Question about Electrolux Washing Machines
I've got a 8kg frontloader Electrolux washing machine. There is a coin stuck in the barrell so now it won't spin? How or what do I do to get it out, besides calling a repair man ?
    President:
  • 1,462 Answers
Take back panel off. remove heater and you can see into the gap between tub and drum and extract coin
Posted on Nov 17, 2008
My Electrolux 8kg time manager lifestyle washing machine got overloaded, now won't wash or spin .. Still drains.. Any ideas plz Tia..
1. Check belt if it is broken.
2.Is the motor running?
3. Is the program /display running as normal?
I have try to fix those machine, all of them are the PCB not working.
Good luck
Oct 14, 2016 | Electrolux Washing Machines
Drum will not spin when wash cycle is started
If the machine took the water then you need to check the correctness of the motor, inverter and wiring, otherwise malfunction is in the process of taking water.
Dado
Nov 01, 2015 | Electrolux EWF1486GDW White 600 mm Washer...
Bosche axxis washer spin cycle ticking noise
Assuming everything else is working normally, I would still suspect there is an object that is getting stuck between the rotating drum and the outer housing. Maybe not coins, but something longer, like a pocket comb or the wire inserts used in some garments. It is easy to take the top off of the unit, and this might help to isolate the noise better. Early spin is usually a bit unbalanced, so it is possible it could also be something really simple like a hose clamp that has sagged enough to be contacting something else, and it only shows up when the machine is bouncing a bit.
Mar 16, 2013 | Bosch Washing Machines
Electrolux 8kg won't run
This is probably normal operation , you can press the start/pause and cancel button at the same time to see if you have a error , if you get E00 this means no error if you get a E21 (example) then look and see what that error is
Feb 20, 2013 | Electrolux Washing Machines
Electrolux frontloader washer detergent drawer won't stay shut
Hello royal37 - Hi - The dispenser drawer could either be cracked or have a broken latch due to interference between the drawer front and top panel. Contact a professional to move forward accurately and might possibly need to order a service kit (PN: 137146000/part number may be different depending on your model number).
Feb 13, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
My washer won't spin. There is a coin stuck inside
If the coin is in between the 2 drums but is free floating you amy be able to get it by removing th bottom drain hose from the drum but this can become a pain unless you are lucky as the coin will move with the machine tipped over. the other way is to remove the heating element while the machine is upright and use a stick or a grabber to get it out.
Dec 30, 2012 | Washing Machines
Washer stays in wash cycle will not spin out i changed control board no help
Isyour washing machine displaying an error code? If so, try using the owner's manual to decipher the code and you may beable to easily diagnose the problem. The problem could be as simple as the doorbeing slightly ajar, the machine is in pause mode, or the spin selector isstuck. Checkthe handy chart in the article Washingmachine won't advance to washer spin cycle for more possible reasons why your washingmachine won't advance to washer spin cycle-and some tricks for getting itworking again.
Aug 01, 2012 | Electrolux Washing Machines
My frontloader EWF1090 will not spin / drum doesn't move around
if its not spinning and the drum is siezed there is a coin or a forighn object jamming it, it can be removed but would have to go into an electrolux repair shop, if its in warranty no probs if its 2 years or less outta warranty they will repair it under a endemic failure, which in english means the bill would go to the manufacture hope it helps
Jun 19, 2010 | Electrolux Washing Machines
The barrel has stuck
I dont know what brand of machine you have you didnt say so its hard to give advice but you either have a coin or other debris thats gone throgh the wash & has jambed the drum or the drum bearings have seized up.
May 28, 2010 | Washing Machines
How can I spin dry bath mats??
you gotta add a few more items like some towels, try it
Feb 12, 2010 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
200 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
