Question about Cameras
Error 18 powershot - Cameras
    Master:
  • 623 Answers
The camera can take a couple of shots (clear and in focus), then stops working. Removing the batteries and replacing may produce 2-3 extra shots.
Canon's instructions (by phone) are to 'remove the batteries, rotate the on button and hold for 5 seconds, and then replace the battery'. The few lucky pictures are clear and in focus.
A better solution (not provided by Canon) is to connect the camera to the TV or a computer. This may completely solve the problem. If not, it may at least allow an extra 10-15 shots. There are several forums on the net that mention that connecting the camera to the TV completely resolved the E18 error.
A camera lens is out-of-focus. Some users have been able to manipulate the lens back into place (see reference links below). To fix the problem, it is often necessary that the camera and optical assembly is disassembled, realigned and reassembled. A non-warranty repair at an authorized service center reportedly costs between US $79 to $250.
Posted on Nov 17, 2008
E 18 errror
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 28, 2009 | Canon PowerShot S2 IS Digital Camera
E 18 error what is this
Most probably this is due to dust accumulated on the lens barrel, which prevents the lens from closing properly. Try cleaning the lens barrel. Check for any dust particles on the lens barrel (the part that retracts) and try again. If you can't get it out yourself, take it to an authosized service center.
Feb 04, 2009 | Canon PowerShot S1 IS Digital Camera
E-18 problem
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Oct 14, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Error #18 Lens will not close and camera shuts off
Hey louboyens,
According to the manufacturer error code 18 is a lens error code. What that means is something is obstructing the movement of the lens. I would make sure that your hands or anything else is not preventing the lens from moving correctly when your powering the camera on, and make sure the camera is powered off and not powering on while in your camera bag. Try turning it off and back on and after this the camera still displays the error code you should probably have it looked at by an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
May 15, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
E 18 Error
The following blog outlines some repair options for a lens error. They won't work for all cases (little less than 50%), but they're worth a try if the camera's no longer under warranty:
Jan 12, 2008 | Canon PowerShot A80 Digital Camera
Faulty Canon Powershot A410 Digital Camera
I have answered this in another post. Here is the link.
If this helps you, please return and choose FixYa! ThankYa!
Dec 04, 2007 | Canon PowerShot A410 Digital Camera
Error 18 in right bottom corner
"e18" is a lens error, the lens is stuck and would not come out, camera displays error and shuts off. replace the lens assembly and it will fix the problem
Aug 20, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Error 18
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: - Hold the camera so that your fingers do not touch the lens unit when you are shooting. - Make sure the camera is off before you put it back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Error 18
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: - Hold the camera so that your fingers do not touch the lens unit when you are shooting. - Make sure the camera is off before you put it back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
Aug 29, 2005 | Canon PowerShot A310 Digital Camera
Cameras Logo
88 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
