Monitor display i have gone throgh the idea you suggested. i checked the buttons and cleaned it. Actually contrast menu pops up and it goes to max. that is 100. and remains there whatever u does. . Thanks in advance
    Brigadier General:
  • 6,966 Answers
Hi again,
Appreciate the direct "Ask Me".
A suggestion, to verify if the buttons are the culprit/faulty, why not temporarily removed them or whichever is erring or cover the contacts with paper or tape. If problem is gone, verified that it is the button; if problem persists, then it is the logic controller (D/A) converter.
Posted on Nov 17, 2008
Pc monitor "menu" pops up on screen
Probably got over zealous with your cleaning liquid and it has destroyed the key pad behind.
Apr 08, 2017 | Computers & Internet
Contrast/Brightness Menu repeatedly pops on screen/won't go away
What kind of system do you have there? Regular PC + monitor or All-in-one/Laptop?
Dec 30, 2017 | Dell E172FP 17" LCD Flat Panel Monitor
My monitor pops up the contrast menu without doing anything.
Actually the button for setting the contrast is a bit loose thats why whenever their is a **** os little movement in the moniter opf ur PC then the contrast button get pressed automatically and the pop up comes up
Sep 07, 2009 | ViewSonic VA721 17" LCD Monitor
Brightness/contrast menu popup
Sound like either the button is stuck or the display is in error.
press and wiggle the buttons carefully, and disconnect the power to the display.
Feb 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
CRT MONITOR display
It sounds like this monitor may have what's called the "Windex syndrome" in TV repairs. If someone cleans the screen with a spray cleaner and it drips down the face, it can get onto the circuit board and cause intermittent button troubles. Sometimes it's possible to clean off the corrosion from that area, but the most reliable fix is to clean the board, replace the switches, and remove, check and if necessary replace any resistors connecting to the switches.
Nov 18, 2008 | HP Compaq FS7600 17" CRT Monitor
Monitor display
Hi again,
Nov 17, 2008 | Computers & Internet
Contrast Menu appears after switch On
Contrast Menu appears after switch...
Jan 02, 2008 | Philips Standard 105S Monitor
Monitor display problem
It seems that your menu switch is short. If you can open up the Monitor check out the connection of your switch and the related components, clean with Spirit or alchohol, check out the switches, if found faultty replace it. That should solve the problem. Good luck.
Dec 05, 2007 | Relisys TL 700A (White) 17" LCD Monitor
Menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Nov 04, 2007 | Acer AL1912 19" LCD Monitor
IBM MONITOR ON SCREEN DISPLAY
This is a problem in the monitor itself. The computer has absolutely no control over the On Screen Display. Most likely the button that controls contrast is stuck. You might try blasting the button with canned air. Sounds like it might be time to buy a new or used monitor.
Jul 31, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Computers & Internet Logo
498 people viewed this question
Alun Cox
David Payne
David Payne
