my ariston a1636s is not finishing a cycle and there is always water on the floor and the machine just stops. where is the filter in the machine as i do not hace a manual to find it. when u open the machine how do i know where to find it. any suggestions greatly appreciated lisa
Comments:
Nov 17, 2008
- thank u will try that
Nov 18, 2008
- filter not in front of machine where is it
Nov 19, 2008
- hi there dad fixed that for me but now its sticking on a cycle, the pipe was blocked so i cleaned that out, i prob have to contact an engineer now
most Ariston machines have a filter behind the kick plate at front bottom of machine. Before un-screwing drain machine by lowering drain hose into a bowl or bucket. if filter is not there get back to me for other options.
Comments:
Nov 18, 2008
- Ok now it gets a bit tricky. There is no filter so you will have to take the pipe off the pump &check pipe & pump for obstructions. If you tilt the machine back & look under you will see a large pipe coming from drum to pump. you need to disconnect this at the pump. This is easier if pump is removed from frame by undoing the screws that hold it. Dont forget to drain machine first as described earlier. Let me know how you get on plz. pete
Was this helpful?
Yes
No
Popular Solutions for Ariston Technologies AWD121WH
hi i have a ariston boiler he mffi 24 microgenius the problem is that i cant seem to set the wired...
(More)
hi i have a ariston boiler he mffi 24 microgenius the problem is that i cant seem to set the wired temperature gauge it works but i cant setup desired temperature it switches the boiler on but the boiler runs in high temperature around 80 mark.
My Ariston Margherita AWD 12 washer/dryer will light up as though a dryer programme has been...
(More)
My Ariston Margherita AWD 12 washer/dryer will light up as though a dryer programme has been selected,no such setting has been selected.can the programmer be "re-booted"
problem with ariston a1436: 1.) wash cycle is not complete. 2) with water coming out from the soap...
(More)
problem with ariston a1436: 1.) wash cycle is not complete. 2) with water coming out from the soap draw. Any help?
I have an Ariston AWD121 washer/dryer combo. When I run a dry cycle, the clothes come out soaking...
(More)
I have an Ariston AWD121 washer/dryer combo. When I run a dry cycle, the clothes come out soaking wet. Wash cycle runs fine-- it drains like it should. It looks like somehow water is incorporated during the dry cycle, whether I run it by itself or after a wash cycle. How do I fix this?
