Question about Microsoft Windows XP Professional
Hiding taskbar programs
How to hide running programs when minimized to taskbar
Right click on the task bar then look for auto hide task bar.
Posted on Nov 17, 2008
  • 4 Answers
"hide window plus" lets you instantly hide any window off your screen with a single keystroke or right click on the Close button. Plus this utility allows you to quickly run a screensaver, turn off monitor or mute sound using hotkeys. program runs invisibly in background and doesn't clutter your system tray.
you can download this utility from
http://www.hide-window.com/hidewin.exe
A tool bar keeps popping up at dottom on the screen. It runs across each box with last being a ? mark then goes away. How do I stop this?
. .This all i could find on the internet,not sure if it will help.
this was related to the notification area (f.k.a. System Tray). Specifically, the "Action Center" notifications were causing the taskbar to pop-up every few seconds. I went into the Taskbar properties, and selected 'Customize' within the Notification area. I chose the 'Hide icon and notification' option for the Action Center icon. I'm sure that some of the other icons could cause this issue, as well. You just need to use trial and error to figure out which one is causing the problem. OR, I suppose you could choose to hide all of the icons if you don't care to see any of them in the system tray/notification area.
Steps:
1. Right click the taskbar
2. Select Properties
3. Click the 'Customize' button in the section labeled 'Notification area'
4. Find the suspect program (Action Center, in my case)
5. Click the drop-down next to the icon of the offending program
6. Select the "Hide icon and notifications" option
7. Click 'OK' to close the Notification Customization screen
8. Click 'OK' to close the Taskbar properties menu..
or try this link...
how to stop toolbar popping up Google Search
Oct 25, 2017 | The Computers & Internet
Tip
Outlook closes when minimized
You might have faced this issue some times while minimizing MS Outlook.
You can solve this issue by doing some changes in MS Outlook.
Step 1: Open MS Outlook and you will see a small MS outlook icon on task bar
Step 2: Right click on it and Unchek the option Hide when minimized
Once you Uncheck the option Hide when minimized, it will look like the pic below
Now you can see the outlook on taskbar even if you minimize.
on Mar 17, 2010 | Microsoft Outlook 2003 for PC
Tip
You might have faced this issue some times while minimizing MS Outlook.You can solve this issue by doing some changes in MS Outlook.
pic below
on Mar 04, 2010 | Microsoft Office Outlook 2003 for PC
Task bar at bottom with font size on it has gone
The task bar is an important part of the Windows experience. Not only does it contain a variety of information including what time it is and how much battery life is left it's the way most Windows users open programs and documents. As such, the task bar disappearing is a stressful thing, but fixing this problem on your own is possible.
Auto-Hide Sometimes you may think your task bar has disappeared, but it's really just been set to "auto-hide." Move your mouse to the bottom of the screen and see if it pops up automatically. Then check all four sides of the screen. If the task bar was simply auto-hiding, disable this feature by right-clicking the task bar, clicking "Properties" and unchecking "Auto-hide the Taskbar." b> Reboot b> If your task bar disappears, and auto-hide isn't the culprit, the first thing you should do is reboot your computer this fixes the problems in most instances. Only one problem: because your task bar disappeared you can't access the "Start" menu in order to shut down the computer. Instead press "Alt," "Ctrl," and "Delete" at the same time and press "Restart" in the window that pops up after doing so. Your computer should restart, and in most cases your task bar should come back when it restarts. b> More Options b> If rebooting doesn't fix cause the task bar to reappear, your computer might have a problem starting explorer.exe, the program that displays the task bar and desktop icons in Windows. Press "Ctrl," "Shift," and "Esc" at the same time to bring up the System Manager. Then click "File," followed by "New Task (Run)" and type "explorer.exe" in the dialogue box that pops up. You now have your task bar and desktop icons back. Reboot to see if they stick around after rebooting. If not, repeat the process in the above paragraph. When you have you task bar back click "Start," then "Programs," then "Accessories," then "System Tools" and then "System Restore." Restore the computer to a time when everything was working fine by clicking that date on the calendar. Reboot to see if this fixes the problem. If none of this brought back your task bar permanently it may be time to run a repair install. Change My Task Bar b> In Windows operating systems, the taskbar shows your currently active windows and programs, shortcuts to your favorite programs, the time, your volume control, active programs and the "Start" button. You may want to change the taskbar so it has a different look or to customize it to suit your needs when using your computer. Windows XP users have fewer options than Windows Vista or Windows 7 users, but all operating system owners can make changes to the taskbar.
Right-click in your taskbar. Left-click on "Lock the taskbar" if it is currently checked. Otherwise, click back onto the taskbar. Click on any empty area of the taskbar. Drag the taskbar to the position (bottom, top, left or right side of the screen) you desire, and release it. Re the taskbar by moving your cursor to where the taskbar ends. Your cursor will change to a two-way arrow. Left-click and drag the taskbar until it reaches the you want. Move your cursor over the series of separator bumps between the Start button and the Quick Launch menu, and the Quick Launch menu and the active programs section of the taskbar, to alter the of the Quick Launch menu and the active programs area. Right-click the taskbar, and left-click on "Lock the taskbar" once you've completed the changes you wish to make. b> Change Taskbar Options b> Right-click on the taskbar, and left-click on "Properties." Modify the taskbar settings so that it appears the way you like. You can decide whether to show the Quick Launch menu (a series of icons for your most commonly used programs), to show thumbnails for your active programs in Windows 7 and Windows Vista and to group similar active programs, and to automatically hide the taskbar or to always have it on top of other windows. Click on the "Notification" tab in Windows 7 or Vista to modify the way the notification area to the far right appears. Stay on the taskbar tab in Windows XP. Hide inactive icons, and decide which information to show, including the clock or the volume, power and network icons in Windows 7 and Vista. Click on the "Customize" button to specify which programs or notifications should always show, never show or grow inactive with disuse. Click on the "Toolbars" tab in Windows 7 or Vista to specify which toolbars you wish to see in the taskbar. Your options will vary according to the programs you have installed on your computer but may include the Quick Launch, address bar and links toolbars. Click the "Apply" button, then "OK" once you have made the changes you desire. Hope this helps.
Jan 16, 2013 | Computers & Internet
GET RID OF SOME TASKBAR ICONS, NOT JUST HIDE.
You can type at the RUN MENU : msconfig
You will get system configuration utility open
select: SERVICES and the select HIDE ALL MICROSOFT SERVICES.
un tick the box of the program you don't want.
also
on STARTUP MENU untick the box of the program you don't want .
ok
you can use malwarebyte free for 60 days to remove unwanted things in the registry
hope this tip will help you
regards
uttam
Dec 21, 2009 | Microsoft Windows XP Professional for PC
Tip
Hacking Your Way Through the Interface
Use Registry hacks to make a grab-bag of great interface changes.
Hidden in the mazes of the Registry are countless ways to hack XP's interface. Here are some of my favorites.
Hide All Icons in the Notification Area
The System Tray, also called the Notification Area, is the small area on the far-right side of the Taskbar, in which utilities and programs that run in the background, such as antivirus software, show their icons.
I don't find it a particularly intelligent use of screen real estate, so I'd prefer not to see the icons there. To hide them, run the Registry Editor [Hack #68] and go to HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Policies/Explorer. Among other things, this key controls the display of objects throughout XP. Create a new DWORD called NoTrayItemsDisplay. Assign it a value of 1. (A value of 0 will keep the icons displayed.) Exit the Registry and reboot.
While you're at the HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Policies/Explorer key, you can also delete the My Recent Documents icon on the Start menu. Create a new DWORD called NoRecentDocsMenu. Assign it a value of 1. (A value of 0 will keep the icon displayed.) Exit the Registry and reboot.
Hide Only Certain Icons in the Notification Area
You might like to display some icons in the notification area but hide others. If so, you can hide icons on a case-by-case basis. You'll do it by delving through menus, though, not by hacking the Registry. Right-click on the Taskbar and choose Properties → Taskbar. The Taskbar and Start Menu Properties dialog box appears. This dialog box, as the name implies, lets you control how the Taskbar and Start Menu look and function.
In the Notification area of the dialog box, check the box next to "Hide inactive icons," then click Customize. The Customize Notifications dialog box appears,
Click on the program's listing in the Behavior column, and choose from the drop-down menu to hide the icon when the program is inactive, always hide it, or never hide it. Click OK twice. Your changes will take immediate effect.
on Mar 17, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
In vista: taskbar does not show icons of opened files
it might be your taskbar is on auto hide try this
Show or hide the taskbar gl_icon_tip.png Applies to all editions of Windows Vista.
The taskbar is usually located at the bottom of your screen. It looks like this:
getopencontent.aspx?assetid=984f8561-57a1-4b9c-9f22-f0d8dddec294&documentset=en-us&renderkey=xml Taskbar
You can hide the taskbar to create more space. If you don't see the taskbar anywhere on the screen, it might be hidden.
Hide allShow allHide all gl_arrow_down_static.gif To show the taskbar
• If the taskbar is hidden, point to where you last saw it to show it again. If you can't remember where you last saw it, try pointing to the bottom of the screen first, and then to the side or top of the screen, if necessary. You might need to move the pointer almost off the screen to show the taskbar.
gl_arrow_down_static.gif To hide the taskbar
1. Open Taskbar and Start Menu Properties by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Appearance and Personalization, and then clicking Taskbar and Start Menu.
2. Clear the Lock the taskbar check box.
3. Select the Auto-hide the taskbar check box.
The taskbar is hidden from view. You can see it again by pointing to the place where you last saw it.
gl_arrow_down_static.gif To turn off auto-hide
2. Clear the Auto-hide the taskbar check box.
Jun 27, 2009 | Microsoft Windows Vista Ultimate Edition
My gateway laptop wont display my desktop
hi richgato,
when you said that the desktop is not being displayed, does this mean all of the actual desktop screen? or just the background or when you minimize all the windows you see nothing?
fo us to help you further, we may need these information from you or a description of how your screen looks like.
looking forward to your reply.
regards,
voodoo
Apr 12, 2009 | Computers & Internet
No Taskbar
The taskbar is always running in Windows Vista. Unlike Windows XP, it can't be unlocked and hidden unless the 'auto-hide' feature is turned on. If 'auto-hide' is on, simply run your cursor along the bottom edge of the screen and the taskbar should pop-up.
To disable auto-hide, after moving your cursor to bring up the taskbar, right click the taskbar and click properties. Then under the Taskbar tab, uncheck auto-hide.
If auto-hide is off, it may indicate that explorer.exe is not running/has crashed. In order to restart explorer.exe you can either
1) Restart
2) Press CTRL+Shift+Escape, File -> New Task and then type in explorer.exe and run
Feb 01, 2009 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows XP Professional Logo
104 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
