Question about iRiver H10 MP3 Player
System Initializing Problem
Someone has posted the same problem but there wasn't a solution for it. I have an H10 iriver and it's been working fine. I was just syncing music onto it from my computer and when I unhooked it, it frooze. I reset it, then it started up, but it stays on the 'system initializing, please wait...' screen forever! I've tried charging the battery and hitting the reset button numerous times but nothing works. Please help me!
  • Anonymous Jul 05, 2008
I had the same problem. Solution 2: Running EasyH10 from Sourceforge.net worked. To add to the solution you must run the mp3 player in Emergency mode (reset device, hold power button and button with circle on it, enter button I think). Let computer detect the H10, then run the software. At the bottom of the EasyH10 screen, select model/firmware and device location letter (i.e E:\). Click OK. The screen will display info about the device and run through the database of music. Once complete your device should work like new now.
Posted on Jun 13, 2007
Where do i go on sourceforce.net
Posted on Jun 25, 2008
How do you format?
Posted on Jun 22, 2008
Format, make sure you use "recovery" not "reinstall" and it worked for me. You'll lose all your music, but at least it'll work again.
Posted on Jun 20, 2008
    Problem Solver:
  • 10 Answers
Scoobz is the man thank you so much!!!!!!!!!!!!!! :)
Posted on Apr 11, 2008
Format and run an update maybe
Posted on Aug 05, 2007
Run EasyH10 on it
Posted on Jun 07, 2007
    Problem Solver:
  • 8 Answers
Try reinstalling firmware from iriver site
Posted on Apr 22, 2007
My iRiver H-10 when I sync music from my library (pc)doesn't work because:sync your device to your pc appears ! What's this ?
Try to reconnect to the computer after updating the software/ firmware in the H10.
Here is for the Iriver H10 software:
http://iriverinc.com/support/hd/h10_5-6gb.aspx
Apr 23, 2009 | iRiver H10 MP3 Player
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Take out the battery, wait a second, and put the battery back in.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For 20 GB MTP Models
  • Poke the "reset" button with a paperclip.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
Vista will not recognize iRiver H10 MP3 player
Try plugging in usb with the H10 turned off. Now, press the select button (with the round symbol on it) while turning the H10 on. This starts the player in 'emergency mode' and should be recognized by XP
Jan 08, 2009 | iRiver H10 MP3 Player
My iriver wont sync with WMP
try bringing your music up as a file normally it works cause with a lot of devices that's the only way you can send them so bring your music up as files then open your i river as files then all you have to to do is copy and paste
Oct 11, 2008 | iRiver H10 MP3 Player
same problem with mine...i tried to use rockbock firmware...it works but you have to be patient...you have to reset it time and time again before it works....it still works anyways rather than the iriver firmware...
Jul 12, 2008 | iRiver H10 MP3 Player
Syncing Problems
sounds like your hard drive is shot, these players are not made to handle much, may not be an expensive fix
Mar 22, 2008 | iRiver H10 MP3 Player
I have no idea what to do! help!
To sync your device use either winamp or Iriver plus (winamp is better)
-Download winamp from http://www.winamp.com/player
-Iriver plus http://www.iriver.com/support/down_view.asp?idx=860
All firmware releases for your H10 can be found at: http://www.iriver.com/product/p_detail.asp?pidx=61
Jan 05, 2008 | iRiver H10 MP3 Player
Iriver H10 V's Vista
Just to let everyone know I have the H10 6Gb player and the reason your having problems getting the H10 to work with Vista is because it isn't supported by Vista at all even with updating your firmware...
Dec 23, 2007 | iRiver H10 MP3 Player
Sync itunes to Iriver h10
well itunes only works with the ipod for syncing music, windows media player 10 and 11 is where you would sync you music i would add your music to the media player library and go from there
Jun 29, 2007 | iRiver H10 MP3 Player
I can't hear any music
Replace - cannot be repaired
Dec 14, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
588 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
