Question about Hotpoint TDC32 Electric Dryer
CONDENSER DRYER IS LEAKING WATER
My dryer is drying properly and the removable tank is filling with water as normal. However, the dryer has been recently moved to decorate and moved back and since then water is leaking out of what seems to be somewhere in the front. I wondered maybe if it's a seal gone etc. Can you help?
  • Anonymous Apr 03, 2009
    My dryer seems to be leaking water from somewhere underneath. I cannot put my finger on the source.
    Novelist:
    Champion:
  • 244 Answers
Make sure it is pushed all the way in but it could be something simple like when it was moved water has splashed out into the inside of your dryer which will make it look like it is leaking had same problems like that with other customers dryers leave it to run and more than likely that it will dry itself out
Posted on Aug 11, 2007
Water not captured in tank
It depends how wet the clothes were to start with, and you will not neccesserily see any water after doing just one load.
It may take 2 or 3 loads before you see any water
Hope this helps
Jan 23, 2010 | Dryers
Whirlpoos washer dryer combi awz510e combi.... when it spins it is emptying but when I dry clothes it is filling with water and still heating to dry them....I checked outlet pipe and its not blocked and...
Washer dryers use a small spray of water into the dryer 'condenser' to remove the 'steam' - the condenser is a plastic or metal box on the side of the machine the hot air flows through. To remove this spray, the water pump has to run most, but not necessarily all, of the time the machine is drying.
If the water pump is beginning to fail, it may well be ok on the short wash cycle, but seizes after a long time drying. That would make the machine very slowly fill with water on dry - the heater would be on. I would check the drain pump for wear, and if in doubt replace it - check carefully the filter and drain hose for blockages, and i would remove and clean out the dryer condenser which I bet will be full of fluff and half blocked. Every one i ever checked as an engineer was blocked to some degree!
If the machine is filling FAST on dry, check the insulation resistance of the wash water heater and motor and rest of machine. These are complicated faults and you may well need an expensive engineer like me to call!
Jan 02, 2018 | Whirlpool Washing Machines
My condenser tray is not filling up with water but the dryer is still working. where is ther water going and why do my clothes smell ?
I have the same problem, my water is gathering behind the condenser unit but it's stopped drying the clothes aargh!!
Jul 12, 2009 | Hotpoint TDC32 Electric Dryer
Miele T358C dryer. water not being pumped out of the sump??
TRY THIS:
TRY THIS:
In some cases cleaning the condenser out and drying the unit well will allow the unit to function again. Once a month you need to empty the condenser unit, it is normal for there to be some water in the tubes when you do this, you then have to flush the condenser by pouring water through it in either your sink or tub. Make sure that there is plenty of room around the drier for air circulation; and empty the water container often or reconfigure your pluming arangement to reduce the water left in the container. The circuitry of this unit it sensitive to high humidity and can cause the unit to not function properly. So with condensing dryers you have to work on keeping them clean. Let me know how it goes. Later :?) DRRXR
TIP OF THE DAY--
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
Feb 02, 2009 | Miele Novotronic T220 Electric Dryer
Water collects under dryer. Clothes dry. floor wet. Vent open.
You said, Water collects under Clothes dry on floor.This sounds like a condenser dryer that needs the water retention bottle empdied or the hose to the bottle is leaking.
Check these two things
Huuum
Please leave a rating before you leave the site!
Feb 01, 2009 | Dryers
Dryer problem
front load washing machine all in one are designed to use water supply also in drying cycle to condensed the hot air & move it out to outside , can you check the faucet if its open, so the moist unside the drum can out to the drain and the machine dry properly,if its ok & no water fill to drum may be your inlet water valve for the drying cycle has a problem.So that the time to call a technician to check it .
May 01, 2008 | Electrolux EW1200i Front Load Washer /...
Not collecting water in the tank
I also have this problem and is leaking all over my floor underneath...i've only had it a day. the condenser is soppin wet and no water in the tank..i'm dead angry...anyone else have an idea how to fix this mother F*****...thanks...clair
Sep 21, 2007 | Zanussi TC7102W Electric Dryer
Condenser Dryer Still Filling Room With Moisture
all dryers produce moisture. thats what hapens when you heat wet cloths up. the dryers job is to remove the moisture to dry. thats how the automai]tic cycles work by deteting the moisture in the exhaust. i will say there is nothing wrong with your dryer. only thing i dont understand is the containers of water?
May 13, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Dryer heats but no condensing of steam
The cold water feeds for condenser cooling and for wash cycle drum fill are controlled by separate solenoid valves (manifolded together at the cold water inlet hose union). When the solenoid on my condenser coolant valve failed a couple of years back, I got symptoms like yours. A new pair of valves isn't expensive to buy and is a trivial job to fit. If this is what has been happening, suggest you also inspect the insides of your dryer fan and of the pump - neither of mine took really kindly to having been cooked for hours on end. Alastair.
Oct 16, 2006 | Candy DQW150 Front Load Washer / Dryer
Hotpoint TDC32 Electric Dryer Logo
850 people viewed this question
Top Hotpoint Dryers Experts
jimorris77
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
