Question about Dell Dimension 8100 PC Desktop
Undetected com port 3
Modem connects to com port 3. Not listed in device manager. Only lists com port 1 and printer port. Fresh format of hard drive didn't help. Windows 2000 SP4. help
  • 341 Answers
You may have to enable the other com ports. You go into the Control Panel and click on Add&Remove Hardware. When the first window shows up with everything that is already installed list, look at the top of the list. Highlite Add New Device. When ask, choose Select From A List. Then select COM Port and follow the wizard.
Posted on Nov 26, 2008
My computer can't see my 1tb seagate expansion portable hdd which I formatted to my smart TV
Formatting a drive using smart TV usually makes your drive into Linux file format like ext2 or ext3 file format, which windows does not recognize. (not unless you install reader or software to read this).
Check on your computer's "Device Manger" if your drive is undetected or just in format your computer cant read. To check
1. On start menu, right-click "My Computer" & click Manage.
2. Click on disk management (assuming your HDD is connected)
3. Check if your drive is shown there and in what format. Like this:
4. You can format your drive here too if you want.
5. If it is here, then your drive is working fine, you just need to install ext2/ext3 file format reader to see the files.
Dec 26, 2014 | Computers & Internet
Drive will not come ready in usb port on my laptop
1-go to device manager by right clicking on my computer icon
2-click manage and then a window will open in it select device manager
3-see for usb ports in the list of devices
4-check if all the ports are enabled if not right click and then enable
if the solution doesnt work
connect to internet and then connect your HDD so that windows will search for drivers online and install it
Nov 09, 2013 | PNY 64GB Drive
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
My scanner doesn't communicate with my computer but my printer does
Hi, there are many possibilities why your scanner is undetected by your computer. It can be its logical connection, scanner driver or the scanner itself.
If you have Windows operating system, please check Device Manager. In the Device Manager please check for the following:
1. Any yellow or red X's, question marks or exclamation marks related to the scanner.
2. Under the Category of Imaging Devices - Check for Epson Product name.
If IMAGING DEVICES is listed, test the scanner from PAINT as follows.
If IMAGING DEVICES is not listed then the scanner is not being recognized. Try another USB port or cable until the scanner shows up in the Device Manager. (The scanner must be on and connected in order for the computer to recognize it)
If you see an Imaging Device that points to your Epson Scanner or Unknown Device that has a yellow question mark or exclamation point, you need to update the driver.
Try to scan in Paint to isolate the issue between your computer and scanner.
To scan in Paint, do the following:
1. Click on START > ALL PROGRAMS > ACCESSORIES > PAINT.
2. Click on FILE then select FROM SCANNER OR CAMERA.
3. Choose COLOR PICTURE.
4. Scan.
If it does not work, it is possible your Windows Image Acquisition (WIA) service is not started.
To restart this process please follow the steps listed bellow.
1. Click on Start > Control Panel > Administrative tools
2. Double-click on Services to access the list of available services.
3. In the Services window scroll down to the bottom and double-click on the Windows Image Acquisition (WIA) Service.
4. Select the STOP option.
5. Click the START option to restore the service.
6. Try scanning again into Paint.
If it scans fine, try scanning from the application that you normally use. If you are still unable to scan or receive any error messages, try reinstalling the scanner driver or software.
If you have Macintosh operating system, please check Apple System Profiler if your scanner is properly detected. The reinstall the scanner driver.
If your scanner is still undetected, please contact your scanner manufacturer for any possible driver updates.
Nov 11, 2011 | Epson WorkForce Office Equipment &...
How to reformat a flash drive
Hi jabbbbbb6,
The Cruzer Micro is a flash storage device that connects to your computer's USB port. It comes in various sizes and fits on a keychain. If you want to erase the drive, you can perform a reformat from within Windows' Disk Management utility. After you reformat the drive, you do not need to reinstall any drivers because Windows automatically detects the device.
To Reformat, please follow the instructions:
1. Insert the Cruzer Micro to an available USB port on your computer. Right-click "Computer" and select "Manage." Click "Disk Management" under "Storage" on the left pane of the window.
2. Right-click your USB drive on the list of drives and select "Format." Select a name and file system type for your drive.
3. Click "OK" to reformat the drive. Click "Start" and "Computer" to access your drive.
Rate this accordingly.
Hope it helps.
Thank you for using Fixya.
Oct 06, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My iomega external hard drive is not being recognised in 'My Computer' but is in the device manager. Software updated. Not sure what to try next to use it?
Hi, Thanks for using fixya.
1. With the device connected to the usb port Right click on My Computer choose
manage. On the left side make sure storage is expanded double click disk
management on the left upper side see if Iomega is listed.
2. If it is on the lower part find your Iomega right click on it choose change
drive letter and paths. Click on change, you will see a drop down arrow click
that choose the first available letter, Now click on change. Open My Computer see
if it is now listed. If it is you are done.
3. With the device connected to the usb port reboot your computer when it comes
back,open My Computer see if it is now listed.
Terry
Feb 13, 2011 | Iomega 33089 250 GB Hard Drive
My hard drive can't be detected by device manager. All it does is blink and make a weird sound each time it blinks. What should I do?
good day.....seems this tips can help you...trace the sata cable if properly connected...but i'm sure the ticking sound is an indication of defective hard drive...inside the hard has a mechanical arm that goes up and down...this arm read the data..... it's better if you buy a new one....
Feb 13, 2011 | Seagate (ST9100801U2-RK) (9W3638556) 100...
Undetected external desktop drive in Windows Vista. The front light is flashing... it is normal?
On some drives flashing is normal and can indicate data being read etc.
You didn't give a specific model so I have attached the basic troubleshooting steps
A few things to check but assumes USB for other interfaces similar steps may be followed
1. ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer.
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply (Dont use any other unless you know it has both the same voltage and current rating eg. 12V 500mA anything rated below that would not work properly)
5. always use the same port for connecting your devices. Some devices do not like being switched about.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select computer management.
Now select Disk Management and expand the window.
Your drive should be listed here (if not then you need to check your computer hardware has not got any issues before proceeding)
If your drive is listed and says healthy then right click on it an select Properties, click tools and then error checking, Check now, tick the two boxes and then start.
This will attempt to fix any errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed ut did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. when it is done restart your computer and you should be good to go.
Aug 17, 2009 | Seagate Computers & Internet
Windows XP wont install USB card readers
Did not reinstall the needed drivers. Download drivers from manufacturer support and install them.
Maybe just maybe you can use device manager to install the drivers by searching the web for them. Only take a minute to make the attempt.
Mar 05, 2017 | SanDisk ImageMate 12-in-1 USB 2.0 Card...
Can't dial up... no com ports listed in devise manager
This may be a simple driver glitch with the modem. Uninstall the modem drivers from the device manager and reboot. The machine will find the modem and reinstall the drivers. If this doesn't work, then check for driver updates or any utility drivers from the support site for E-machines.
Jul 25, 2008 | E-Machines M5310 PC Notebook
Dell Dimension 8100 PC Desktop Logo
166 people viewed this question
Alun Cox
