Question about Acer Computers & Internet
When i play movie files on the laptop andplug it into the plasma with vga cable and the cable for audio the movie plays but there is no sound on the plasma
    Genius:
  • 1,913 Answers
First check on laptop when u play the files sound comes or not.then check in plasma that not mute the sound.aslo check that u right attached jack of sound in laptop when u attach plasma onlky sound comes on plasma not on laptop.
Posted on Nov 17, 2008
When i hook my laptop up to my tv to play my movies the sound sound will only come out my laptop not my tv how do i fix this
Hi Gemma. You will need to state the connection type that you are using. If it is via a VGA cable, blue 15 pin D connector, then it will not carry sound, neither will a DVI, bigger white connector. Only an HDMI cable will carry sound and video. If you use HDMI, make sure that you set the HDMI as sound device as well. If you are usinf VGA or DVI, you will need to add an audio cable, 3.5mm stereo audio from your speaker/earphone jack on the laptop to "Sound In" on the TV. Hope this helps!
Nov 14, 2014 | Televison & Video
Audio out of sync
There could be a few different problems. You should first narrow down the possibilities. If you are playing the mp4 file directly from your laptop try changing the source. Put the mp4 on a usb drive or on a playstation/xbox or simply on a dvd. Try playing the file through one of these other sources. If the audio no longer lags behind the video than its likely an encoder setting that your Hisense doesn't handle well. If lagging is still present on all your sources then change the type of cable. If you are using HDMI try RCA or vice versa. You can also separate the audio from the video. Try using a VGA cable between your laptop and TV for the video and use a separate RCA to 3.5mm headphone jack for the audio, Most Flatscreen TVs have dedicated audio inputs for different video inputs. Try out these different set ups and you can determine if the problem is with the TV the Laptop or the cables in between. If it is the TV you may have a problem with the main board but this is unlikely especially if the audio video sync works fine with other file types.
Jan 27, 2014 | Hisense Televison & Video
What kind of cord do I need to connect my laptop so Netflix Movies can play on our T.V.?
Hi Candice,
First, without the model of your TV *and* laptop, no one will be able to give more than general information. It is much better to provide too much info than not enough - to get questions answered quickly here. With that said..
The short answer is that you need a cable that will connect to your note book (most likely either Video [yellow], S-Video, VGA, DVI, Display Port or HDMI) and the TV (most likely RF, Video, S-Video, PC / VGA, HDMI or RGB) Only the HDMI cable will provide sound with video. The others will require either an audio connection from the laptop (probably via a 3.5mm stereo headphone output jack) to the TV (most likely standard "RCA" jacks [red & white] - or settling for the laptop speakers or external amplified speakers plugged into the headphone jack.
If you are unable to locate a cable that has the connector supported by the laptop with a connector offered on the TV, it is likely because it is not possible to connect the two (HDMI to video, etc.) with only a cable. Additional hardware (probably expensive if available) will be needed to up or down convert & split audio to make it compatible.
Take a photo of the jacks offered by your laptop and those on your TV to a respected TV / Audio store / department for additional assistance. Some Radio Shack store employees are very good - and some are just plain horrible. Save your receipts in case it doesn't work to your liking.
Keep in mind that a $50 Roku box will stream Netflix (and a whole lot more) to most TV's "right out of the box" - or by buying $10 HDMI cable online to connect an HDTV. Don't spend 20, 30 or more dollars on an HDMI cable unless you want to pay too much!
I hope this helps and good luck!
Oct 22, 2013 | Computers & Internet
No sound from usb movies on my bush blcd32h8 tv
If this is a flat screen maybe the TV isn't capable of decoding the audio you have for the movie. Check to see what audio the TV can decode. For instance: MP3, AC3 etc and check the movie file with a app called mediainfo and go to the audio section and see if your TV is capable of decoding that audio. Also check the extension of the movie file and see if the TV can play those as well. MKV, AVI, MPG, etc.
Dec 28, 2012 | Bush Televison & Video
My sound on my laptop works fine but when i try to play a movie on it the sound is messed up but the movie plays fine whats wrong with it?
It could be a potentially corrupted movie file or disc. If it is a disc, examine it near a light source to check for scratches; also, consider testing it in a DVD player of some kind, and determine if the audio problem persists. Otherwise, if it is a file, try using another program to play it, or find another copy. If the audio problem persists for all movies, consider changing the program.
Dec 09, 2012 | Computers & Internet
Movie is not playing, downloaded from torrentz
Usually this is a result of unfinished torrent download. When you are downloading a movie using torrents you have to let it go up to 100% and probably has to start seeding. It may also be a result of the file format. What ever format you got, try to play with VLC(it supports most file formats). The other option you can try is that, play the movie from another computer because maybe you do not have Video Graphics Adapter (VGA) driver installed on your computer for proper display
Dec 15, 2011 | Computers & Internet
To play laptop thru samsung tv I am attempting to play laptop movie thru tv. I have tried the rca y cable with 3.5 mm plug from headphones of laptop to red and white audio in on the samsung tv., no sound....
So you are connecting the laptop to the TV using VGA port of the TV, right? To get sound in the PC input mode, you need to use the PC audio input jack (green jack, mini 3.5mm jack) not the RED and White RCA audio input, they are for Composite Video AV inputs. That is how I have my laptop and TV setup to watch Netflix.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jun 16, 2010 | Samsung LN52A850 52 in. LCD HDTV
Lead from external harddrive to tv- to show films,--usb connection from harddrive to 15pin to tv
Dear ragalgey,
As far As I can remember, most TV design to receive the signal to watch whatever you want limited to available TV station in your local broadcaster.
If you think you connect your harddrive to TV USB or 15pin (VGA cable) then you can watch the movie file from harddrive is a totally wrong!
You need a drive or a player for those file that capable to configure your TV to play them. Or at least you need a PC or Laptop Computer that played your harddrive then send the images/video via Video Out Jack (Yellow) from your laptop, or connect the 15pin VGA jack from Laptop PC out then plug in to your TV. In this case you'll need the Jack/adapter to convert from 15pin VGA from laptop to available Video jack on your TV.
Good Luck!
Best Regards,
bionic23
Dec 08, 2009 | Samsung Computers & Internet
Audio problem
there is no problem in os u have to install ur audio driver of ur laptops
Feb 24, 2009 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
