Question about Universal Remote Control Remote Control
The volume control won't work on my sky remote
Toshiba tv with panasonic digibox,
  • jarienqvist Feb 04, 2009
    I have a panasonic TU-CT 20 E digibox and problem remote control volume and text-tv don`t work
  • ringandrosey Apr 02, 2009
    The volume and mute button wont work on my sky remote.Any body know what to do?
The volume dosn t work on my sky remote control what do i do
Posted on May 11, 2010
  • 27 Answers
For a toshiba tv,
press tv
press and hold select and red until the led blinks twice
type in 0 1 5 6
press the power button on the remote
If the tv turns off press select and hey presto you're done, if the tv doesn't turn off, press tv then press the power button and keep doing this until the tv turns off. When the tv turns off press select.
Posted on Apr 04, 2009
Hello i contacted you last week regarding a sound and channel changing issue with my tv. Sadly this issue has not bern resolved. I have a toshiba text tv and it,s connected to a hitachi digibox as i only...
Annamaria:
It sounds like you have not yet simply married your TV to your digibox (which I assume is a cable box) with the proper code. Go to Hitachi.com for the code.
Apr 11, 2017 | Televison & Video
What other devices do I need to make my toshiba 35A44 tv work
It needs to be a digital antennae and digibox,then go on digibox and scan for channels
Aug 23, 2012 | Toshiba 35A44 35" TV
Need a user manual for panasonic sky digibox
Here is the online pdf manual for the Sky Digibox
There's also this one that is valid for all makes of the SkyBox if that one doesn't work.
May 07, 2011 | Panasonic Cameras
How to setup Toshiba CT824 tv with digibox (I have no user manual)
You can connect the digibox (digital converter box) or DTA to the TV using coax jumpers and tuning the TV set to channel 3 or 4 in some cases.
Connect the input (wire from the wall or floor) to the input on the digital box.
Connect the output of the digital box to the input of the TV set.
Turn on TV and digital box, tune TV to channel 3 using the TV remote or the buttons on the TV itself.
Use the digital box remote to change channels. You may need a code to program the remote to work the TV set.
I hope this helped.
Cheers!
Apr 27, 2010 | Televison & Video
How do you fit a two way booster to a digibox and a tv?
Hello. When you boost the signal to the digibox it will also boost it to the tv. So just install it in the incoming line before the digibox. 10412402.jpg
Jan 25, 2010 | Televison & Video
Picture jerks like robotic .its ok on arial only the prob occurs when digibox turned on?
is electrical problems on digibox or tv, use the same power source (plug), and use good top quality cables bettween tv and digibox.
Jan 17, 2010 | Televison & Video
Panasonic digibox tu-ct20 has all stations mixed up since the retune . worked perfectly well untill then.even tried the shipping reset .no luck.
Just had the same problem with a Panasonic digibox whilst trying to fix a customers tv. The only way I can see to unmix them is to use Profile menu to create a new Profile and manually add the channels one-by-one to the new profile, or replace the digibox. I suggested to the customer best solution - replace digibox as they are cheap enough now.
Oct 20, 2009 | Panasonic Televison & Video
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
New sky digibox fitted. Cannot timer record satellite programmes
I encountered a similar problem when recording and I phoned Sky and they changed my settings to eliminate standby mode for me.
No problem any more.
Mar 21, 2009 | Panasonic Televison & Video
Panasonic home Theatre
You need to obtain audio leads and connect from home theatre directly to audio input in back of tv - be careful as there are normally 2 in back of tv
Dec 14, 2007 | Panasonic SC-HT720 System
Universal Remote Control Remote Control Logo
3,775 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
