Monitor display i have cleaned the button but no any improvement and also cheeked by digital multimeter all are correct.please give other option to solve this problem.also only contrast menu pop up and goes up to100 and does exit by any menu button.
  • pankaj8lcet Mar 12, 2009
    yes one of the button was faulty. I opened the monitor and disconnected that button. Now its fine except that particular button is not working. But my monitor will survive without that button. Thanks
    Brigadier General:
  • 6,966 Answers
Hi again,
Appreciate the direct "Ask Me".
A suggestion, to verify if the buttons are the culprit/faulty, why not temporarily removed them or whichever is erring or cover the contacts with paper or tape. If problem is gone, verified that it is the button; if problem persists, then it is the logic controller (D/A) converter.
Posted on Nov 17, 2008
My display screen reverted lol how do I correct it please
Try either of the followings if you are Windows 7 user:
1. (For built in display) Right clk on the desktop screen and point to "Graphic options". You will see a drop down list where you can find "Rotation". Point to that "Rotation" and you will find the "Rotation" options.
2. (Seperate monitor) If you or someone accidentally or intentionally click on the monitor "Menu" button. You will have to find that on the monitor's "Menu" and locate the reverse display option and correct it. Since monitor differs from one another, I can't give to the exact button to press :). Good luck
Aug 08, 2013 | Computers & Internet
Unlock ford car radio. have code.
can you give the number or name of the model
Apr 05, 2008 | Car Audio & Video
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
My prints are coming out with Horizontal lines on them. What can I do to rectify this problem?
Please try this approach:
  1. On the printer operator panel, press Options repeatedly until Cartridges appears.
  2. Press the right arrow button until Clean appears on the display.
  3. Press Select. A nozzle page prints forcing ink through the nozzles to the clogged nozzles.
  4. Print your document again to verify that the print quality has improved. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
Aug 21, 2011 | Lexmark X5150 All-In-One InkJet Printer
While i am opening the system i am gtting in monitor control menu is locked ,how i hve to un lock it pls give some tips
Maybe the problem is in your control panel (where the buttons are located) maybe one of the buttons are in normally close state, where in the button is already pressed.first check the buttons use a multimeter to check a good push button reading when not press is 0L in digital multimeter while in analog the reading you get is nothing. and when the buttons is pressed the reading must be 000 it means that the button is good. Try to replace a new push button or buttons. Hope this may help
Aug 06, 2011 | Dell E771MM 17" CRT Monitor
Printer window displays in foreign language. need english. pages come out blank.
  1. From the main menu, use the left and right Arrow buttons to scroll to Setup.
  2. Press the Select button .
  3. Press the right Arrow button until the heading you want appears on the display, and then press the Select button .
  4. Use the left and right Arrow buttons to scroll through the available menu items.
  5. When the setting (language) you want appears on the display, press the Select button to save the setting or enter the submenu.
  6. For Blank printout:Ensure you installed the ink cartridges correctly and removed the sticker and tape from each cartridge.
Clean the cartridges:
To clean the ink cartridges from the operator panel:
  1. Load plain paper. .
  2. From the main menu, use the left and right Arrow buttons to scroll to Maintenance.
  3. Press the Select button .
  4. Use the left and right Arrow buttons to scroll to Clean Cartridges.
  5. Press the Select button .
The cleaning page prints. You may discard the cleaning page when printing is complete.
To clean the ink cartridge nozzles:
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Clean Print Cartridges.
  1. If the print quality has not improved, click Clean Again.
  2. Print your document again to verify the improved print quality.
If you are still not satisfied with the print quality, wipe the ink cartridge nozzles, and then print your document again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 20, 2011 | Dell 946 All-In-One InkJet Printer
Monitor continuously displays the menu option
click on the monitor menu button and change settings after save and exit.
Jul 09, 2009 | HP mx705 17" CRT Monitor
Screen shrunk
Try using the 'degauss' option of your monitor. It should be in the on screen menu, or possibly a reserved button for it. If not, you may have the options in your menu for the monitor to adjust the shape of the screen manually, you'll just have to go through the menues carefully using the various buttons on your monitor. If nothing fixes it, I would just replace the unit, as repairing it would likely cost more than buying a new one.
May 07, 2009 | Compaq 7500 17" CRT Monitor
CRT MONITOR display
It sounds like this monitor may have what's called the "Windex syndrome" in TV repairs. If someone cleans the screen with a spray cleaner and it drips down the face, it can get onto the circuit board and cause intermittent button troubles. Sometimes it's possible to clean off the corrosion from that area, but the most reliable fix is to clean the board, replace the switches, and remove, check and if necessary replace any resistors connecting to the switches.
Nov 18, 2008 | HP Compaq FS7600 17" CRT Monitor
Computers & Internet Logo
464 people viewed this question
Alun Cox
David Payne
David Payne
