Question about Water Heaters
Electric water heater will not stay on
I have a truma gas/electric water heater in my caravan, a problem occurs when the boiler is charged with water, when you turn on the electric water heater it brings the tank up to the temperature, (50C) once water is used (not all) the water will not heat up again untill i switch off the boiler for 5/10 minutes and it then heats up again, i have to perform this procedure all over again. no problem with the gas opperation. i have dusted the control board and cheaked the fue, fine, i,m at a loss as what to do.
    Problem Solver:
  • 17 Answers
Sounds like the electrical thermostat is defective and is being over ridden by the overheat safety stat.
Posted on Nov 29, 2008
Can I use a Truma hot water heater on gas in my shed kitchen for washing up?
I just looked on the website which contains a remark there is only approval for installations for campervans and caravans.
Nowhere in the description or specifications does it mention a flue or ventilation requirement which is very surprising because burning gas needs a good supply of fresh air and produces poisonous gases that must be got rid of/vented to the exterior.
I guess you could use your heater as long as the requirements of an adequate fresh air supply and the venting of combustion gases is taken care of...
Sep 10, 2017 | Water Water Heaters
Truma Ultra store water heater. How ti hard wire from 230volts. Many Thanks awaiting reply ?
There may be a wiring diagram pasted somewhere on the heater. If not, request the diagram directly from Truma.
Aug 27, 2017 | Water Water Heaters
Truma c 3402 water boiler
Sounds like a bad Relay on the control board
Mar 17, 2016 | Water Water Heaters
No hot water
10-22-12
Copy following links to help identify product and download possible troubleshoot resources:
Tank-type gas
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Tank-type electric:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Rheem tankless:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Other types of water heaters include boiler, tankless electric, indirect, solar-assisted, solar, hybrid electric, heat pump, wood-burning, gas hybrid, 3-phase commercial electric.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 21, 2012 | Rheem Water Heaters
Water gets to hot even when turned down all the way thus opening pressure release valve
I can get you started but might need more information.
Do you have tank-type electric or gas water heater?
Or indirect heater, or boiler, or tankless, or condensing, or under-counter?
If you have ordinary tank-type electric water heater, the thermostat is probably bad.
Replace thermostat(s)
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If you have ordinary tank-type gas water heater, then thermostat can be bad, and thermostat is located on the gas control valve
http://waterheatertimer.org/images/Typical-gas-valve-300.jpg
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 25, 2011 | RELIANCE ELECTRIC WATER HEATER
Water Heaters Logo
680 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
