Question about GE 46GW947 46" Rear Projection Television
Blue Halo, Tried to adjust on Projection TV
I tried to adjust the green (worked fine), the red (worked fine), but no matter how I adjust the blue, I still see this horrible blue halo around mainly white images on the screen. Could you tell me what the problem might be? Is this something I can fix myself? Thanks!
  • 3 more comments
  • brettpeart Nov 24, 2007
    blue is out and need to know if I can adjust manualy? Its on a Mitsubishi
  • 1234johnson May 04, 2008
    i have a nec projection tv and the pictue is terrible
  • ambyG Aug 21, 2008
    I have the same problem.
  • italianyehaw Mar 08, 2009
    i have blue halos around everyting. please help
  • mjremmo May 15, 2009
    blue halo
    Genius:
  • 1,694 Answers
The convergence issue you have will not adjust out....repair
of the convergence circuit will be necessary....then adjust...T.
Posted on Dec 03, 2007
I have the same problem. first i had convergence problem which is now fixed when i replaced STK ICs.i can adjust the colors but the blue halo around while or blue images still remains. i guess its the fault of blue lenses....it has three lenses...red,blue and green i guess and halo may be due dust settle in these lenses. may be have to replace the blue one or coolant of blue may have to be replaced. i am trying to change it. once done will let you know. thanks.
Posted on Jun 23, 2010
I have a 60" Sony HD TV, and after a lighting storm I now see a blue streak running down the left side of the screen. I am not sure if the storm caused this issue or not, or if that was just a coincidence. Any fixes??
Posted on Jun 13, 2010
We hit the side of the tv an it is find for about an hour!!
Posted on Feb 10, 2008
    Champion:
  • 317 Answers
Call tech ..suggest c- chip replacement.
Posted on Nov 26, 2007
Posted on Nov 23, 2008
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Have a projection tv...RCA model 61830BL. Had
Hi the green cross it cant move that the reference for red and blue adjustement ;just try to put the red and blue cross over the green pattern then quit/
if that doesnt work you probly have the stk-xxx ic
who control the color alignment ,are blow/
you will have to replaced and make the convergence
check if you have an auto adjustement for that most projection tv have one...
hope that help..
Mar 28, 2010 | RCA P61830BL 61" Rear Projection...
Sony kp51hw40 has green shadows and on edges in pictures and blue flickers on and off, tried all adjustments including screen, focus, and menu??? no luck
The CRTs in this model of TV had a problem with internal leakage. The blue was usually the first to show the symptom (flicker). Because all 3 CRTs are connected to the same high voltage source, when 1 acts up, the other 2 suffer as well. You need to replace the Blue CRT. However, this TV has some age on it... 1 tube will lead to 2 tubes, and 2 tubes to 3... They only last about 7 years. If you love the TV, replace all 3 (about $200 each). I recommend replacing the Red and Blue first, adjusting the geometry and convergence to the original Green. Then replace the Green, adjusting the geometry and convergence to the new Blue and Red.
Mar 15, 2010 | Sony KP-51HW40 51" Rear Projection...
Red Halo persists after coolant replacment & Converg. Adjustments
If you bought a kit with instrucitons contact the company you purchased it from. They will help.
My guess is that you did not change the fluid in the blue and green tubes. You may have accidently done the red instead.
Mar 07, 2010 | Televison & Video
Toshiba TP43H60 - Unable to adjust colors left/right
Have you tried to adjust in the customer menu or in the TECH menu? I can tell you how to get into the tech menu--if it will not adjust there you have a convergence circuit problem and I can tell you what is needed to repair the set.
SD TECH
Oct 08, 2009 | Toshiba TP43H60 43" Television
Convergence is off - Blue and Red are fine Green will not line up
On most units, the Green is constant and the Red and Blue are adjustable. Here are 2 links on how to manually adjust the convergence. There is a menu option using the remote control. Once there, you will find step by step procedure on how to adjust the convergence. Hope this helps answer your question. All the best!
Greg
http://www.fixyourowntv.com/menumitsubishi.php
http://www.ehow.com/how_2034880_perform-convergence--tv.html
May 23, 2009 | Mitsubishi WS-65809 65" Rear Projection...
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
Blurry screen KP61hs10
Yes, Convergence settings should be tried first before any color adjustment or any fluid changes are done. Remember that there are 3 colors to notice. Red, Green, Blue. The Green is the only one that you can not move with an adjustment The Red and Blue is ligned up on green. Some cases it does matter how linear the Green color is across the board, just how close you get the blue and red on top of green is what matters.
Mar 25, 2008 | Sony KP-61HS10 61" Rear Projection...
Blue Convergence
Blue convergence IC is bad, but change both as red wont be far behind they are cheap about 10.00 ea at the following link.
http://electronix.com/
Jan 14, 2008 | Toshiba TN55X81 55" Rear Projection...
BLUE SCREEN
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
GE 46GW947 46" Rear Projection Television Logo
1,128 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
