Question about Ricoh Aficio 2022 Black and White Copier
Ricoh Aficio 2022 not taking pages from the document feeder
I've got a problem where any page put into the document feeder at the top is top being taken for photocopying. Any suggestions - I reckon it may be the sensor that is malfunctioning. Can you confirm this or suggest a solution? Thanks!
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this on the Automatic document feeder where you feed your originals into or is it comming from the paper tray where your blank paper is stored to be printed on?
  • madam Jan 12, 2012
    I'm having the same problem with lanier 5435, seems like a clutch problem and i would replace it myself but finding the parts is a bit tricky. They would like $150 for the first hour of work and thats not even sure they will fix the problem. Essentially it gets past the first sensor, but doesn't switch from the front roller to the back roller and thus the paper just sits there and causes a "paper jam."
  • Ricoh Master
  • 2,794 Answers
Check the feed tires to see if they are smooth at all. Sometimes they need to be replaced. There is a clutch as well in the feed mechanism that could be going out as well.
Posted on Nov 30, 2008
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
When pages come out of the copier the image is printed crooked. The paper comes out straight, so feed is correct. Image is just crooked? Why?
Does this happen when you using the document feeder?? Try placing the original document on the big glass see what happens might be you document feeder needs to be adjusted or the original document is hitting a obstruction in the path as it is being scanned. Does it print OK? Vise copy?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 25, 2016 | Ricoh Aficio 2018D All-In-One Laser...
How to get ricoh aficio 2022 usage
Counter? If you are looking for the counter page press the button with a diamond shape and a 123 icon on it. There you will see a counter, press ok and print and the green button!
Jul 16, 2014 | Ricoh Aficio 2022 Black and White Copier
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Ricoh aficio 2022SP prints black line across middle of page
Remove the OPC unit,clean the charge corona,charge corona grid,clean or change the OPC drum cleaning blade.
Jan 26, 2013 | Ricoh Aficio 2022 Black and White Copier
Hi, we cannot print to the Ricoh Aficio 2022. I have connected to the printer by pinging the IP address of it and it is OK. The 2022 can still photocopy. I have tried a test page and nothing prints.
Are you sure no other device on your network has the same IP address? (Turn the copier off and trying pinging that IP address to make sure.)
Do you have the Ricoh 2022 driver installed? You can download it from Ricoh-USA.com if you don't have it.
Aug 23, 2010 | Ricoh Aficio 2022 Black and White Copier
Ricoh Aficio 1022 Toner Bleeds
I ended up taking out the toner bottle completely and just running copies (with no toner in place) until they came out crisp. This used up the toner that was floating around. I was able to make about 700 copies before I needed to put the toner back in. But a **** of paper is still much cheaper than getting a service tech.
Apr 08, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Document Server issues
The 2022 has a very limited area for storing document in the copier. It has several bugs in it as well if you put them into PDF multi page mode. The best way to store them is to use an ftp server or scan to email. SMP server will work as well.
That way the Documents can be kept off the copier and stored into an area that is easier to organize the data with.
Document server wasn't designed to be a document server for long storage use.
Aug 13, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Operation of Duplex through computers
Go to "start" then "printers and faxes" ( If XP). RIGHT click on your default printer ( Ricoh 2022) select properties, at the top of the screen you will see a tab that says Accesaries" hilight that tab and down on the page that says "duplex" place a check mark where it says duplex. CLICK APPLY or it will not change when you exit.
hope this helps.
gizard
Jun 26, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Copy blank pages
Does it also do this while printing?
Does it do if while using the auto document feeder and the glass or just one of the two?
Does the light come on inside when it scans?
Jan 18, 2008 | Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh Aficio 2022 Black and White Copier Logo
101 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
