Question about Microsoft Windows XP Home Edition
Power save mode problem -- during the PC boot up
My OS is WindowsXP pro with SP3. My husband has installed a "Screen saver" couple days ago, and it was worked well; but today, after he didn't use the computer for 3~4 hours, the screen doesn't turn on any more. He told me he did some change of the application setting. I tried to clean COMS, but it didn't work for me. The MB is MSI 661FM(MS-6540G). Could you please give any advice, please?
Thank you in advance.
P.S. I am sure my power supply, memory board, CPU, HDD, and VGA are working functionally.
  • yuenij Nov 17, 2008
    Hello Geekman,
    Thank you very much for the quick replying.
    It is my fail for the unclear case description of my problem.
    My situation was:
    When the front power switch is turned on > the power led is turned to green and the HDD led is turned to red (stay in red, no blinking at all), also I can hear the normal "monitor turn on sound" when I turned on the monitor; but the screen only shows a message box of "the display is in the power save mode" (the background is black and after about 5 seconds later, the monitor power led is turned yellow) and no any boot up message (such as bios data, memory check, hardware check etc.), even one letter is appeared on the screen.
    BTW, I have noticed that if the monitor power was turned on before the mid tower was turned on, the monitor led won't turn to green, it will stay on yellow and no any message appear.
    For the troubleshooting, I have done:
    First, make sure every hardware device is working functionally by installing movable device to another computer. And I installed another working graphic card instead using on board graphic card. After that, I have:
    Scenario 1: press and hold the 'Del' key right after I pressed front power switch --> black screen and no any letter appears on the screen, after about 10~15 seconds, the 'power save mode' message is appeared, then 5 seconds later, the monitor power led is turned to yellow.
    Scenario 2: press and hold the 'Insert' key right after I pressed front power switch
    --> black screen and no any letter shows up, after about 15 seconds,
    the 'power save mode' message shows off, 5 seconds later, the monitor power led is turned yellow.
    Scenario 3: press and hold the 'F8' key right after I pressed front power switch
    the 'power save mode' message shows off, , 5 seconds later, the monitor power led is turned yellow.
    Scenario 4: Clear COMS
    Step 1: Disconnect the main AC power by pulling out the
    power cable.
    Step 2: Wait for 1 minute to be sure all the capacitors and coils have discharged.
    Step 3: Move
    the CMOS jumper to the clear position (moving JBAT1 from it's original 1-2 position to 2-3 position)
    Step 4: Wait for 5 minutes to be sure the CMOS has been cleared.
    Step 5: Return the CMOS jumper to it's original position.
    Step 6: Restore power to the system.
    Still get the same result as the scenario 1~3.
    Had online study, then:
    Scenario 5: Clear COMS
    power cable.
    Step 2: Wait for 5 minutes to be sure all the capacitors and coils have discharged.
    Step 3: remove the battery on the motherboard
    Step 4: Move
    Step 5: Wait for 10 minutes to be sure the CMOS has been cleared.
    Step 6: Return the CMOS jumper to it's original position
    Step 7: Reinstall the battery on the motherboard .
    Step 8: Restore power to the system.
    Still got the black screen as the scenario 1~4.
    Scenario 6: Clear COMS
    power cable.
    Step 2: Wait for 10 minute to be sure all the capacitors and coils have discharged.
    Step 4: Move
    Step 5: Turn on the main AC power (actually the power can't be turned on)
    Step 6: Wait for 10 minutes to be sure the CMOS has been cleared.
    Step 7: Return the CMOS jumper to it's original position
    Step 8: Reinstall the battery on the motherboard .
    Step 9: Restore power to the system.
    Still got the black screen as the scenario 1~5.
    After I did all 6 scenarios, I left all power cables as unplugged to the devices. I wrote this issue and had asleep. It was this morning after 5.
    Thanks,
Hi Geekman,
Thank you very much for the quick follow up. I am very sorry that I couldn't update the issue on time as I was very busy on my work.
My problem was solved even I am not sure what was happened to me.
As I wrote down before, I left my computer disconnected to all power cable (power supply cable and monitor cable) on Nov. 18 at 5 am. This afternoon I connected monitor's power cable and main AC power cable, and turned on main AC power; then the bios check and memory check had appeared on the screen, and also asked for resetting the COMS. After I have reset all parameters, the computer is boot up as before and had the Windows Advance Options Menu (I didn't hit F8). I chose boot as "last knowing ...", after I had the desktop, then I went to Control Panel ... > to switch off the Screen Saver. Now everything is fine. I don't know if the length of the time of the disconnected power was the key point. Until now, I still do not know what is the correct scenario (the exact step by step) of clear COMS. I checked with websites, seems like there are so many different ways to do it (more than four ways). Does this mean every way is correct or can I say COMS can be cleared in any way?
Thank you again,
Posted on Nov 21, 2008
  • Microsoft Master
  • 32,281 Answers
Try and reboot your computer and after Windows opens go to the Control Panel, then to Display then to Screen Saver and select (none).
If you have trouble with booting up Windows, then power off or remove the power chord reconnect it again, As you switch on press F8 several times until you get Windows Advance Options Menu.
Then select Safe Mode then go to Control Panel - Display etc to switch off the Screen Saver.
Posted on Nov 17, 2008
  • Chris Hingee
    Chris Hingee Nov 18, 2008
    You have been very methodical in your problem solving - full marks to you.
    It appears that the problem lies with the monitor, it may be faulty. Try connecting a different monitor to your computer.
    Some monitor functions are controlled by their internal CPU, and these can be access via the buttons on the monitor's front panel. There may be a setting for power saving mode, if you have a manual check it out and/or check their WEB site.
I have a toshiba satellite a205-4707 when i got it it would freeze at startup i had a ancient copy of xp pro sp1 i could only install with power cord unplugged.even after install if i plugged in power cord...
http://www.4shared.com/file/oE15gXll/killdisk_and_boot-cd-iso.html
get this from my shared drive(read instructions in there)
and wipe your disk clean (Warning...this process will make you lose all data on disk so be careful, if posible backup all critical data that you need)
once done install WinXP SP3(get a Windows XP cd from a friend or download a pirated copy from net) look for "WinXP SP3 piratebay" in google
when installing WinXP make more than 2 partitions (C, D, E)
Install WinXP in C
once done, let Windows boot and show Desktop
install WinVista or Win7 in D
use E for saving your critical data
Nov 29, 2010 | Toshiba Satellite A205-S4617 Notebook
I installed anew harddrive(windowsXP 4600c O/S) (...
If you are installing the new OS from the disk drive you have to direct the motherboard to boot from their first. While in system setup (F2) arrow right to the boot sequence menu and toggle the choices till you have cdrom at the top followed by HDD, and finally USB, if there is no diskette drive I would just disable it. Also you can toggle off OS install mode.
May 19, 2010 | Dell Dimension 4600 PC Desktop
Dell screen (1901FP) won't come out of power saver mode
hold down the Fn and F8 keys, and it worked fine for me. or if your problem is you cannot wake from power saving mode (after your PC goes to sleep, then its probably just the driver for your video card). VISTA has some issues with certain drivers that the PC cannot wake from sleep
Sep 24, 2009 | Dell 1901FPt 19" TFT LCD Flat Panel...
Re-installed XP Pro + SP2 + SP3 - but have black screen
reinstall xp and dont install sp2 go to microsoft update and let it install sp3 for you
Sep 23, 2009 | Dell Latitude D600 Notebook
Hp pavilion a1220n shuts dwn after loading hp8500 pr drv xpsp3 os
If you can boot into safe mode, then once in safe mode open system restore and then restore to a couple days prior to the install of the hp drivers. This should fix the problem. If you need to know how to get into system restore let me know your operating system (Vista or XP)
Jun 27, 2009 | HP Pavilion a1220n (A1220NED904AA) PC...
My computer only boots successfully after a forced shutdown.
Is it possible that you have installed winxp twice? You say that you installed XP Pro sp3 was that an upgrade from xp home? if so then you will need to uninstall one or both versions of XP then install only one.. Make sure you backup any important files first though
May 22, 2009 | Microsoft Windows XP Professional SP3 Full...
LG W1952T LCD monitor power save mode during bootup?
called customer service - see other post for details
May 11, 2009 | LG L1915S 19" LCD Monitor
Windows XP Pro SP3 will not boot normal mode
This may be because you have the wrong drivers installed- i reccomend starting your computer up in safe mode and using system restore go back to a past restore point before upgrading to SP3
then update your drivers before upgrading to SP3
i reccomend drivermax.com to update drivers.
Hope i could help
CBZ
Comment if you need more assistance
Apr 27, 2009 | Microsoft Windows XP Professional SP3 Full...
Problems when installing sp2 on my dell 4400
Reboot and keep tapping on F8 into Safe Mode. You can select "Last known good configuration" or continue In safe mode and do a system restore to the day before you installed the SP3. To do a system restore, go to Start, Programs, Accessories, System Tools, System restore. Windows XP SP3 has some issues with certain programs giving the blue screen of death.
Jan 04, 2009 | Dell Dimension 4400 PC Desktop
Full screen probs with netflix
This has nothing to do with Netflix, you would get the same result with any DVD regardless of its origin. Chances are that is the laptop trying to revert to a screen saver or power save mode during the movie.
Check your laptop's power and screen saver settings. If you are experiencing the problem every 3 minutes or so, your screen saver is most likely scheduled to go on after 3 minutes of inactivity. The same goes for your monitor-- it may try to dim or turn off after a certain amount of time.
To change these settings to a longer delay, go to your desktop and right click. Select "Properties". Choose the "screen saver" tab, and change the "wait:" field to a higher number. Or, just turn the screen saver off by selecting "(none)" under the screen saver dropbox. You may also click "Power" and change the time for "turn off monitor" to "never", or a longer amount of time.
Jan 04, 2009 | Toshiba Satellite M115-S3094 Notebook
Microsoft Windows XP Home Edition Logo
832 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
