It may be air whistling past the exhaust filter, which may need replaced. Try removing the filter to see if that could be where the noise is coming from.
TRY AND LISTEN TO UR COMPRESSOR SEE IF U HEAR ANNYTHING THERE? IF NOT CHECK UR COMPRESSOR CONDENSOR FAN AND FREEZER EVAPORATOR FAN FOR BLOCKAGE OR OBSTRUCTIONS? OR POSSIBLY 1 OF THE FANS MOTOR IS GOING OUT MAKING FUNNY SOUNDS, ANOTHER THING COULD BE A BAD DOOR SEAL ISSUES WHICH OVERWORKS THE COMPRESSOR AND CAN CAUSE IT TO MAKE FUNNY NOISES
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
sounds like an exhaust system or shield, possible clutch noise? this is something only you or a person actually sitting or driving the car can determine.
More likely it's the lifters--exhaust leaks don't usually get quiet. Make sure you have a fresh oil change (high mileage oil) with a filter change. The high mileage oil will tend to clean the lifters as well as soften hard seals. If the noise gets worse, eventually you will need to get the lifters changed. Hope this helps!
The pump sounds like it may be plugged wih a coin or something like that. If the pump is plugged it will make a funny noise. Remove the pump and clear everything out of it
