Question about Smeg DWD612C Built-in Dishwasher
Smeg leak device activated
Until recently my Smeg DI612C has been working fine. The warrenty has just run out and now it seems that it can no longer recognise the wash cycle. After starting fine, pre-rinsing, it then ends and bleeps continuously, it seems to miss out the actual wash cycle, the wash tablets remsins and the water is still cold.. According to my manual the light that flashes means the machine has been tripped due to leaking. I have taken out and turned it 90 degrees, cleaned the water out and checked the pipes, but still it just does half a cycle and then bleeps continually. Can anyone help me, Many Thanks Mike
4 Suggested Answers
  • 247 Answers
SOURCE: smeg dishwasher
The second problem is almost certainly a symptom of the first - leaking water is reaching some of the electrical terminals and shorting them to earth.
First thing to do is to make sure the strainer in the bottom of the cabinet is clear - if it's really badly choked, you can brew up quite a spectacular flood.
After that, best I can suggest is to move the machine onto a piece of dry carpet, run it for a short while and see whereabouts the carpet gets wet first. Use this to guide your subsequent leak-hunting.
If there's any hint that the leak is from the front of the machine, check the seal between the lower edge of the door and the bottom of the washing chamber. On some machines, this gets covered with a thick layer of hardened grease (which is fine, until bits of the grease start to break off). If this is your problem, scrape the remaining gunge off, give the metal surface a good clean,and expect the last vestiges of the leak to cure over the next couple of washes as the seal recovers its proper shape.
Next thing to look for is the device which senses when the machine is full enough (and tells it to stop filling). Let the machine get to the stage when it is leaking nicely, then turn it off, open the door, and see if the cabinet has filled to overflowing. If it has, then drain it, then unplug the machine and take the back cover off. Look for a thin hose coming out the bottom of the washing chamber and running up to a small unit mounted on the case some way up with a pair of wires going to it. Check this hose for cuts, splits and blockage.
If the leak is coming from further back, then you are going to need to look inside to see how much of the inside of it is wet. Use this to guide you to where you need to do a more detailed inspection.
Check all the nearby hoses, looking for splits - especially where they push onto fittings, cuts (especially anywhere they're pulled over sharp edges) and just generally to see if they've pulled off completely.
Next, check any plastic fittings in the area to make sure they haven't cracked, and look to see if there's any evidence of water seeping out of the joints between the different fittings (in case you've blown an O ring, rotted a gasket away, or just had some screw work loose)
Posted on Apr 13, 2008
  • 1462 Answers
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Posted on Jul 18, 2008
SOURCE: SMEG DI 612CA. Dishwasher
Pisss!!! Comin from my asss!!
Posted on Jul 24, 2008
  • 750 Answers
SOURCE: Smeg Dishwasher DI612C
Hello Friend,
Welcome to fixya.
I'm Huuum and happy to assist you,
Try this remedy.
When we have an error code this is the remedy.
This can reset the system.
First turn it off.
Cut power to the washer at the breaker and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Write back right away and let me know that it worked and solved the problem .
Bless You
Please remember to enter a rating here when you finish!
How old is the appliance?
Here is an interesting report I just read.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Bless You
Posted on Sep 23, 2008
0 characters
1 Points
How do you reset a smeg DI612C dishwasher?
Just unplug or kill power for about 10 minutes. see what that does but you may have another issue. see if water fills into unit. Also check flod switch for debris
Feb 17, 2013 | Smeg Dishwashers
My smeg dishwasher seems to be permanently in wash mode. The light on the menu of settings no longer flashes, but permanently is on, and when I run a load it never stops. I hear the two beeps as if the...
You have a timer relay issue ,probable need a new board for it ,a cheap fix would be to time it and see how long it take to run full cycle and put a regulaer outlet timer on it or a alarm off your stove or what ever,save a couple of bucks
Feb 16, 2011 | Smeg STX2 Dishwashers
My Kenmore portable dishwasher quit working in the middle of the wash cycle. It has power going in, but no longer runs at all. I need a service manual or a troubleshooting guide. Is there a circuit breaker...
This seems to be that the Anti Flood system has triggered. This device detects water leaks / spills to the bottom of the washer and automatically puts the washer in pump out mode and shuts off the water inlet. The device is made up of a pollystireene float and micro switch that activates once the float detects any leaks / spillage. Dry water and check for leaks and this should solve the problem
Jan 23, 2010 | Dishwashers
Bosch SHU43C installed in 2003
My Bosch SHU43C had the same exact problem. I found the below solution on this site. Perhaps you already seen it.
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Aug 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher stops after rinse
Seems to be an error with the float switch on the anti flood device
Apr 18, 2008 | Smeg 24 in. STX2 Built-in Dishwasher
Smeg dishwasher
my hotpoint dish washer aquarius is 4 years old leaves a sandy grit all over dishes water not spraying the top,done all the usual stuff run out of ideas
Mar 09, 2008 | Dishwashers
Mar 04, 2008 | Smeg Dishwashers
"E 1 code error
The fault is that the anti flood device is activating, you have a leak somewhere in the base of machine. Regards Engineer
Aug 05, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
We have a Smeg SA8605W which has had a similar problem 3 times in its short 3 month life. The problem with ours is that the control panel on the front pushes against a very brittle plastic frame to activate the micro switches. Because of the brittle nature the 'fingers' of plastic break off and either get stuck holding the machine in a set cycle or break off fully so nothing functions. Gaffa tape or Elastoplast is a simple solution.
Nov 08, 2006 | Smeg CSU2001 Built-in Dishwasher
Smeg DWD612C Built-in Dishwasher Logo
52 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Level 1 Expert
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
