Question about Haier HLF11P 6 cu.ft. top load washer / dryer
Washer will not drain- filter is clear
I have a Defy Auotomaid washer. The filter is at the rear of the machine attached to the sump. When it failed to drain I disconnected this and cleared out lots of coins, an alan key & dog name tag! Eureka I thought I had it wrapped up!....but it still will not drain. On the face of of it everything happens as it should, except that it will not drain. Can you help?
the impellor swings quite freely. The outlet pipe is not blocked or kinked.
Regards Maria
  • mdavey Nov 17, 2008
    it's a front loading machine.
I replaced the drain pump and voila! Problem sorted!
Posted on Nov 18, 2008
I have a whirlpool frontload washer with model number WFW83005W00 and I have an error code F21 that flashes and then the washer stops working. What does this mean and what should I do?
Means the drain is taking too long . Most likely that the drain sump filter is blocked. Remove the lower front panel and unscrew the large white thumb screw attached to the pump. Water will come out so collect it then clean and replace.
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water is not drained from the tub when washing of the dishes is complete
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote if you liked my answer
thanks
Feb 13, 2011 | Bosch SHX45P05UC Dishwasher
My hotpoint washer won't drain, but it spins when I drain the water into a bucket. I took the pump off and I don't see anything clogged. Help please
Clear your Sump hose . its located @bottom of tub one end goes to the pump this has a filter in it ...Note which way it comes out to refit properly.
Apr 07, 2010 | Hotpoint VBXR1090D Top Load Washer
F o2 code washer will not drain
check pump filter and hoses for blockages including the sump hose if needs be
its blocked or the pump has failed
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer is failing to drain completely and the dock lock does not remain locked. The washer is only three years old
Hi there...well sounds as if you got a blockage either in the drain pump...the filter housing....or the sump hose to the drain pump...replace the door switch...
regards Sir Galahad
Aug 21, 2009 | Washing Machines
Water wont drain
OE-pump blocked. Disconnect the power before attempting any work. Use of an RCD (plug in power breaker) is recommended.
Disconnect pump from sump hose and check for obstruction in either item. Pump removal: power off, remove cover, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace.
Also check the filter - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together, remove the hose, take out filter and clean.
Good Luck!!
Mar 26, 2009 | LG WM-2277HW Front Load Washer
Creda excel 2000 skips spin and rinse cycle
The filter is located in the sump hose at the rear of the washer.
Remove back panel and undo the clip that holds the large black hose onto the rear of the drum .
Inside it ,you will find the filter.
Remove and clean.
Plz leave feedback for this solution.
Thanks.
Dec 14, 2008 | Creda W120VW Front Load Washer
Model WM2277HW leaks
Leaks from the bottom of the machine are usually related to a sump issue.
You will have to remove the rear panel from your machine to see leak happening. Do not reach into the back of the machine while it is powered if possible. Be extremely careful.
The rear panel is held on by 4 screws, with these removed the panel will pull away from the back of the machine.
With great care you will need to start the machine to observe where the leak is coming from.
At the very bottom of the machine is a black rubber tube that attaches to the bottom of the tub. It splits and goes forward towards the drain pump & filter unit and it also goes towards the back of the machine and attaches to a white air chamber which connects to the fill switch via a long black rubber tube.
Leaks will usually occur in the rubber sump hose; at the air chamber; at the pump connection or pump; or in the drain hose. Careful inspection of these points should reveal its location.
Leaks coming from the tub area can either be a center tub seal or from the inlet water at the top of the machine traveling down along the tub.
Further clarification of the leak location is needed for further diagnosis
Jun 27, 2008 | LG WM-2277HW Front Load Washer
Maytag washer PAV2300AWW
tilt the M/C carefully and look underneath for the pump its probably at the rear it may have a rubber sump under it feel for things ie squeeze the sump often ladies bra wirings escape the drum and end up in the sump and jam the impeller
its no big job to take off and clear if you put your finger in the hole you can feel the impeller fins see if they go round easily
hope this helps if not can you hear the pump kick in on the spin cycle?if not it probably is a knackered pump
Jan 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Haier HLF11P 6 cu.ft. top load washer / dryer Logo
104 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
