Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Verticle line in display
I replaced the convergence amplifier board and when set powered up there was a mostly straight vertical line starting at top middle of screen extending to about midscreen. Colors converged correctly after some dickering but the line remains. Kind of looks like this: | | | | \ \ | | The line is there no matter the source and changes color with screen. Did I scratch a coating somewhere? This being generated by a chip? Thanks in advance
Re: Verticle line in display - Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Projection Televisions
It might be a bad convergence amp
Posted on Feb 04, 2007
0 characters
3 Points
The vertical green convergence adjustment is broken
Either your convergence ic's are bad or the convergence digital module ( if your model has one ) . I would have it looked at by a service company.
Jan 16, 2010 | Hitachi Projection Televisions
Convergence Adjust
It means probably one of the two convergence ICs has blown
Jul 13, 2008 | Hitachi 53FDX01B 53" Rear Projection...
I replaced all 3 convergence chips, check every
If it had line stright acoss screen thats Vertical IC and Capacitors 100uf 35v ,1uf 50v, 2.2uf 50v Check by hori output Blue capacitor c556 561pf 2kv
Sep 30, 2009 | Mitsubishi VS-60621 60" Rear Projection...
most likely a fault in the vertical deflection circuit or sometimes but rare, in the video circuit. Your problem could be a vertical registration problem(convergence), a bad vertical drive or verical output falure, or a fault at the sweep power suply that feeds the voltage to the verticle circuit. In my opinion, this repair, if it is what I think it is, should run anywhere from 200 bucks, all the way up to 450 bucks.depending on what has to be done. These sets have no user replaceable parts inside them, so trying to fix them yourself these days can not only be dangerous, but if you do not have the right training to work on these solid state sets, can also be alot of guesswork.
Jul 17, 2009 | Zenith D52WLCD 52" Rear Projection...
Rear Projection TV convergence
dear friend if you have that type of skills you cerlainly can either resolder or replace the convergence stks. you we'll need to replace both if that's the case. they look like the audio outputs in the audio amplifiers. good luck
Oct 12, 2008 | Projection Televisions
JVC AV-48WP30 started displaying vertical lines every inch
it looks like theres a wave in the top of my screen on my jvc av-48wp30 not sure but i think it has something to do with the bulbs because the projection mirror wasfine and all wires seemed to be hooked up properly.. can you help? tell me where i can find the bulbs to replace them?
May 13, 2008 | JVC AV-48WP30 48" Rear Projection...
Red vertical lines
red verticle lines are most likely a bad tube or convergence problem. You will not be able to fix this your self . I suspect a bad convergence ic cost for parts are around 45.00 servicer charge about 250 to fix. At least know when you call a servicer you will have
a good understanding of problem.good luck.
doctor video leadingedgeelectronics since 1987
Apr 29, 2008 | Projection Televisions
HCM4215W Green convergence problem
Hi Greg,
Sounds like you have a bad convergence chip in the convergence board. Unfortunatly, about 80% of the rear projection sets I work on have this similar problem. I suggest that you change both chips ( there are 2 of the same ) and remember to use heat sink compound as this is why you not have the problem ( excessive heat destoys electronic components). Good Luck
NC Electronic
Mills, Wyoming
Dec 19, 2007 | Samsung HCM4215W 42" Rear Projection...
Hitachi 43FDX01B rear projection TV
It is adjustable only in the technician menu. You will most likely need to replace the convergence IC's in the TV. This is a very common issue. The locations are IK04 & IK05 and are generic part numbers STK392-110's.
Mar 10, 2007 | Hitachi 43UWX10B 43" Rear Projection...
You need to most likely replace the convergence output IC's probably STK392-110's and check associated resistors around it. HD is not mandated for 2009, only digital braodcast it is at that point all analog television broadcast must stop.
Jan 21, 2007 | Hitachi 46UX50B 46" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
70 people viewed this question
Top Samsung Projection Televisions Experts
Steven Wander
Steven Wander
The Wyzzyrd
Donald Griswold
Donald Griswold
Level 1 Expert
Are you a Samsung Projection Television Expert? Answer questions, earn points and help others
