Question about LG WD-16115FD Front Load Washer
Bypass rinse cycle
Hi! I have a LG Intellowasher 7.2kg WD80130F and switched over from washing powder to using magnetic balls as substitute. As it is not necessary to rinse the washing anymore, I could not find a cycle in the manual that does not rinse. Is it possible?
Regards
Thea
South Africa
4 Suggested Answers
  • 351 Answers
SOURCE: 7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Posted on Mar 04, 2008
SOURCE: LG Intellowasher 7.2kg WD80130F
where is the drain filter located
Posted on Mar 11, 2008
Greg20
  • 149 Answers
SOURCE: Makes helluva noise when going into final spindry cycle
I would check the large pulley on the back for wooblyness(is that a word..lol) if so replace pulley.:)
Posted on Jun 13, 2009
mknzoz
Could also be damaged/worn bearings or broken spider (attaches to the inner drum and is part of the spindle/axle assembly). That's what mine turned out to be. This vid explains how to change bearings for similar model. Hopefully its not that severe. http://www.youtube.com/watch?v=XaFF2-Rl8Nc
Posted on May 10, 2014
Where do I put the soap powder when using my LG Intellowasher
Most just add the powder or liquid direct to the wash drum onto the clothes.
Jul 17, 2015 | LG Washing Machines
My LG intellowasher 7kg WM -131 50 FB is not washing and keeps flashing 5E
If the washer won't agitate the stator or rotor assemblies at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects.
Nov 21, 2014 | LG Washing Machines
Lg intellowasher wf t8501tp
My washer WF-T8501tp shows a PE error code.
Can anyone tell me what's wrong with it
Nov 17, 2013 | Washing Machines
Hello. I have an LG intellowasher front loader wd-8015c which has finished its cycle but the door will not open.... how can I get it to manually open? I have tried doing another rinse cycle and pumped out...
If you've waited the normal time for the interlock to allow the door to open and it's still locked, the interlock switch itself is probably faulty. Tricky job. Best to find a repair technician........Nomess
Apr 18, 2010 | Washing Machines
Jun 13, 2009 | LG WD-16115FD Front Load Washer
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Intellowasher WD-12126RD
it is coputer box in the washer. if it work on all other cycles. and stop on rinse. it need a new computer box . and in not hard to change.
Feb 15, 2008 | LG WM-2277HW Front Load Washer
LG intellowasher (front-loading washing machine) is starting to squeak.
I suggest u buy another washing machine. This one's had it!
Jan 12, 2008 | Washing Machines
LG WD-16115FD Front Load Washer Logo
51 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
