Question about Diesel DZ7044 Watch
Diesel Dz7023 / Dz7044 change wrist strap
Can anyone help, I have a new watch strap to fit to DZ7023 (DZ7044 looks visually similar although I can see the secondary pin). I have removed the spring bar but have not been able to remove a secondary fixed bar which passes through the strap (the strap was cracked and I have cut it away from the second bar to remove). Any ideas how the second bar is removed, and how the new strap is fitted?
FYI new straps available from (around £26):-
http://www.bablas.co.uk/diesel-watch-straps-c-38_107.html?page=2
dz7024 and dz7025 appear to be similar construction.
  • 374 Answers
SOURCE: REPLACEMENT STRAPS
Call Casio Parts dept and they should be able to send you a band. 800-223-2001 is their number. :)
Posted on Jul 23, 2007
jackboy
  • 2985 Answers
SOURCE: Leather wrist strap
I would scrap the strap - the odours are caused by the tanning chemicals getting wet. Retain the fastening and purchase half a meter of nylon ribbon loop it through the case pegs on one side glue them together and pierce for buckle holes. On the buckle side loop it through both case peg and buckle and fold and glue. You have a choice of colour and it cost only fraction of a new leather one- also you will have enough left to make two straps
Posted on Sep 12, 2007
SOURCE: oakley band/strap
I called Oakley customer service and they said mail in watch and they will put on a replacement band for 45 bucks
Posted on Nov 19, 2007
SOURCE: How to adjust the watch strap
I just bought the o-ring watch by Starck, and it looks to have the same style of strap. If you look on the side of the clasp, you will see a pin on both ends. You have to remove these retention pins first (which may require tools that are unavailable to you). First, stabilize the watch on its side on a soft mat - I used the back of a mouse pad. Then, use a thin, stiff piece of metal tool to push the pins out slightly. I used a crafting tool. Once the pin sticks out enough, you can use a fine set of pliers to pull them the rest of the way out. (If this does not make much sense at this point, you may be best off going to watch shop.) Once you remove the pins, the clasp can be removed from the strap simply by lifting the clamp. You then trim the strap with a pair of sharp scissors to the appropriate length - make sure you see exactly what the end looks like, because the shortened strap will need to have the same apperance. After trimming, reclamp the clasp onto the strap, and reinsert the pin. You may need a small hammer to get the pins seated completely. Then, you're done. So obviously intuitive, why would anyone need directions, right? Honestly, Fossil did not make this one easy at all. Kind of irritating.
Posted on Aug 09, 2008
escapement
  • 2334 Answers
SOURCE: Strap for Fossil Philippe Starck PH1035 Wrist Watch
Type in your browser FOSSIL WATCHES.
You will find numerous sites. Go thru them till you find what you're looking for.
Posted on Dec 19, 2008
How to set the time on a diesel watch model number dz7023
Try Googling (diesel)(dz7023)(manual) without parens.
Dec 24, 2016 | Diesel Watches
I need a user manual for my wrist watch Diesel DZ-7044
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all DIESEL watch manuals. Rate me, please .
Apr 08, 2010 | Diesel DZ7044 Watch
I NEED DIRECTIONS TO SET TIME ON A DIESEL DZ7023
Mar 09, 2010 | Watches
How do I set the time on my Diesel DZ7073?
Check out my tips here and find DIESEL watch manuals.
Feb 04, 2010 | Diesel DZ7044 Watch
How do i set the dz7023
Check out my tips. Find diesel watch manuals/instructions there.
Feb 03, 2010 | Diesel DZ7023 Watch for Men
I have a watch that is supposed to wind itself by the movement of my wrist rocking around the wheel and it has stopped.
How old is the watch? If its an older automatic watch it might need to be cleaned! There are 2 types of auto wind watches. Springs or capacitor! If its a spring then take the watch off of your wrist and while holding it in your hand gently rock it back and forth. You should feel the weight moving around inside. If its a capacitor and doesnt start to run after you gently rock it in your hand then you need to take it to a watch repair business and see if they can replace the capacitor!
Jan 09, 2010 | Diesel DZ7044 Watch
My diesel watch gets reset everyday dz-7044110703
I have the exact same problem. The watch was working fine up until I had the battery replaced. I went to another watch repair shop (couldn't go to the same one as I had moved to another town) and the chap there explained that with Diesel watches, when the batteries are replaced a small button inside the mechanism must be pressed to reset the settings, if this isn't done then the annoying problem, inflicting our watches, will occur.
My watch worked fine after, for a few days, then it began to reset again; casting doubt on the watch repair man's explanation. I'll go back to see the chap when I have the time, prob next week and keep you chaps posted on anything new.
Feb 22, 2009 | Diesel DZ7044 Watch
Diesel DZ7044 Watch Logo
781 people viewed this question
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
randymanfive
Are you a Diesel Watch Expert? Answer questions, earn points and help others
