When I try to start a cycle (any cycle), all of the lights flash. Nothing starts. It wont turn off with the power button. When i press the STOP button the entire machine cuts off. (The door was also locked shut but i founf the info on how to open it) I removed the front panel and cleaned GOBS of change, pen parts,bobby pins, and airsoft pellets out of the filtrr. The roter seems to be turning fine. Suggestions???
SOURCE: Kenmore Elite 10.4708 front load washer won't start with new load
Uh oh! It did it again! This time I had to unplug 6 times for one cycle. Seems to be on the last 2 minutes most of the time. Today my husband is taking the control unit and looking for soldering problems. On Askmehelpdesk.com this man told of taking the bottom panel off and there is a little black latch thingy you pull to open the door lock manually. Also he said that the K2 and K4 relays are usually the problem if it isn't a soldering issue on the connectors. ( On the CCU);. He said one of them is usually burned and to clean it off and then switch it with the other one which carries less voltage, therefore doesn't burn. You can use a pencil eraser to do this. My husband told me they did this in the Army for MOose code contacts. He just told lme the soldeirng looks good on the connectors and is now working on the K2 and K4 relays. If you go to Askmehelpdesk.com/appliances you will see these tips are for the Whirlpool Duet whic is apparently the same machine as our Sears Kenmore H4's. Gosh, I hope this helps someone as it sure is not fun trying to track this problem down. I am glad you got Sears to come out. I will NEVER and I repeat NEVER buy from Sears again! Did I mention I wrote a letter months ago when I was having a hard time getting warranty work done.( Which I never did) that I had written to the pPesident, CFO and the Texas Attorney General for Consulmer Protection Division and never got a response from anyone?
SOURCE: Kenmore model 44142400 door lock
Try unplugging for 2 minutes and if display looks the same, then theres and elec. issue.
SOURCE: I have a front loader. When I shut the door and
pin on door switch is brocken. look on top of door latch
