Question about Toshiba 32A40 32" TV
TV TOSHIBA 32A40 / Vertical Problem / Horizontal line on screen
I replace integrated circuit TA8427K = NTE158 Deflection Circuit Power Amplifier. Also check voltages all are ok. I don't have the squematic for this tv. any idea on what to do will be very helpfull.
If any one has a copy of the squematic by any chance you can email me at tomasteran@yahoo.com
TV Thosiba 32A40 chasis #0017 .
Thank you all for your coments.
    Top Expert:
  • Toshiba Master
  • 75,767 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on Jul 13, 2017
4 Suggested Answers
kevin000
  • 1847 Answers
SOURCE: NO DEFLEXION VERTICAL
check this link ......
http://www.freelists.org/archives/techassist/06-2005/msg00159.html
Posted on Aug 10, 2008
  • 51 Answers
SOURCE: No vertical deflection Toshiba model #CF27H40, need schematic
If this is a CRT television, replace all electrolytic capacitors in the vertical circuit - this fixes 90% of all vertical deflection problems. The capacitors most likely t0 fail are low-cap, high-volt such as 3.3 uF at 50 volts, etc. Quicker and cheaper to replace them all, rather than tracing it down to the one bad part. Total cost if you do it yourself is about $15 tops, and make sure you install them correctly - electros have a plus and minus lead, and must not be installed backwards or you'll have serious blow-upage of the new parts. Before replacing the caps, however, go over all solder joints in the vertical section, reheat them and add a touch of fresh solder. You may end up not needing to replace anything.
Posted on Jan 02, 2009
  • 4234 Answers
SOURCE: TOSHIBA 36A50 HORIZONTAL LINE WHEN TV IS TURNED ON
If flexing the board will "fix" the problem, then the most likely issue is poor solder connections on that board. Look for any connections that appear grainy or have rings and resolder them. The IC involved here is the vertical IC which will be a small flat IC attached to a heatsink. It may be marked LA7837 or something similar and have about 9-11 pins.
Try the resoldering and update this with your results.
Dan
Posted on Mar 04, 2009
TV has a great picture but wont "hold it". Keeps going to a single flat horizontal line across the middle of the screen. Tapping on side of TV used to bring it back but now, nothing. Just a line.
Vertical scan output section circuit fault. Absence of vertical scan causes the single horizontal line on screen. Horizontal scan output section is OK. Contact any service technician to troubleshoot the vertical scan output section circuit. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Horizontal line fault to CRT based TVs are given.
Oct 06, 2014 | Televison & Video
Horizontal ine in CRT tv
Failure of the horzontal linerity coil, possible dry soldering on the board of the components- resistors and capcitors- in the horizontal coil circuit . Also failure of the deflection coil- YOKE- in the crt. So check the coils and the circuit around this section as the rest of circuit seems OK.
Apr 06, 2011 | Televison & Video
Toshiba Model 53HX71: Bottom half of screen and sound is fine; top half of screen has collapsed to a horizontal line in the middle of the screen. Repairman I spoke to briefly said it probably won't be...
Hello
Your TV has vertcal scanning problem. All picture tube based TVs have, both vertical and horizontal scan to spread the picture to entire screen. When vertical scan section meets with a fault, the picture will collapse horizontally and fi horizontal scan section has a troubl, picture will collapse vertically. Your TV s fault , we technically say, to be vertical foldover. This is due to the vertical output section, a circuit part, inside the circuit board of your TV.
To rectify this fault you must open your TV. Unplugh it from the power socket, and open it. Locate the vertical output section, which is easy to do. Look at the deflection yoke, the coil fitted on the neck of the picture tube, and you will see four wires from it going to the main circuit board. Out of which, two will be thick, normally red and blue in colour, connected to the opposite direction on the deflection yoke, and the other two will be thin. follow the two thin wires, said later, and you will reach to a plug in point on the printed circuit board.
Before doing anything, just look at the soldering of that section carefully for any loose soldering, or bad soldering. Usually, the components in the vertical output section will get heated during working, and ahve a cahnce to get loose contacted soldering joints. Just resolder all the suspected points by applying a little more solder, and see the effect. If thi doesn't help, check the IC used in that section for trouble. Some capacitors will be there in this section, will get dried as aging, replace them first, as they are ver few in numbers, When replacing capacitors, note their polarity, as electrolytic capacitors have both positive and negative terminals like torch cells. Before replacing the vertical IC, replace all the capacitors, especially, two or three large capacitors on that section. Just do these and if you want any more assistance feel free to contact me through Fixya. OK
Dec 08, 2010 | Toshiba 27AF42 27" TV
Blue line across mid screen
check vertical deflection circuit.. make sure h.o.t is good..
Caution high voltage in horizontal circuit.. make sure u have electronics experience.
Dec 16, 2009 | Toshiba CN36Z71 36" TV
Toshiba TV (about 7 years old)
You had parts in the vertical deflection circuit failing, most common are the vertical output IC and possibly several capacitors also in the same circuit.
Sep 11, 2009 | Toshiba 36A50 36" TV
I have a three year old model pvc2542 tv/vcr combo the picture is just a line in the center of the screen
Bad vertical deflection circuit, unless you have a bad connection (bang on set to set it it fills out for a second) . you will need components replaced such as the IC, capacitors possibly a fuse from the power source to the vertical IC.
If its a bad connection soldering the IC pins is not to hard if you are OK with taking it apart yourself.
gd lk
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 21, 2009 | Televison & Video
H line problem
I think you are describing 'no vertical deflection.' If all you have on the screen is a single horizontal line, the vertical deflection circuit (or IC) has died. Unless you have service documentation on hand, I can't give a part number to replace but this is typically not an expensive failure and if the set was OK before, it is worth having repaired.
Jul 05, 2009 | Sansui 27" TV
No vertical deflection -Horizontal line on tv
check or re solder the ic of vert. defl.
Jun 09, 2009 | Sansui 27" TV
Toshiba 32A40 32" TV Problem
does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
I only see a horizontal line on my Tv.
thanks.
teranco@hotmail.com
Jul 13, 2008 | Toshiba 32A40 32" TV
POP and noothiing
yes it can still be fixed! the pop sound you've heard maybe came from a blown capacitor in the vertical deflection circuits. this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 10, 2007 | RCA E13309 13-Inch Diagonal XL-100 Color...
Toshiba 32A40 32" TV Logo
125 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
