Question about Lanzar Vibe 218 Car Audio Amplifier
My amp wont go past protect mode
My lanzar 218 vibe wont go past protect mode wat do i do
  • Anonymous Mar 24, 2014
    My Amp keeps going into protect mode when starting up Dont know why wires are all connected correctly What can I do to take it off protect mode
I had the same problem. be sure to change all transistors cause once one goes the rest useally goes right along with it... replaceing one or two transistors will not do the trick, cause once you power up again the rest of them will go, & you will have to repeat the prosses
Posted on Nov 25, 2008
  • 631 Answers
Disconnect all speaker wires and signal cables from the amp. If it powers up (no protect light), the wiring needs to be checked. If it still shuts down (goes into protect), the amp likely has blown output transistors.
Posted on Oct 09, 2007
How do i reset my 4000 watt lanzar vibe 286 from being in protect mode
You can only reset it by disconnecting power to it. If it is in protect you may want to check your speakers and speaker wires for shorts and/or grounds. If they check out all right you may have internal problems in the amp.
Oct 28, 2011 | Lanzar VIBE286 Car Audio Amplifier
I have a Lanzar Vibe 235 amp. the green power light is not coming on, but the red "protect" light is. how do i solve this problem??
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Time to purchase an old school Lanzar Opti Drive. Any of them. The 50 will kill some 12" subs .A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-vibe-235-amp-green-power-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
Mar 11, 2010 | Lanzar Vibe 235 Car Audio Amplifier
Prosound amp is running fine but the protect light is still on
Hello martinpresto,
The most likely causes are overheating and operating the amp into too low of an impedance. Or the amp itself could be failing. If the protect comes on immediately after the amp has cooled overnight, it's probably not overheating. Too low of an impedance can be caused by a shorted voice coil.
You can check the load with a multimeter. Disconnect the speaker wires and measure their resistance with a multimeter. Since the published impedance is nominal and varies with frequency, you'll be reading the DC resistance. Some manufacturers include the figure in their "R subscript e" specification. Usually, it's a little lower than the impedance. So a 4 ohm load may read 3.2 ohms. If the DC resistance checks OK, it's probably the amp itself.
Hope this helps.
Sep 19, 2009 | Lanzar Vibe 218 Car Audio Amplifier
Lanzar 800 watt amp protect mode stays on
protect mode usaully means that something has disrupted the power of feed lines to the subwoofer/speakers possibly fuse is blown in amp or amp is blown in which we hope not. see if you have a warrenty if blown and send back or bring it to where you purchased it from.
Aug 01, 2009 | Lanzar VIBE266 Car Audio Amplifier
Protection light grief
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Vibe is mediocre. Time to invest in an old school Lanzar Opti Drive amp. .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-light-grief-shonxoarcym4awy4zl1imx4o-2-0.jpg
Jun 11, 2008 | Lanzar VIBE266 Car Audio Amplifier
Lanzar Vibe 1200D protection light
You will need to show it to a service technician as it seems the output section has blown so it remains in protect mode. One reason (could be) that the input to the amp was high and may have been clipping for some time before the amp decided it could take it no more
Jan 14, 2008 | Lanzar Vibe 1200D Car Audio Amplifier
Audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Nov 28, 2007 | Lanzar 2H 1000W MOSFET AMP Car Audio...
Pb1644
Oct 07, 2007 | Lanzar Vibe 218 Car Audio Amplifier
Protection mode on Lanzar Vibe 241
Almost without exception, if the protection light comes on as soon as you power it up, the output transistors are defective. Any reputable repair shop that services car audio equipment should be able to repair it.
Oct 06, 2007 | Lanzar VIBE241 Car Audio Amplifier
Lanzar vibe 1500 protect mode
sorry bath your problem is a proablem the soft
Aug 02, 2007 | Lanzar Vibe 1500D Car Audio Amplifier
Lanzar Vibe 218 Car Audio Amplifier Logo
528 people viewed this question
Top Lanzar Car Audio & Video Experts
Mike Duncan
Mike Duncan
Morne Olivier
Joe Alexander
Joe Alexander
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
