into the control panel and change the resolution for your display
Mar 12, 2009 | ViewSonic VP920b 19" LCD Monitor
Monitor display prob
Here are some basic trouble shooting tips for new monitors: The picture does not appear
Check to make sure the signal cable is firmly connected in the socket.
Check to see if the computer system's power is ON.
Check that the Brightness Control is at the appropriate position, not at the minimum.
The Screen is not synchronized
Check that the output level matches the input level of your computer.
Make sure the signal timing of the computer system is within the specification of the monitor.
The position of the screen is not in the center
Adjust the H-Size, H-Phase or V-Size, V-Center controls.
Check if the signal timing of the computer system is within the specification of the monitor.
The screen is too bright or too dark
Check if the Brightness or contrast control is at the appropriate position, not at the maximum or minimum.
Check if the specified voltage is applied
Especially, check the horizontal frequency.
The screen is shaking
Move all objects that emit a magnetic field, such as a motor or transformer, away from the monitor.
Check if the specified voltage is applied.
Oct 19, 2008 | Computers & Internet
Computers & Internet Logo
574 people viewed this question
David Payne
David Payne
