Question about Health & Beauty
Spider nebulizer 2.how to piece together
Hi i need some help to try and get the pieces to fit on my nebulizer can anyone tell me how they go togther .i have the paper showing hoe to put together but its for a diffirent kind of nebulizer ..thank you
  • 74 Answers
The long tubing should have a green end and a blue end. (If both ends are the same it does'nt matter) Now the little cup that holds the medication...look at the bottom of the cup. It should have a male connector (blue or green) take the end of the tubing that matches the color of the male connection and firmly plug them together. Hold the chamber/cup upright. If your unit has a little plastic diffusor, drop that inside the chamber. now locate the top af the chamber and screw it on. You should have a large whole the size of a nickle on top. This is where you squeeze the medication in. After putting in the medication put the mask(or mouthpeice) Firmly into the place where you put the medication into....and your peices should be assembled. Last thing is to plug the other end of the tubing into the machine itself and then turn on the power.
Posted on Dec 23, 2008
Need reassembly instrucstions on American Standard ToeTap Drain
buy another one and use it as a model to put yours back together then take it back for a refund.
Dec 24, 2013 | American Standard Plumbing
Where do you load the inhalation solution?
You may have already figured this out by this time, but figured that others could have the same question. Here's a simplified explanation on how to assemble and use the nebulizer. I apologize if the explanation sounds patronizing. I'm not sure of what you may or may not understand about the nebulizer, so I'm explaining as though you don't understand it. I'd rather someone explain something in a patronizing way, than assume I have knowledge that I actually don't. At least with the former, it's easier for me to ensure my questions are answered. I also apologize for my ADHD. It often cause me to write much more than is necessary or overexplain things.
There should be two pieces that screw together to make the reservoir.
Piece #1 is the male side/bottom side and may or may not have a green cone inside. If not, there are still a plastic piece inside that forms a cone shape. This side should also have a small plastic cylinder shape on the bottom. This is where one side of the supply tube should be attached.
Piece #2 is the female side and has a larger cylinder shape on the top. When the piece is turned on its side, it sort of resembles a flashlight. This is what the breathing apparatus is attached to. You attach the tee adapter to the tube side of it. Then you attach the mouthpiece to whichever of the tee sides it fits best. Once this is all assembled, attach the other end of the supply tube to the nebulizer.
Now, back to your question. Open the reservoir, pour the solution into Piece #1, then screw Piece #2 back on. It should only take a second or two for the steam to begin flowing through the breathing apparatus once you turn the nebulizer on. Also make sure the the supply tube is attached securely to both the nebulizer and the reservoir so it doesn't pop off. Now you're ready to begin.
If you start coughing during treatment, that's fine. Don't remove it from your mouth or stop treatment. My mom was my son's pediatric nurse and trained us on its use. She said that if you start coughing during treatment, that actually helps you to inhale even more of the solution which is beneficial..
Aug 02, 2013 | Salter Labs 8900 Series Small Volume Jet...
The baffle part of our Omron Nebulizer is broken could you please tell if we can get the same from somewhere in market or if the complete Nebulizer kit is available??
You can use pretty much any nebulizer kit (try the brand salter, item#8900), this is a universal kit and fits most nebs, I have not seen Omron offer the baffle piece seperate of a new kit (or new neb). Your local pharmacy (Walgreens in my area) sells the kits, or check with the provider that gave you the unit.
Jan 24, 2011 | Omron Health & Beauty
Button from laptop pulled off..need quick fix!!!!!!
The pieces snap into place if you place them correctly on the keyboard and press down until you hear them click together. You may need to pry one off to see the orientation of the white plastic piece that goes on first. Lay the piece like the one you just looked at and firmly press the key evenly on top of it until you hear the click sound. You may have to rock it a little to get it to fully engage. If it sticks down, take a paper click and gently pry it up and it should work fine.
Feb 08, 2010 | HP Compaq Evo N800v Notebook
Can you tell me how to fit 1989 gpx750 airbox, i am having trouble fitting it in frame. thanks.
You have do dissasamble it first, it is actualy made of 2 pieces, hold together by screws.
You put the big piece into place first, then the smaller one, than the screws.
Aug 01, 2009 | 1989 kawasaki GPX 750 R
Mysterious metal piece under vacuum motor?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fdgf
May 07, 2009 | Bissell 8910 ProHeat Clear View Upright...
BROKEN MOUNT
WITHOUT KNOWING EXACTLY WHAT AND WHERE THE BREAK IS, HERE IS A POSSIBLE SOLUTION. EPOXY IS AN EXTREAMLY GOOD BONDING AGENT FOR PUTTING TWO PIECES BACK TOGTHER, SECURELY. AN EPOXY PRODUCT CALLED "J-B WELD" WHICH COMES IN TWO [2] SMALL TUBES BOUGHT LOCALLY AT HARDWARE STORES CAN BE USED TO BOND THE TWO BROKEN PIECES BACK TOGETHER...FOREVER. FOLLOW THE DIRECTIONS FOR MIXING, APPLY TO PIECES, CLAMP TOGETHER PIECES AND LET LET OVERNIGHT. WIPE OFF/CLEAN EXCESS EPOXY BEFORE IT SETS UP. THE NEXT DAY, DRESS UP THE AREA AS NEEDED FOR LOOKS AND OR FUNCTION. HOPE THIS HELPS.
Jul 28, 2008 | Meade Polaris 114EQ-D (36 x 114mm)...
Fell apart..help please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Jun 21, 2008 | Conair GMT182CS
Health & Beauty Logo
853 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
