CODES FOR IECR6
I have a SANYO TV. MODEL DS20930
THE REMOTE IS IECR6. PLEASE HELP ME WITH THE CODES.
THANKS,
GARY
5 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: Masterplug tvrc4n 4 in 1 remote control/sanyo
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 23, 2008
CMV9
  • 594 Answers
SOURCE: codes for my sanyo tv
please give me them the model number of your remote and i would be glad to give you the codes
Posted on Jan 08, 2009
SOURCE: need codes for a Sanyo TV
Code for Sanyo TV is 0154
Posted on Mar 26, 2009
SOURCE: i need remote control codes for my GE universal
Need Code for GE RC24991-B Remote Control
Posted on Jan 13, 2010
I am trying to get TV remote control on MARAI Model Number : T3212G DTL- 332M200
063,061,069 are the setup codes to check with this brand TVs. If you wish to get more, check the sites linked here. It has setup code list, and setup procedure to many popular brand remote controls. Check which brand remote control have setup codes to your Tv brands' and buy that brand remote control, according to availability. Brand name of the remote control isn't a matter; but it should have setup code to your TV brand. That's all.http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 02, 2013 | Sanyo DS20930 20" TV
How do i get to the input channel
Generally there is an input button on the remote. This is assuming you have the original remote that came with your television. Otherwise, there may be a button on the television itself.
If the model number you provided is accurate, this pdf may help
http://www.sanyotv.com/DS20930%20(E)%200169--.pdf
Mar 29, 2011 | Sanyo DS20930 20" TV
HOW CAN I FIND THE CLOSED CAPTION ON SANYO TV MODEL DS20930
User manual:
http://www.retrevo.com/support/Sanyo-DS20930-TVs-manual/id/17567dj485/t/2/
See page 6 (CAPTION button on the remote) and page 14 on how to use Closed Caption functions.
Dec 30, 2010 | Sanyo DS20930 20" TV
Digital?
No sorry to dissapoint DS is short for Definition STANDARD ... and is a cheap 20 inch model assigned to category 2 of televisions. To improve its reception you could apply a Digital setop box to it to get all the additional channels seen on a Digital. Probably last longer than most new plasmas and LCD's as this is quite a robust little TV.
Please rate my help++++Thanks for using FIXYA
Nov 28, 2009 | Sanyo DS20930 20" TV
Change input without remote
Go to menu on front of tv, scroll down to source/input heading.Use the volume or channel select buttons to change the source
Sep 14, 2009 | Sanyo DS20930 20" TV
Sanyo C25EP57NB tv remote
just try as long as it is sanyo remote control
Sep 09, 2008 | Sanyo DS20930 20" TV
Need code for sanyo tv
Welcome to FixYa.
SANYO TV Codes: 0154, 0159
Please be informed that the codes vary with different make and model of the universal remote that you have. If none of the codes above work, please post back with make and model of your universal remote included.
Thank you for using FixYa.
Jas247
Sep 01, 2007 | Sanyo DS31590 31" TV
Manual Controls Insufficient
What is your universal remote control? if its not philips magnavox you try this universal remote control you will set the code match to your tv sanyo which you will see at the back of the instructions manual when you buy this remote control. follow the instruction of the manual on how to enter the code for tv. thanks.God bless you. i hope it will help.
Jun 11, 2007 | Sanyo DS20930 20" TV
Televison & Video Logo
465 people viewed this question
Top Televison & Video Experts
