Question about Siemens Dryers
I have a Siemens Washer/Dryer WDI 1440. The problem is that when I put it to dry, no heat is produced and my clothes are staying wet. What do I do? Many thanks
    President:
  • 1,462 Answers
Take top off. you will see dry manifold running across the top with various stats mounted on it. one of these stats will be resetteble ie with a small knob in middle. press and stat will reset. also check continuity thro the dryer heater and the other stats.
if a resettable stat has popped out, check also for lint blockage in the dryer duct
Posted on Nov 17, 2008
I have a washer dryer combo DWC LD1013 it stoped drying. My clothes are more wet when put in to dry. The clothes would be extremely hot but all wet. It works 1 cycle and then stops. Please help ????
In order to dry cloths, you need two things, heat source and air flow. Sounds like you have heat but no air flow. If you can, pull unit out and check vent for washer. Look around unit and make sure there is nothing blocking any vents. If you don't see any thing, try drying with vent not installed. I run into a lot of homes with clogged vents inside walls. By drying with no vent installed, it might tell you if you have dryer problem or a home issue. Good Luck
May 25, 2016 | Washing Machines
Siemens Wdi 1440 washer/dryer
It means your machine is not draining, Look out for the water exit open to drain water off.
Jul 21, 2014 | Siemens Computers & Internet
My whirlpool AWZ510E washer dryer - the dryer doesn't seem to be working - it goes through the cycle but the clothes are still as wet as before. I am using the same cycle as I always have which used to...
there are 3 reasons for a dryer not doing the job yet running through the motions. 1st, the heat is not being produced and only cool room temp air is circulating. this can be a burned-out electric element or an over-heat sensor, or in0line safety fuse. ( if gas, can be ignitor or gas valve coils).. It could be that the washer is not ringing (spinning) dry the clothes verywell and there is too much moisture stiil in clothes which would double the dry time from 50-60 minutes to 2 hours. 3rd, could be clogged vent line and the hot moist air cannot leave the dryer so the clothes get hot by the moisture stays.
Apr 28, 2010 | Whirlpool Washing Machines
Yesterday i was drying clothes and then all of a sudden it is running but not putting heat out...when it finishes the clothes are not wet not really damp but not dry
Heating element needs to be replace. It made by several sections to produce heat. some section are bad so heating didn't come on with its full capacity.
Apr 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a siemens WDI 1640 washer/dryer which is
I managed to find out the fault code E14 relates to faulty Heating element, product code 494069, and have been quoted £65.00 + Vat for the Bosch replacement. I am yet to decide on how I will proceed.
Dec 29, 2009 | Siemens Washing Machines
Dryer will not heat-up, clothes stay wet even after hours of drying! gas is on, gas bill payed,turning needlessly, no drying.
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Nov 13, 2009 | Frigidaire FEX831CS Top Load Stacked...
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Dryers Logo
1,794 people viewed this question
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Mike
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
