Question about RCA RT2380 System
Will not turn on
The red power light remains on when the power is plugged in. However when function buttons are press a "chk spkr" msg on the front panel appears. This all of a sudden happened one day. Help somebody! Calvin
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: chk spkr error message
Your problem is the output IC's The case where you say the speakers buzz tells you theres a short in the audio outputs. If your unit didnt shut off, the speakers would fry and the unit would also smoke. These are solid state devices and are soldered in, and are not concidered user serviceable parts, unless you know how to solder and trouble shoot Stereo systems. This is a job for the pro if you want it fixed. Good Luck
Posted on Jun 22, 2006
tech48
  • 624 Answers
SOURCE: chk spkr
That message means that you have a bad speaker or you have a bad amplifier IC most of the time. The amp circuit could have some other problem, but more times than not it is the amp IC.
How to check if it is the speakers or the amp circuit:
Unplug the speakers and turn it on. if you do not get the error message you have a bad speaker. If you do get the error message you have an internal amp problem. Then start plugging in speakers one at a time. If the unit turns on and stays on for a few minutes, turn it off and then plug in one more speaker. Keep doing this unit the unit gets the error message and when it gets that message you know that the last speaker you plugged in is the bad one.
Now the bad news
RCA no longer sells parts for their audio equipment. When the supply they have on hand right now is gone, thats it, no more RCA parts.
Now the good news.
The amp IC they use is a generic type that you may be able to get from another source.
But that is only good news if the amp IC is bad. It is the likely suspect, but without troubleshooting it on a test bench with the proper equipment, that can only be a good guess.
If you have found this help to you a good rating would be really appreciated.
Posted on Jun 22, 2008
dunnbiker
  • 8546 Answers
SOURCE: CHK SPKR appears an turns off the system
It means to check your speaker connections for shorts.
Posted on Feb 20, 2010
  • 336 Answers
SOURCE: it says chk spkr when
You probably have a blown channel. but check for a shorted speaker wire or bad speaker. Remove all speaker wires from the rear of the receiver if it still says check speakers when turned on, then one of the output channels is bad.
Posted on Feb 12, 2011
2000 KIA SPORTAGE STEREO WIRING DIAGRAM
You can use the attached diagram for assistance, but here goes:
1. Blue/Yellow (Pin 1) - Illumination (+12V) (when headlights on)
2. Black/Yellow (Pin 1) - Main Power (+12V)
3. Light Green/Black (Pin 2) - Memory Power (+12v)
4. Black (Pin 11) - Ground
5. Blue/Red (Pin 9) - Left Front Spkr Return (-)
6. Green (Pin 19) - Left Front Spkr Signal (+)
7. Brown (Pin 10) - Right Front Spkr Return (-)
8. Light Green/Yellow (Pin 20) - Right Front Spkr Signal (+)
9. Blue/Orange (Pin 7) - Left Rear Spkr Return (-)
10. Green/Yellow (Pin 17) - Left Rear Spkr Signal (+)
11. Green/Red (Pin 8) - Right Rear Spkr Return (-)
(Note here that the wire color at the rear speaker is
Green/Blue - not sure if this is a misprint (see diagram))
12. Yellow (Pin 18) - Right Rear Spkr Signal (+)
Nov 10, 2013 | Vehicle Parts & Accessories
Need color code for kenwood kdc mp 245
black - ground, red - switched or ignition, yellow - constant (memory) power, white - left front spkr pos., white/black - left front spkr neg., gray - right front spkr pos., gray/black right spkr front neg., purple - right rear spkr pos., purple/black - right rear spkr neg., green - left rear spkr pos., green/black - left rear spkr neg, blue - antenna remote, blue/white amp remote turn on.
Nov 02, 2010 | Kenwood KDC-325 CD Player
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
I need to know wat colours do wat on a kenwood KVT-739 car Stereo DVD player wiring
yellow - constant power, red - switched or ignition power black - ground white - left front speaker pos. white/black stripe - left front speaker neg gray - right front spkr pos gray/black stripe right front spkr neg green - left rear spkr pos green/black stripe - left rear spkr neg purple - right rear spkr pos purple/black stripe - right rear spkr neg blue - power antenna remote blue/white stripe - amplifer remote turn on
Aug 16, 2010 | Kenwood Car Audio & Video
What is the color code for the wires to the factory radio for a chevy malibu 2004
1989-1990 And Newer
AS VIEWED FROM MATING END OF CONNECTOR
A B C D E F G H I J
K L M N
F Not Used
H Power Antenna Turn On Pink (if available) Blue
Smaller sized
Mar 07, 2010 | 2004 Chevrolet Malibu
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
I need a factory radio wiring diagram for a 2006 chevy 1 ton just a am/fm cd player
1989-1990 And Newer
A B C D E F G H I J
K L M N
F Not Used
Smaller sized
Feb 01, 2010 | 2004 Mazda 3
1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
Rear Wirelss speaker do not work
With the main unit turned off, press and hold [REMAIN] on the home theater's remote for 4 seconds. (The REMAIN button is directly under the 7 button). Once held down for 4 seconds, the Volume Indicator on the main unit will turn on for 1 second. Release the [REMAIN].
Press the [RESET] on the back of the Wireless Receiver 2-3 times. The Standby/On LED on the front of the Wireless Receiver will blink 3 times
Turn on the main unit. The Link LED on the wireless receiver will light up if process is done correctly. The front of the main unit will no longer say REAR CHK and the rear speakers should now function correctly.
Feb 24, 2008 | Samsung HT-WX70 Theater System
RCA RT2380 System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
