Question about Bose Wave Radio
Bose wave radio does not turn on
When the player is plugged in it does not turn on. I have unpluggeg it opened it up and voltage is supplied to the transformer and coming out of the transformer but the radio or clock still do not turn on. What is wrong with the radio or what can i do in order to troubleshoot the radio?
  • 8 more comments
  • nobose Dec 02, 2007
    unit does not do anything. No display, no radio , nothing. Worked fine for a few years and then just quit.
  • jmae Dec 28, 2007
    The radio will not come on, nor can I set the time; the time just blinks.
  • bennyboo Dec 30, 2007
    Good Afternoon:
    My Bose radio/cd is not working! When I turn it on, it seems like the alarm is stuck - it makes the alarm sound and is very loud. The radio will not come on and the CD feature will not work. What can I do to fix this? I have unplugged it and replugged, this does not seem to help.
  • jonala Jan 09, 2008
    My radio died after a power outage. Does anyone have the part number for the transistor?
    Thanks
  • Raj65 Jan 15, 2008
    power goes to unit but no display, no sound, no buttons work.......worked fine for a couple of years then poof! not what I would expect from Bose....
  • Ronald Mar 23, 2008
    Worked fine, unplugged radio and plugged back in. Now no lights, clock or radio. have power to radio.
  • Anonymous May 03, 2008
    My elderly Mother just called to say her Bose just stopped working, just like that. She's broken hearted any idear why this would happen
    Pam Mclean
    gpbmac@comcast.net
  • Anonymous Oct 25, 2008
    worked fine for about 5 years, then, dead.
    no lights, sound,cd, nothin. wife turned it off 2 nights ago, never regained life.
    I need my Coast to Coast AM mightnight radio fix! HELP!!!
  • harusan Oct 26, 2008
    The unit will not turn on. No clock, no time, nothing
  • wordsorcerer Nov 05, 2008
    BOSE Wave owned less than 3 years, and suddenly - with no sign of decreasing capabilities - just stopped working.
  • 52 Answers
Considering that power is present and all fuse are OK, check R406 for open. Check for Q401 also, the 5V supply to display.
Hope this will help.
Posted on Jan 03, 2008
By an EMerson@&%$*@
Posted on Oct 18, 2007
PIONEER PL-720 TURNTABLE MAINS SELECTOR VOLTAGE TRANSFORMER OPEN CIRCUIT, CAN I ELIMINATE IT NAD OPERATE FROM 110vac DIRECT?
What you are talking about is rebuilding the power supply for the turntable. A tricky job. Can you not find a replacement transformer?
Otherwise you could find a pre-built power supply, providing it has the correct secondary supply for the turntable.
Oct 09, 2018 | Pioneer Audio Players & Recorders
Howw do you make a Samsung bd-F5700 blue ray player operate on a 240 volt power supply
You'll need to bring the voltage down to 110-120 volt. Travel converters do this cheap and effective. The player only uses 12 Watt according to the manual. You could use an old 3 prong extension cord to cut of the connector to connect to your power supply. Get the converter below and plug it into the adapter, who then will fit in the extension cord.
25361686-pcx3svhkvlazjixsdsr3jt1v-2-0.jpg New 220V to 110V Step Down Voltage Converter 50W Travel Power Transformer 25361686-pcx3svhkvlazjixsdsr3jt1v-2-3.jpg Generic Round Europe to USA Plug Adapter
Jan 09, 2015 | Samsung Televison & Video
Denon dra 25 no power
John,
If you have a multi meter then unpug from mains supply.With meter
on "ohms" range check the following:-
Fuse F501 (and F502 if mult-voltage model)
yellow to white on mains transformer this should show some resistance.If you have a mult-voltage model check
brown to gray and orange to white. Both should show some resistance, if not your mains transformer has an open circuit primary winding.....
Mar 03, 2014 | Audio Players & Recorders
My Toshiba RDXV60 stopped working, there are no lights no sound and will not respond to the remote or to button operation.
if you want to confirm if the transformer in the power supply is also bad you have to make a voltage checking. turn on the dvd player and make a voltage checking at the output at the power supply board.
Nov 19, 2012 | Televison & Video
Screen does not switch on at all , and no sound either. However standby light is on only when plugged. TV repair told me it is transformer and line up, however asking for more then 100...
Hello, most common faults, such as CRT TV will not turn on. The reason stems from the low power supply failure, or from the high power supply. There are two transformers suppliers, with more common high-tension transformer goes bad. Price of 80 or $ 100, sounds reasonable replacement of transformer. Along with this need to perform some tests that require a professional, to confirm that the problem is due because of transformer. One test is to test basic stability, voltage power reaching the high-voltage transformer. If lower than normal voltage. Then perform the same test, when you break the initial snap of the transformer. If the voltage rises to the desired level must be to replace the high voltage transformer. Good luck!
May 12, 2011 | Sanyo Televison & Video
My hard drive has stopped working! I checked power supply and it is working fine, when plugged into drive and turned on, the blue light flashes briefly on the drive then goes off again as does the light on...
Could be a bad transformer on the power supply or a bad drive. You could check the voltage coming from the transformer and verify that it is the proper voltage using a fluke meter. You could also dis-assemble the hard drive housing and try installing it in the computer and check if it is working. If you install it in the computer and the drive is not found then the drive is probably bad. If the drive works in the computer then get a new transformer.
Sep 24, 2009 | Western Digital Computers & Internet
The power supply of my pioner dvd was burn
Hi
check all semiconductor in the power board and look for a shorted and open parts! then replaced the defective parts.
Thanks!
Dec 05, 2008 | Televison & Video
TV doesn't turn on
first warper2001 your power supply is probanly bad the voltage checks was you getting 80 volts on the output side of the transformers each one should be labeled as to the output voltage, at least one of them should only supply 24 volts, the transformer went bad probably overheated and melted the protective coating in the trans and let the voltage increase. could have burned out lots of things. unplug it, use a screw driver and short across the plug ins and the ground on the cord to drain the capicitors in the unit. the ohms check the components through each and to ground. check for opens and shorts. when checking a board remember that you will get a little bled back because you cannot isolate the parts. so most of you ohms readings should be large amounts of resistance if not you have a problem with that component, wire coils excluded. ie transformers they are best voltage checked. hello motorcity kid. i sent you a buddy message but also remember these items of advice.
Feb 19, 2008 | Polaroid FLM-3232 Television
Dvd player is completely dead.
First thing to check is the power cord with it unpluged. Do you get a resistance there or is it open?? If its no reading at all then the power transformer or fuse or current limiter resistor is open. If you do get a reading then you know your power transformer primary is good. Next measure the AC volts comming from the secondary of the transformer. AC volts? Good! Now Find pin 1 or the end pins on the microprocessor. 5 volts present?? No theres your problem get a schematic and troubleshoot the power supply. Yes 5 volts? Measure the display any volts on it?? Ok im sure by now your gonna say no to one of these and like I said get a schematic and conferm all the voltages are present in the power supply. Most common dead problem in dvd/cd players is the power supply ie transformer,regulator, ic, ect, ect. Good Luck
May 10, 2006 | LG DVD 5183 DVD Player
Bose Wave Radio Logo
1,191 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Steve Allison
Steve Allison
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
