Centrex ctw 60560 washing machine dosent pump water out after it does it thing but when ya put the pipe to the groung it runs free
  • 262 Answers
SOURCE: washing machine
there is a tool that hooks to you garden hose that goes in your pipe and expands then blows water down the drain to blow out stoppage it work great you can get it at your local hardware store
Posted on Dec 20, 2007
  • 236 Answers
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
Posted on Mar 16, 2009
venexcsd
  • 1185 Answers
SOURCE: where can i get centrex washing machine parts pls?
Click on the link below
http://www.stareast.com.au/
Posted on Jun 24, 2009
SOURCE: Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
Posted on Jan 18, 2010
  • 86 Answers
SOURCE: Hotpoint - WML520 washing machine - Not pumping water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You could have a blockage in the sump filter or there may be a foreign object in the pump housing stopping it from working, there may be a faulty or lose wiring connection on the pump. Is the tub still full of water? If yes then try lowering the outlet hose into a bowl or bucket and see if any water comes out, if yes the system is clear and it would be pump related, if no then you have a blockage somewhere.
Posted on Mar 06, 2010
Manual for Centrex CTW 60519
do a search on google.com sometimes you can find one through there.
Mar 08, 2015 | Washing Machines
Indesit pwde 8148 s display f05
take out plug????
take off rear panel
look for the pump
then take of the pipes to it and clean them
allso take the pump apart (3 screws)
and clean it
Jan 13, 2014 | Washing Machines
Not pumping out water
Most likely cause is a blocked drain hose. With water in machine try removing the drain hose from where it joins the house drainage (connection to waste under sink or pipe that is specifically for WM.) Put this in a bowl and lower bowl to floor. If water runs out the drain hose is not blocked, if no water runs then the hose is blocked. If water runs then the pump is either broken or blocked - when it should be pumping if it makes a noise then it is not broken.
To unblock the hose or pump - drain the water from the machine (there should be a small pipe hidden behind a front cover at the bottom of the machine put this in a bowl (it will be very slow.) Once drained you should be able to access the pump (it is really an impeller) this should have a screw on front, undo this and remove you should now be able to clean the pump housing. You can also check whether the hose is blocked by blowing down it or pouring water down it. If it is blocked then squeezing the corrugated part of the hose will free some of the blockage. Keep doing this until water can be poured down it. If you live in a hard water area then it would be worth while doing a very hot wash on a regular basis to removed undissolved soap from the machine.
Good Luck
Jan 09, 2013 | Washing Machines
Hi, my hotpoint aquarius df61 makes all the noises of washing, i hear the water going in, motor is running, however i dont believe the spray arms are revolving, so the dishes are not getting clean. i have...
how old is your machine? it is posible to have something in the watwr pump, you hear the water and the motor, but the fan of the pump (washing pump) is blocket. also the pipes hat make connection to the water pump and the arms. at someoane i found glass in the pump and in the arms, many lime, or ather's things. it is recomandet to make a preclean of dish befor you put this in the machine and for beter results an economy of detergents is recomandet also to put a magnetic (or whit renewable resins, It is recommended for drinking water) softner, you wil save some money.
Feb 18, 2010 | Dishwashers
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Maytag washing machine won't drain or agitate
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Make sure nothing is clogging the pump (like a stray piece of clothing) and check the pump impeller. Make sure there are no blades missing/broken and that the impeller spins freely. If there are any broken/missing blades or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or jammed impeller. Remember to disconnect the machine from electrical source before attempting any repair. Sorry for your trouble and I hope this helped. Best wishes.
Sep 23, 2009 | Washing Machines
Looking for a lid for a centrex washing machine model ctw60518
We have a Centrex Washing Machine, Model No. CTW 60518 Top Loader, which has recently broken-down. It leaks and not emptying completely on the spin cycle. We are unable to have repaired due to parts unavailable. If anyone would like this machine for parts kindly phone (07) 4936 4185 (Queensland -The machine has not been flood affected).
Vicki
Jul 07, 2009 | Washing Machines
Wahing Machine wont drain--Centrex CTW 60518
It appears your pump/coupling has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 08, 2009 | Washing Machines
The washer make a humimng noise and don't complete the draining stage. I remove all clothes from of it, and still have some water
Heool Welcome to Fix ya,
Is your drain pipe at the same level as the top of the machine?
You may have any of these two common problems!
Defective Water Pump
If the motor is running and water is not pumping it could be a defective water pump. Ensure the tub to pump water hose is clear. If so, replace the pump.
Defective Motor
If the motor is not running, the pump will not work. Most washing machine use a reversible motor and it is possible for the machine to agitate and not spin or drain.
They need to be diagnosed to know which to replace. You will need a capable hands on tech there to do this!
Please remember to leave a rating before you sign off!
Dec 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
161 people viewed this question
Top Washing Machines Experts
