Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Blue color is now Green
My TV has just started acting up,i was watching soccer match and noticed the blue jersey of the soccer team had gone green,please could anyone help with this problem,before i call someone in to fix. Thanks.
Are you using a cable box / dish network etc reciever? Does it have 3 component video cables (red, green and blue cables). Often times color problems like that are a result of your cables coming loose out of the set or cable box. Make sure that they are snug and secure and in the correct spots on both the reciever and the television. Don't just assume they are, make sure to check all of the cables. I am a television repairman and even though I tell everyone this, at least once a week I have a call where this is the problem.
Posted on Dec 05, 2006
  • Steve Mocadlo Mar 10, 2011
    I know this was posted 4 years ago but I had this problem today. Sure enough it was the cables. Thank You for this info. It stopped me from going crazy.
  • 65 Answers
If your onscreen display looks green ie the menu from the tv call sony immediately and tell them you want the light engine replaced under warranty do not hesitate
Posted on Dec 09, 2006
My zipper broke
Try and put some candle wax on the zip to lubricate it.
Jan 09, 2015 | Adidas Soccer Jersey: Radamel Falcao...
Hi,,i only see two colors on my tv screen,blue and white,,waht should i do..please help me
there are three primary colors from your TV's chroma circuit, red green and blue..
you'll notice it when you open your back cover of your television set, the wire colored red, green and blue.. you better leave it to the expert technician to prevent severe damage
Sep 15, 2011 | Sharp 27F543 TV
My TV works fine. The only problem is that when i'm watching a movie, or playing PS3 the field seems dark. Sometimes is FIFA Soccer, in the shadow, i can't even see my players because of the dark...
It is possible that there is a allergy that is growing the blue and green gun, it will not grow in the red gun, and it blocks the video and makes it look dark, on the greenish side. To fix the problem, you have to change the coolant in the guns, and then it will look like new again.
Jan 25, 2011 | Toshiba 46H84 46" Rear Projection...
I have a 42" Hitachi HDTV Model Number 43UWX10B which I bought 12 years ago. I was having problems with the color about 2 years ago, and replaced the part, but now I am having similar problems where...
Over time a thin layer of fungi grows over the top of your BLUE CRT preventing light fronm shining through. This causes you to loose the blue color in your set. Check and clean. Also when the back is off your set check to see if your blue CRT is on. If not you may need to replace it.
Aug 14, 2010 | Hitachi 42V710 42" Rear Projection HDTV
Blue colors are now green.
It sounds connections are not matched yet. Make sure connections are green to green, red to red and blue to blue in dvd player and tv are correct.
Try another component video cable.
If problem still exist, test dvd player to any other tv, found ok then component input of this TV is bad, need to get it repaired.
Jan 24, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
After having my dish network upgraded to HD and installed, i notice on my tv now that the green and red colors are not there, predominant on channels like ESPN that use these colors most. I._E.: football...
Sounds like one of the cables got plugged in wrong.
Look at the back of the HD box and there should be a cable with 5 ends on it (Green,Blue,Red, White and Red).
Often times a flashlight can help make sure you see the colors clearly.
The Green,Blue and one of the Reds is for video. The White and other red are for Audio.
When you unplug the connector the connection it is attached to is also colored. Check to make sure the colors on the cord match the color they are connected to at the box.
The most common mistakes connecting these cables are:
1) Crossing the Green and the Blue cables.
2) Connecting the Red Audio cable to the Red Video connection.
If all of the connections match the correct colors find the same cable where it plugs into the back of the TV and check these connections that they are correct.
When you find and move the cable to the correct connection this should clear up your color and you can begin to enjoy your new toys....
Good Luck....
Jan 15, 2010 | Panasonic CT-34WX54 34" TV
My tv is showing blue when i turn it on i think my blue projector light is out?
i have a mitsubishi vs-60111 when i watch the tv as of last week the color is pale like green color or green,gray color the picture is sharp yet , i took front cover off the lights are still bright red , green and blue what can be the problem / joe
Nov 06, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Blue crt shot
The coolant in the blue tube has no doubt congealed to an oatmeal like consistancy. Did you notice things like blue halos around things for some period of times. change the coolant. that should correct the blue. this is a common thing for that model as well as all TVs. Blue and green has this happen, Red seems to not have the same trait.
Mar 20, 2008 | Philips 55PW9363 55" Rear Projection...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
59 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
