Question about Microsoft Office Professional 2007 Full Version for PC
Our cdrom is not working what i do - Microsoft Office Professional 2007 Full Version for PC
  • 849 Answers
Try some other cds, if not, then try to clean its lense, if again not then u have to replace it
Posted on Nov 17, 2008
Cdrom error
3 THINGS YOU CAN DO REDOWNLOAD/INSTALL THE DRIVERS FOR THAT SPECIFIC CDROM AGAIN .....OR IF IT WONT READ AT ALL BUY A NEW CDROM THEY MAKE THEM EXTERNAL OR INTERNAL WHATEVER FITS YOU.... OR YOU CAN GIVE IT TO A COMPUTER REPAIR MAN AND SPEND HUNDREDS BUT HE WILL ONLY TELL YOU WHAT I JUST TOLD YOU BECAUSE I AM A COMPUTER REPAIRMAN
Nov 21, 2012 | Dell Computers & Internet
Hi..my compaq CD drive is not working The CD drive is not seen in my compuer
hello
shut down the computer completely and disconnect power cable connection. make sure all cables to the CDROM are connected properly. If they are , remove the cables.
Remove the CDROM, clean it from any dust or debris with air compressor inside bay area and around the connection circuits. Replace the CDROM back into tray and start up computer. If problem persists. go to www.hp.com , retrieve CDROM part number and get a quote for replacement CDROM drive. The one you have obviously does not work at all.
Jul 16, 2011 | Compaq (120192-B21) CD-ROM Drive
I have IBM think pad Notebook and I can't play CD in my CD Rom CD Rom Name is: HL-DT-ST DVD -Rom GDr808 2n I wanted just play a simple audio CD or install some Software with install CD but I could not....
If your CDROM is older than a year than you need to take it to repair person and ask for service of the device. He will carefully clean the sensitive lense and other parts of the CDROM. If the CDROM does not work even after that you need to retire it and get a new one.
The CDROM drivers are built into windows. Windows detect the device driver once you start your computer with a CDROM in a working order.
Good Luck!
Feb 03, 2011 | Computers & Internet
Can I boot my e-machine M6810 from a usb cdrom drive? My build in cdrom fell apart and my usb cdrom works when the computer is on, but I can't seem to boot from the new cdrom I have tried changing the...
in short - yes! any e-machine, or indeed any computer build in last 5 years can be boot-up from usb port.
you need to enter bios and setu-up as first boot-up device "other", "boot from another devices", i do not remember which one is actually in this particular bios
plug in your external usb cd-rom, or indeed bootable usb-memory or bootable hdd and they should boot and work as they are on the computer.
another issue, internal cd-rom cannot be really disabled as only mechanical, external part stop working, it' logic part is still there and cmoputer therefore "see" it. you can disable it by downloading newest bios which have bit more power and tweaks than old one.
Jul 26, 2010 | E-Machines M6810 Notebook
The cd rom on my acer x1200 is not working. When I load a cd into it, it won't start up
Just check the connection of your cdrom on the My computer if they have appear. If the cdrom was display in the My Computer just clean the cd lens of that cdrom. Remove the cdrom from your computer and open the cd lens then clean it by the piece of cotton and add a small amount of alcohol then rub on the cd lens. After that insert back the cdrom then try to power on your computer and if the problem are the same not solved. Just replace the cd lens of your cdrom, But if the cdrom was not display in the My Computer just check the connection inside if the power supply of the cdrom are connected to its back.
May 13, 2010 | Acer Aspire X1200-B1601A PC Desktop
I cannot boot windows xp
Hi praph_wicked, normal order would be, floppy drive first, CDROM second & Primary hard disk drive third.
How ever if your bios does not comply you can always press the F8 key every two seconds & that should bring up (Please select boot device). Which will look like this;
Choose the CDROM drive with the windows CD in it.
If you have just one CDROM drive, make sure the jumper on the back side of the CDROM is set to "Master". If you have two CDROM drives connected, set one as master & the other to slave.
If using an IDE cable for the two CDROM drives. The CDROM at the end of the data connector is to be set as master, the 2nd CDROM connects to the next IDE connector & Its jumper is set to slave.
Mike
Dec 13, 2008 | EliteGroup P4M800-M7 Motherboard
HP Pavilion zv5000 CDRom Problem
Please increase your ram and cd model may be your system is not supported for this type of large type of applications
Jun 22, 2008 | HP Computers & Internet
Cd and dvd no longer shows on my computer or windows explorer
Hi soren,
Open up your pc, and remove the cables connected to your cdrom, power on your pc, then shut it down again, connect back all the cables into your cdrom and see if it works.
if you have an extra cdrom, try it out, you might have a faulty cdrom there, or maybe somethings wrong with your IDE cable(if your using that) or your sata cable.
Jun 21, 2008 | Toshiba Computers & Internet
Windows won't start
hi i as you said you have no cdrom you are using an external cdrom this may be your down fall but i shell try my best for you ok .
first start the laptop up press f2 or del to go into *********** board settings when you have done that move your arrows to the right finding your boot option go into that and remove your hard drive from that this will make your sys search for the usb or cdrom to load from then you must save this on leaving the motherboard when you leave it will say save y do that then it will restart and find your cdrom make sure that you have the windows disk in the cdrom before you start ok follow the on screen insturctions telling you to format the hard drive this will wipe the hard drive ready for installing the new windows program on it ok
the reason when you loaded the windows on the other pc and put it in your laptop is the motherboard is not the main op sys for the hard drive hope this work for you if not get back in touch and we shell try another way ok thanks all the best
May 22, 2008 | Compaq iPAQ Legacy-Light PC Desktop
Acer aspire 5310 cdrom drive cannot be recognise or not working
my cdrom drive is not working,what will i do or what would be the possible causes
Feb 21, 2008 | Acer Aspire 3680 Laptop
Microsoft Office Professional 2007 Full Version for PC Logo
16 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
