How to clean cannon iR1022 printer to stop getting black streaks on pages
    Master:
    Sergeant:
  • 449 Answers
Hi
Try running a head cleaning cycle from the maintenance menu, then print a nozzle check. try to run 3 head cleaning cycles then try printing again
Posted on Nov 17, 2008
Black streaks at bottom of page after printing
Okay Grehner, I suggest you to perform a complete alignment and cleaning/maintenance-service for this printer.ASAP...this will help you out with this particular problem during printing.
Blessings.
Gladmar.
Mar 18, 2014 | Savin Office Equipment & Supplies
Cannon D1150 I have a crease down the middle of the page as well as faint black ink. How do I correct this. this happens on envelopes as well.
this sounds to me as toner cartridge fault.
Remove the crg and look at drum surface for streaks. If the streaks are on drum surface, replace drum ( toner ) cartridge if not the problem is in fixing assy.
Hope that helps!
Aug 23, 2011 | Canon imageCLASS D1150 All-In-One Laser...
Printing a large black streak of toner on rt side of page
Hello! Malik Muhammad Mehran Here... your problem solution is that you must replace the cleaning plates in the cartridge...
Mar 28, 2010 | HP LaserJet 6L Printer
Streaks and black spots on printed pages
Try cleaning the laser lens using the laser lens cleaning wand. However, it is likely that your black cartridge needs to be replaced based on the troubleshooting from the Minolta manual. Sorry,
Mar 22, 2010 | Konica Minolta magicolor 5430 DL Laser...
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Cannon mp530 series
you need to clean your heads
Mar 03, 2009 | Cannon MULTIPASS C530 Printer
Refilling Cannon 106 cartrige streaks on page.
when you start using refill kits they messup you machine you will need to use the oem toner for the canon good luck canon sr tech
Jan 22, 2009 | Office Equipment & Supplies
Our Cannon MP 500 is leaving a 1/4" wide black streak on the back side of copies. I have cleaned off the cartridge heads, replaced the ink tanks cleaned the heads to no avail. What is the problem and how...
HI Foster,
The problem is not with the print head. Print a blank page and if you are still getting the streak. Something is probably trapped in the printer or the rollers are dirty.
Rgds
S88
Dec 19, 2008 | Canon Pixma MP500 All-In-One InkJet...
2 Missing ink black streaks
Check the dev unit for missing lines. Also clean the laser glass with the supplied cleaner pad - though if the problem were caused by toner on the lens, there would be gaps in ALL colours.
Check the dev units first. You can also do a stop test whilst a full colour test image is half way through printing and see if the lines are missing off the image on the PCU as well.
May 20, 2008 | Epson Aculaser C1100 Printer
Minolta 2300DL Printer - black streaks
you will have to check the Minolta web tech support team for this one.
May 20, 2007 | Minolta QMS 2200DL Laser Printer
1,017 people viewed this question
jasbo
jasbo
