Question about Vivitar ViviCam 3935 Digital Camera
Blocked driver will not work with vista
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
Posted on Apr 07, 2012
Need a driver for Lexmark x9575 using Windows 8
Hi
Driver related problems can be solved easily on: Driver Update Software for XP Vista 7 8. Wish you best of luck
Thomas
Mar 10, 2013 | Lexmark X Office Equipment & Supplies
I have a dell printer A920 and an acer computer with windows 7. Having trouble getting the printer to work
First run Delete Print Jobs to remove any stuck print jobs in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
Download and install the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Links to the patch/drivers can be found at...
Dell A920 All-In-One Inkjet Printer owners thread (W7)
Virus programs and firewalls will block communications.
Rick
Apr 18, 2011 | Dell A920 InkJet Printer
Driver blocked due to incompatibility in windoes 7
usually windows seven it takes most drivers automatically ...so go to device manager and choose one by one any drivers that you find in yellow ..and click on automatic update ( update driver ) it will search with an wizard auto...if the driver for any device is not present it will inform about ..and you have the choice either to try with the same driver from Vista ...(usually works) or disable if you do not need the device...
Dec 21, 2009 | Computers & Internet
I upgraded my hp omnibook 6100 from xp to windows vista. now it tells me that there is no audio device installed. is there a driver i can download for my laptop that is compatible with windows vista?
I had the same problem with my HP when l put vista on it and overcame that problem with using my XP driver. It worked for me no harm in trying your XP driver.
Nov 24, 2009 | HP OmniBook 6100 Notebook
Windows 7: Printer not working
It sounds as if you don't have the latest drivers for this printer. To run on Windows 7, it may work with Vista drivers.
Windows 7 just won't run some older drivers.
Nov 11, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
All I can find for my Canon iP5000 is an add-on module for Vista 64. What driver must I install before I add it on?
What you need to do is to prepare your printer...power up, ink in, paper in, and then plug the printer into your computer.
Vista has the basic driver for your printer. After Vista detects and installs the driver then you can download the add-on and install it.
Here is a reference for you from the Canon Support site:
iP5000 using Vista
I'm not sure if that link will work as is. If it does not, go to: Canon iP5000 Support then enter vista in the Knowledge Base search block and click Search. The top result should be "Does My product Support Windows Vista?" Click on the red link for the information.
Thanks for using Fixya.
Oct 01, 2009 | Microsoft Windows Vista Ultimate Edition
Vista 32-bit driver for MF3110
Go to Canon MF3110 Support
If the Drivers & Downloads tab is not selected, click on it.
From the drop down menu, select your Operating System (Vista).
A link will appear in red in the Drivers block that appears. Click on the link to download it. The best thing to do is to select Save when the download window opens and save it to your Desktop. You can then begin the installation once the download is complete.
The Setup Guide is also on that same download page if you need it. Just remember when it says to insert the CD, just double-click the file on the desktop.
Sep 28, 2009 | Canon MF3110 All-In-One Laser Printer
Sir my window vista tell that some driver blocked due to compatibility issues what can i do to solve this problem?
I CANT SOLVE THEM BCOZ THE DRIVERS ARE OUTDATED OR NOT COMPATIBLE WITH UR VISTA FOR THIS U NEED TO UPDATE UR DRIVERS FOR VISTA
PLEASE VOTE FOR ME
May 19, 2009 | Microsoft Windows Vista Ultimate Edition
Download driver software for PIONEER DVD-RW DVR-K17LF ATA Device
I wish to download the Software drivers for Pioneer DVD RW
May 24, 2008 | Computers & Internet
Vista
Have you tried turning off your firewall?
That may be the issue.
FIrewalls will block printers. Can you ping the printer and not print to it?
Feb 12, 2008 | Office Equipment & Supplies
Vivitar ViviCam 3935 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
