The cd doesn't rotate/or isn't read
The player isn't dead, the tray opens and closes, but the cd doesn't rotate or isn't read. Before committing to a repair I would like to get closer to an identification of the problem, such as the motor, its control, or the laser. Is this possible and if so, any suggestions would be welcome.
  • 165 Answers
Ok if you know how to clean up kit for cd,s and if it works your re done...see the problem continues you have to change the laser just tell yourself how many hours has the laser on operation. and if its worthly....saludos
Posted on Nov 17, 2008
A disk is stuck in my Harmon Kardon player. The door will open and close and I can see the disk but cant' get it out.
turn on the unit and then tried to press the play button while the cd tray is in place. if doesn't work, unplug the dvd player then open the cover to access the internal part. look for a broken limit switch for cd tray mechanical assembly or check weather the cd not in proper place in the tray that is why an error occur.
Sep 02, 2012 | Televison & Video
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
CD Player Tray keeps opening and closing by it self
This is either caused by the drive belt slipping, the closed sensor being faulty or an obstruction to the tray.
Basically the tray isn't makeing it to or registering as being in the fully closed position.
May 02, 2011 | Tascam CC-222mkIII CD Player / Recorder
Cd was still player and I found the player with drawer half open and jammed. I can't get it to sync with correct rotation, enough rotation or fully close or fully open. I can force it and hear the gears...
Rea alligning cds is not hard, but not too easy,the best way is to remove the whole cd changer mechanism and allign it to either one point,while totally disconnected, fully open or fully closed. I mean, the rubber or gear mechanism.
The main point of reference is the nearest part driven by the main motor. For example decide to do it when fully open, arrange everything so as to allow the tray to be fully open.If you get everything right, rotate the motor manually and see if it closes the tray without jamming..If it gets fully in keep rotating the motor and see if it loads the disc.if it does, return the assembkly, the sensors and the cd computer will take over from there ...
Apr 12, 2017 | Sony CDP-C445 5-Disc CD Changer
Open tray on xbox when it's closed
when the tray is closed and it does not
see a cd it should say open tray
The problem weak or dead laser
laser are chep 30.00- 40.00
and not to hard to swap out.
second it may be a bad drive motor
or bad spindel motor .in that
case you will to buy a new
drive and swap out the P.C. board
from the old drive to the new one
Rob
Sep 16, 2009 | Microsoft Xbox 360 Console
Onkyo C-707chx cd tray jammed won't open won't play
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Jun 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
CD tay won't open
If you had any cds inside, you can open the case and see whether there's any cd jammed, with the power switch off! If you didn't have any cds inside, open the case anyway and check if the tray opens or not!!!
Hope it goes well!!
Apr 04, 2008 | RCA RS2653 Shelf System
CD Player tray will not rotate or open or close - no power
my cd player will open and rotates but will NOT play, can anyone help me?
Oct 09, 2007 | Audio Players & Recorders
CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Sep 19, 2006 | Sony MHC-RX70 Shelf System
120 people viewed this question
 Grubhead
Grubhead
