How do i hook up the cable tv to my mitsubishi model am-4201r?
  • 3 Answers
With a cable box and rf cables
Posted on Jan 05, 2009
I have no remote and no menus button on my old model Mitsubishi TV an I can't get to channel 3 how can I hook my cable can I use red white yellow cords??
Possible does it have a source button? If so,yes use cable and transfer to one of the other modes. Channel selection does not matter.HDMI,whatever.
Apr 17, 2016 | Mitsubishi Televison & Video
Mitsubishi rear projection tv, model WS-48311 - Lost audio after moving tv and re-hooking up cables. How do I get it back?
It sounds like this TV is being used only for the PS3. We'll need to troubleshoot this through a process of elimination.
If you're using Component Input 1 and audio, try using Component Input 2 and audio instead. If this set of inputs provides working audio and video - you can stop. Or, try going back to Input 1 once more. If Input 1 now works - you may have simply made a better connection. If it doesn't - then there's probably an issue with input 1 on the TV.
If moving to Input 2 above still didn't solve the problem, you should try using a different set of audio cables between the HDFury and the TV. If it now works, the original audio cables are faulty.
You can check the HDfury setup on another HDTV with component inputs with it connected to an HDMI cable. if the HDFury wors, you know the device and all the cables work. If you do this test and it works with your PS3, then you know that the PS3 is providing good video and audio signals via HDMI. If the problem follows the PS3 - then it's the PS3 at fault. If everything works perfectly on the second TV, then there is some issue with the audio amplifier / inputs / speakers of the Mitsu TV. You could get a cheapo stereo amp and speakers - or a set of computer speakers for audio - it all depends on how much you want to spend for sound.
Good lcuk!
May 07, 2015 | Mitsubishi Televison & Video
Hook a htc one sv to a mitsubishi 840 series tv
In order to view it your phone will need to have a mini hdmi port, your model does not. More then likely your Television will have an USB charger and you can hook it up to your phone and from there you can view your videos and photos only, it will not be able to show you your screen or a movie that you might be viewing from netflix or youtube
Jan 05, 2014 | HTC Cell Phones
How do you hook hmdi cable up to Mitsubishi hdtv wd62528?
Must select correct input, on your model the input used is not "labeled" HDMI, look in your user manual.
Feb 16, 2012 | Mitsubishi Televison & Video
The mitsubishi model vs-60805 tv will provide air channels off of cable hook-up, but does not provide cable channels. What needs to be done to recieve cable channels? The menu does not provide an apparent...
Mitsubishi VS-60805 is 1999 model tv and unable to receive digital cable channels because it is equipped with analog tuner that can not receive cable channels because it is almost 11 years old.
You need to hook Cable Box in AV input of tv, plug digital cable in cable box and get digital cable channels in tv. Cable box has its own remote control and inbuilt digital tuner to receive all digital cable channels and widely available in Store, Radio Shake, amazon.com etc.
Let me know if you have additional question.
Thanks.
Aug 07, 2010 | Mitsubishi Televison & Video
I'm trying to hook cable to my TV
probaly vertical ic going bad take to the shop
Apr 02, 2009 | Televison & Video
Just bought a mitsubishi 40503 dont have manual cant get my cable hooked up
check if the plug if your cable is fit for the antenna in of your tv.if ok then hook it up and do the manual/auto search of channels.
Mar 28, 2009 | Mitsubishi CS-40503 TV
No audio from Samsung DTB-H260F
I have a sr605 Onkyo receiver and just hooked it up to a new Mitsubishi 73" and I could not get the picture to work, sound did though. Here is the problem the Onkyo is HDMI 1.3 but TV calls for HDMI 1.3a. There is a big difference between the 2 and the Onkyo will not work with TV. The newer model TV'S say in the manual Category 2 V 1.3a. You need to make sure that all your parts are compatable. It makes a big difference.
Dec 05, 2007 | Mitsubishi HD-6000 DTV Receiver / Video...
HOOK UP INFORMATION
The cable should be on the Input to RF connector. Then you should reprogram tv for cable channels. If you have dvd then it should go to the inputs for 1/2/3 A/V inputs yellow for video, red for right audio and white for left audio. Color coded! Hope this helps!
Aug 31, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Poor reception
It sounds like a problem with the tuner in the TV set. Hook up a VCR through the video inputs and hook the cable through the VCR and if the picture is still snowy, the problem is the cable. If the picture is clear, the problem is the tuner in the TV set. If you wanted, you could simply leave the VCR attached to the TV set and change cable channels through the VCR, or have the TV serviced. Good Luck
Jun 20, 2007 | Mitsubishi CS-40505 TV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
